Hello, I have a 50H82 toshiba rear projection tv and the red is out of alignment. I read your post and I tried doing the convergence option and i could align the red up to a certain point. The problem is that the red is more warped than anything. It's worst at the bottom left of the screen and gets back to normal towards the center so aligning it to the letters in the bottom left of the screen leaves it unaligned in the center (crosshair). I am still wondering if it is the Convergence chip or if it a bulb problem. thanks for your time.
  • 11,800 Answers
The convergence chip is failing and is no longer capable of delivering the required current - you must replace it.
Here is a complete repair kit
http://www.tvrepairkits.com/xcart/home.php?cat=2754
Posted on Apr 11, 2011
Shows a red scream
try the auto focus if shows error then try to do it manually in convergence and make sure you align all colors. If still doesn't work, then you will have to have the convergencs chips replaced.. Approximately $250 repair cost..
Mar 07, 2010 | Toshiba 50H82 50" Rear Projection...
My Toshiba 50H82 television takes about 30 minutes to clear up and during that process, it shakes.It becomes clear but still has wavy lines at the top of the screen which is about 6 inches.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2010 | Toshiba 50H82 50" Rear Projection...
I am seeing green and red shadows and in the corner the shadow goes up at an angle Help
Ur convergence is dead.U know how to solder?Tries this website.Tv Repair World.com.Buy ur tv model convergence kit,and repace it.
Sep 07, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba 42wh46p convergence problem
Yes Replace Both STKs also CK all low ohm resistors.
Feb 15, 2009 | Toshiba 50H82 50" Rear Projection...
Color convergence messed up
you can get the convergence repair kit for your model that has both convergence IC and the six feed resistors at this link, The repair kit also has step by step instructions with pictures so you can do the repair your self. Heres the link.The 50H82 kit is the same for the 57H82, http://servicemanuals.vstore.ca/product_info.php/pName/toshiba-50h71--50h81-convergence-repair-kit/cName/convergence-repair-kits
Feb 01, 2009 | Toshiba 57H81 57" Rear Projection...
Toshiba 50h82 convergence issue
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 11, 2008 | Toshiba 50H82 50" Rear Projection...
Convergence for toshiba 50h82
Either mode is fine...just save your session when done!
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Nov 16, 2008 | Toshiba 50H82 50" Rear Projection...
Toshiba 50H82 Wavy Lines - Jittery Picture.
Dont have the manual - sorry - but this is the most likely cause.
*Screen Looks 3-D
*Colors wont align
Nov 11, 2008 | Toshiba 50H82 50" Rear Projection...
Convvergence problem w/ Toshiba 50H82
You need to replace following ICs, may be 2 pieces in your tv for convergence problem.
IC, STK392-110T
Toshiba Part Number: 23135090X
Please search on net for availability in part stores
Sep 27, 2008 | Toshiba 50H82 50" Rear Projection...
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
