Question about Konica Minolta magicolor 2300DL Laser Printer
Printing size mismatch - Konica Minolta magicolor 2300DL Laser Printer
How to solve mismatch paper size on xerox 4118
Set the paper size correctly.
http://www.fixya.com/support/t5246564-paper_size_mismatch_xerox_workcentre Paper size Mismatch on Xerox workcentre 4118 cant print
Mar 06, 2016 | Xerox Office Equipment & Supplies
My HP C7180 says mismatch when trying to print DL envelopes. It has worked in the past.
CHECK THE PRINT SETTINGS FOR THE DOCUMENT YOU ARE SENDING TO THE PRINTER YOU MAYBE TRYING TO SEND IT AS A LETTER SIZE INSTEAD OF DL SIZE. YOU CAN FIND THIS IN THE PRINTER PROPERTIES WHEN PRINTING THE DOCUMENT CHECK PAPER SIZE.
Mar 11, 2015 | HP Photosmart C7180 All-In-One InkJet...
Envelope mismatch
In Windows operating system, press CTRL+P then go to page setup and adjust the page/ print size from there.
Sep 11, 2014 | Office Equipment & Supplies
When I try to line tells me that the paper size mismatch and only takes a copy of the text
Have/had the same problem: Getting "paper size mismatch" on the C4280 status screen, after we got a paper jam. Every time we hit OK and put in paper, Message about "Now printing Alignment page", it feeds through quickly, with nothing printed on the page and reverts back to Paper size mismatch. Finally got rid of the error, not sure how, but now when I try to copy anything, we only get the lower right postion of the document that I'm trying to copy. Printing from the PC seems ok.
Powered off and back on, and it is back to P"now printing alignment page, quick feed through and "paper size mismatch" error. AND
When copying directly from the glass panel,it will only print a quarter of the page -however it prints and coorectly if we print directly from the computer.
The problem is the paper size sensors. Remove the plastic access panel that is for access to the rollers in the back and has 4 rollers on it. There are two papaer sensors attached to the printer circuit board (PCB). The control arm for the sensor is a small plastic piece that extends slightly into the paper path above the PCB. The plastic can be broken when you are removing a paper jam. I stuck a small piece of a match stick in the sensor to keep it open (as though a wider piece of paper was passing throught the printer). I can't switch to smaller card stock, etc, but who cares, it works.
The copying problem is caused because the C4280 will not scan correctly until after it does the alignment phase.
Dec 16, 2010 | HP PhotoSmart C4280 Laser Printer
Paper mismatch will not go off
here is a simple way to print off that.
open printers and faxes from control panel.
right click on your printer icon and select printing preferences, on printing preferences window click on features tab.
select paper size as custom and it will open a new window to enter the size, enter the width and length of paper you want to print on and type Name as size1 and click on save, now again select more from paper size and selec size 1 (just saved) and click on Ok on printing preference and you are ready tp print,
best of luck!!!!!!
May 02, 2010 | HP PSC 2175 All-In-One InkJet Printer
Paper size mismatch for A9 envelope (5.75x8.75)
Set the envelope size in the printer properties paper size list to A5 (5.83 x 8.27) which is only .08 inches wider than the short side of an A9 envelope (5.75 inches). The paper size sensor on the HP6520 printer must not be sensitive enough to tell the difference. I can print A9 envelopes just fine using the A5 setting.
Jan 20, 2010 | HP Photosmart C4580 All-in-One - InkJet...
How can I print envelopes on my HP C5180. I've had it over 2 years and have never been able to get it to print any size envelopes. I always get a 'paper mismatch' message. HP tech support has never...
I tried all of the suggestions on here and nothing worked. My envelopes are 5x7.3. So, I finally just put in 5x7 and lo and behold, even though there truly was a paper mismatch this time since that was NOT the size of the envelopes, they printed. I did have to move the text boxes some to make them print correctly. So, I guess the solution for my printer is to actually mismatch the size of the paper/envelope so that you will NOT get the "paper mismatch" error message. Will it work on other size envelopes? I have no clue. This is the first time I've ever been able to print an envelope at all with this printer that I've had 2 or 3 years.
Dec 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Paper Mismatch
I had this problem on the 6300 and was able to fix it by doing the following:
After selecting print, select preferences.
Select the Features tab.
Under Resizing Options, select "Custom" from the drop down menu.
Put in the custom dimensions of the paper on which you are printing.
Save it under a new name (e.g., "Invitation")
When it is time to print,
Select "More" from the drop down tab under Resizing Options.
At the bottom of the list of those options, you will see your custom sized saved.
Select it, and happy printing.
Mar 11, 2009 | HP DeskJet 5550 InkJet Printer
Checks mismatch
You may need to change the settings on your printer to accept the checks through the paper input. Otherwise try the printer setting on your QB to have it print from the tray. Make sure it is set to print on 8 1/2 X 11 sized paper and not 3 X 8 or some strange size.
Let me know if this helps.
Jan 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printing card envelopes
It sounds like you may have a size mismatch in the settings. Please refer to this link for information and the settings that you need to verify. You should be able to refer to the packaging for the envelope size to select.
Hope this helps. Please rate this information.
Thanks
Nov 06, 2008 | HP Photosmart C6180 All-In-One InkJet...
Konica Minolta magicolor 2300DL Laser Printer Logo
47 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
