Question about Ruud UBHC Air Conditioner
Replacing a thermostat on a heat pump with a Honeywell Pro Th3000 series non-programmable digital - Can not get the unit to com on
  • Susie Langford Apr 13, 2011
    Thanks for the help but tech support just tells us to call a professional--But thanks for the answer
Check the setup for correct settings. Refer to the install guide here.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CFIQFjAA&url=http%3A%2F%2Fjacksonsystems.com%2Fimages%2Ffile.php%3Ffile_id%3D1592&ei=qy--UOWbNbCB0QGzqYDoAg&usg=AFQjCNFHka0SMf_L0OJNVHHW3spIAZEk4A&sig2=Ft9-NZvXyhZjybW7ELf1hw&cad=rjt
Posted on Dec 04, 2012
  • ropes98
    ropes98 Dec 04, 2012
    Check the setup for correct settings. Refer to the install guide here.http://www.google.com/url?sa=t&rct=j...
  • ropes98
    Follow the procedure below to configure the thermostat to match the installed heating/cooling system, and customize feature operation as desired. Setup function Settings & options (factory default in bold) 1 System type TH3110D only 0 Gas, oil or electric heat with air conditioning 1 Heat pump (5 minute compressor off time in heating and cooling) 5 Heating cycle rate (CPH: cycles/hour) TH3110D only 5 For gas or oil furnaces of less than 90% efficiency 1 For steam or gravity systems 3 For hot water systems & furnaces of over 90% efficiency 9 For electric furnaces [Other cycle rate options: 2, 4, 6, 7, 8, 10, 11 or 12 CPH] 6 Auxiliary heat cycle rate (CPH) TH3210D only 5 For gas or oil furnaces of less than 90% efficiency 1 For steam or gravity systems 3 For hot water systems & furnaces of over 90% efficiency 9 For electric furnaces [Other cycle rate options: 2, 4, 6, 7, 8, 10, 11 or 12 CPH] 8 Emergency heat cycle rate (CPH) TH3210D only 9 For electric emergency heat 1 For steam or gravity systems 3 For hot water systems & furnaces of over 90% efficiency 5 For gas or oil furnaces of less than 90% efficiency [Other cycle rate options: 2, 4, 6, 7, 8, 10, 11 or 12 CPH] 9 Compressor cycle rate (CPH) 3 Recommended for most compressors [Other cycle rate options: 1, 2, 4, 5, or 6 CPH] 14 Temperature display 0 Fahrenheit 1 Celsius 15 Compressor protection 5 Five-minute compressor off time **See page 8 [Other options: 0, 1, 2, 3 or 4] Function number Setting To begin, press and hold the s and t buttons until the display changes. Press t to change settings. Press s to advance to next function. Press and hold ts to exit and save settings.
  • 40 Answers
Your new t/stat need to be configured the best solution is to call tech support they are great I;am an A/C tech and I call them anytime I have a problem 1800 468-1502
Posted on Apr 13, 2011
How do I replace an old White Rodgers thermostat with new honeywell TH5220
The Orange wire for the reversing valve and used with a Heat Pump
If you have a heat pump, then yes. If you have a gas furnace then no. If you have a HP and the reversing valve is not connected, then you might just be using the emergency electric heat strips. :-o
Jul 21, 2014 | Honeywell Th5220d1003 Non-programmable...
I have Honeywell Pro TH4000 series. The fan wiil not come on what do i do
Depends on what type of heat you have...gas, oil , electric, heat pump? Make sure it is the right thermostat for your heat source. Some thermostats have a switch on the back for fuel or electric.
Dec 08, 2013 | Honeywell Programmable Thermostat Heater
How to setup honeywell th3210d1004
you need to change the differential pressure to 3 degrees.that means the unit will not kick on unit it is 3 degrees warmer then the setpoint
Mar 06, 2013 | Honeywell TH3210D1004 PRO 3000...
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
Wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
Wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Honeywell st7000
what type of system do you have? cool/gas heat, heat pump, electric cool & heat. split system or package unit?
Mar 14, 2008 | Honeywell Programmable Thermostat Heater
Ruud UBHC Air Conditioner Logo
233 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
