Question about Whirlpool LHW0050PQ Front Load Washer
Lid switch washer wont drain or spin
  • 958 Answers
Could be a broken lid switch.
check the continuity on the two end wires...if you close the lid, there should be continuity. if you open the lid, there should be no continuity.
i hope i fix your problem.
tnx,
drcool
Posted on Aug 07, 2008
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Wont drain and spin
Pl click if helped.
Apr 17, 2013 | Whirlpool WTW4950XW Washer
My whirlpool front loader wont final spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 05, 2013 | Whirlpool Washing Machines
Kenmore washer front load 417 wont spin
Click if helped
Feb 18, 2013 | Kenmore 24032\24036 Top Load Washer
My washer will agitate but wont spin out or drain any ideas ?
No washer will spin when the lid is up. If the lid is down and it still wont spin, the first thing to check is the lid switch. If it's bad, the washer will think the lid is up all the time. You'll need to remove the front panel of the washer to see it. Here is the switch to order.
Dec 07, 2012 | GE Washing Machines
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Nov 08, 2008 | Roper RAS8445KQ Top Load Washer
Washer won't spin
press in clips each corner with putty knife and lift top remove screws bottom front panel slide panel down and off ..locate pump. turn washer to spin and switch on if faint hum felt at pump more than likely plugged with something if pump is running fine ck for something in drain lines..most washers i would say lid switch but on those i believe if switch was bad wouldn't aditate either ck by raising lid ..if agitates with lid raised ck lid switch if not switch ok
Sep 13, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washing wont spin or drain it stops after rinse
slowly open and close the lid and listen for a clicking sound. most washers have a lid switch that clicks when closing the lid. if this switch is bad then the washer will not spin or drain. depending on what brand of washer you have.
Jul 06, 2008 | Washing Machines
Whirlpool Washer wont spin or drain
check your lid switch. if it will aggitate and not spin or drain.. then your lid switch is your answer
Oct 29, 2007 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
