Question about Bosch Evolution 800 SHE58C05UC Stainless Steel Built-in Dishwasher
The door won't close. The latch seems jammed. I have tried setting and releasing the child lock inside the handle. The problem seems to be with the latch itself. From inside the door, I can see the tongue the clips into the latch, but it seems stuck. I can't get it to move, even with gentle force.
4 Suggested Answers
here2helpBSH
  • 27 Answers
SOURCE: Bosch Dishwasher SHX46A latch stuck in down possition.
look at the latch via the hole in the door where it closes to the tank? is the latch faced away from the tank? if so, then grab a paper clip and fold it so you can hook it around the latch then just pull outward towards the tank. you might need to hold that paper clip with some pliers. if it happens more than once then you will need to replace that door lock.
Posted on Mar 19, 2009
here2helpBSH
  • 27 Answers
SOURCE: Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
Posted on May 30, 2009
  • 457 Answers
SOURCE: our Bosch SHY66C05 door latch is stuck in locked position
you have to pull back the spring or replace the lock. the repair is pretty easy.let me know what happen.
Posted on Feb 26, 2010
Child lock on, tried open Door Handle from inside, is the handle broken no longer open Door from inside even when child latch off 2003 Cadallac Deville
Hi. Try : unlock the car ( push open 3 times) open doors from outside ( make sure they unlocked) switch child lock to lock position and back to open. Pull again on the handle after you switch before you close the door. Let me know if it helped.
Apr 27, 2017 | Cars & Trucks
Jammed door on a 2007 Entourage
The door latch is damaged, you need to remove the inside door panel and replace the latch, it is a dealer only part.
Dec 31, 2016 | 2007 Hyundai Entourage
How can I open the left rear door if the latch won't release?
Its the child safety on, you can try disengaging the child safety if partially open, black latch
Feb 01, 2016 | Jeep 2004 Liberty Limited Edition
My back door in 2004 Ford focus child locks are locked and I can't close my door. How do I disengage the child lock to close my door?
Your latch may be stuck in the latched position. Try pulling on the handle as to open the door while lifting the latch arm.
Jul 31, 2015 | Ford Cars & Trucks
Door stuck closed
The door has the child safety on possibly try opening from outside with a little leverage if not successful remove door panel to unlatch from inside with a small screwdriver on the latchy
Jul 22, 2014 | 2002 Jaguar X-Type
Mazda 6 2005 driver door jammed
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
Jan 04, 2013 | 2004 Mazda 6 Sport
My rear passenger side door will not close
Just use the outside door handle and pull on the latch that is closed. If you use the inside door handle then you will have to undo the child lock.
Pull on the latched that is closed while holding the outside door handle....Make sure that it is unlocked...
Dec 29, 2011 | Ford Focus Cars & Trucks
2006 buick lucerne back doors won't open
My friend just had this problem and he reached in and pulled the inside door handle back as far as it would go, and then let it go, allowing it to 'snap' back. For some reason this fixed it. We have no idea why. By doing this on one door, both rear door locks freed up and the rear locks are now working. Before, both rear locks were stuck and you could not open the doors from the inside nor the outside. Not sure why it works, but maybe it will work for you!
Jun 10, 2011 | 2006 Buick Lucerne
Dishwasher runs even tho the door is open
The door interlock switch is jammed in the closed position.
There is a metal tab on the inside top of the DW frame that engages a lock just behind the handle on the inside of the unit. The lock tells the machine the door is closed and it is OK to run. If that jams the unit thinks the door is closed.
Open the door.
Look for the latch inside the door behind the handle.
Try to release it with a screwdriver.
If you need to you can remove the handle and repair from inside. It is usually a simple jam that requires you to gently pry the latch open.
REMEMBER TO TURN THE POWER OFF FIRST.
Hope this helps. Please rate this if it helps you.
Thanks,
Adrian
May 03, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
The locking mechanism on the rear passenger door isnt working.The door will close but the metal catch will not lock.How do i repair?
I have seen some times the latch assemblys get rusty or dirty and the inside or outside door handles are pulled and the latch assembly siezes in the open position not allowing the door to latch closed..but this may not be the case .. check to see also if the child lock switch position is not stuck in the halfway position, also check if the latch has not flipped to the close position before the door was closed thus jamming the striker latch..this can be fixed by pulling the catch out while opening the door handle..hope this helps good luck...
Nov 05, 2009 | 1995 Pontiac Sunfire
Open Questions:
Bosch Evolution 800 SHE58C05UC Stainless Steel Built-in Dishwasher Logo
48 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
