Question about Emerson LC320EM9 32 in. LCD HDTV
Unplugged tv and when plugged back in doesn't come on
    Top Expert:
  • Emerson Master
  • 75,404 Answers
Hello
If you have unpluged the TV from wall socket and it doesn't come On when you plug in back, either its power supply system or its stored memory has the trouble. Look whether the power indicator light coms on. Ensure that the main power ON/OFF switch at the front panel of the TV is ON. If the front panel power switch, control switch of your wall socket, and all the other electrical connections are OK, and still the TV doesn't come ON, surely the power inverter baord has the trouble and must be either repaired or replaced. if the power indicator light comes on, and your TV doesn't come ON by remote POWER ON button, the settigs that were stored has vanished, and resetting it to its original setting is necessary. Follow its manual for 'initial setup" and so all the recomended setting there. OK.
Posted on Apr 11, 2011
Vizio not getting power
The screeching noise might be to a damaged back-light inverter board. Your TV must checked. Contact any service technician. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 18, 2013 | Vizio L32 32 in. LCD HDTV
Coby lcd on and off
unplugged for a while the tv and then tried to disconnect all the source that has been hooked up in your tv. then re plugged it and turn on, if still doesn't resolved the problem. unplugged and at this time you will need to remove the back cover and look for the power supply board then replace bulging capacitors.
Oct 03, 2012 | Pioneer PDP-5080HD 50 in. Plasma HDTV
My screen kept turning blue for couple of weeks and now i can't get my television off stand by mode
unplugged the tv for a while then re plugged it and power it on, lets see weather it works normal. if doesn't work unplugged it again then remove the rear cover then look for a bulging capacitors in the power supply board.
Sep 27, 2012 | Televison & Video
My insignia flatscreen tv monitor doesn't work. I
Shut off the tv, unplug it, hold the power button on the tv for 90 seconds. Plug it back in. Hit menu? Do you see a menu? (if not, your tv needs serviced)
You might also have a cracked LCD.
Jul 01, 2012 | Televison & Video
No sound, no picture
Hello sorry to hear that. From your description it sounds like your signal board may have been damaged by you plugging in your laptop to it. The signal board is the one with the tuner on it.
Feb 22, 2012 | Vizio P50HDTV20A 50 in. Plasma HDTV
I have a 32" LCD
Tries tv and cable box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The cable box to reboot and upgraded it software.Than go in to the tv Menu go to Audio Setting go down and do a resetting back to the tv factory setting.By doing these steps u have a great chances to get ur tv audio sound back.Not have the same problems after this than the tv Tuner signal board it is shorted in the audio ICS modjulation sections.Tries websites like Shopjimmy,com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 16, 2011 | Televison & Video
My Samsung 20" CRT model # TX-P2036 has power
May be you should press the channel button on the set itself or there is a problem with the eeprom of the set circuit.
Jun 15, 2011 | Samsung TXP2036 20" TV
Grandson put a penny into the SD slot while the TV was on. It immediately stopped working.
This happened to me yesterday. My daughter put a penny and a dime in the SD slot and none of the buttons or volume were working on my TV.Only the power button would work.
I fixed it by simply removing the penny and dime out of the SD slot and then i held the power button for 10 seconds. After I unplugged the TV from its power source for 5 minutes and then plug it back in. When I turned the TV back on everything was back to normal.
For a second I thought I was going to have to buy a new TV, lol. Hope this helps. If it doesn't work the first time then try it a second time.
By the way I have a Panasonic PT-52LCX66 LCD Projection TV..
May 02, 2011 | Panasonic TC-P46G25 Flat Screen Plasma...
TV won't stay on for more than 2 seconds
TV turns on for 2 seconds then shuts off. Sleep/timer blinks. Won't go back on unless unplugged and plugged back in
Nov 16, 2008 | Televison & Video
Emerson LC320EM9 32 in. LCD HDTV Logo
127 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
