Power Saver Dell All In One 948
Hi Hashch,
I've looked under print window as well as control panel, however there is no power option anywhere. I've even scrolled through the options on the printer itself. All it will allow me to do is delay the power saver by 240 minutes, but it will now allow it to be shut off.
Thanks,
Marisa
    Sergeant:
    Champion:
  • 246 Answers
In normal control panel there is not a option to do that
normaly it comes form the printer software
You have to check it from the pinter software window to control it
Posted on Aug 07, 2008
Dell printer
Go to page setting option and set own required option. If you are not well do setting contact Dell support teams.
Read more... Dell Printer Support
Thanks,
Aug 27, 2014 | Dell 948 All-In-One InkJet Printer
Would no battery charger cause wifi to disable
Your power saving settings might be configured to disable WiFi if the laptop is not plugged in
The power settings will be in the screens saver section, and in the control panel under Power Options (or just search for Power Options).
Look at the settings for your power plan and tell it not to disable WiFi when not plugged in.
Aug 12, 2014 | Dell LATITUDE Computers & Internet
How to turn off power save mode
Navigate to the control panel and double click power options.
Under the turn off monitor select never.
Click apply then OK.
Thumbs up!
damnor01
Jan 30, 2011 | Dell E153FP 15" LCD Monitor
How can I disable my monitor's sleep mode? I don't want the screen to go black, I want to be able to see the screen saver as it cycles. Thank you.
You can do this in the Power Savings options with Windows. For Windows 7, rght click on the display (anywhere with no icons or running programs) and choose Personalize. Click on Screen Saver in the lower right hand corner. Adjust the Wait time for the screen saver if desired and click Apply. Then click on Change Power Settings. This brings up the Control Panel > Hardware and Sound > Power Settings. Then click on Edit Power Settings for the active power plan. (For desktops it is usually the balanced power). Then change the setting for Turn off monitor to Never when plugged in. Also change the Sleep time for the computer to Never. You can do the same for when on battery but it will shorten the length of time that the computer will be able to run on the battery for laptops. Then Save Changes and close the windows.
For older versions of Windows, these advanced power settings are also available from the Screen Saver settings page but details may differ.
I hope this helps.
(for most monitors, as long as the computer is sending a signal the monitor will stay on)
Dec 23, 2010 | Dell 22" SP2208WFP Widescreen Flat Panel...
Dell Vostro screen has started going black every
Check the power settings. Start/Control Panel/Power Options. There is a setting separate from the screen saver to turn off the screen in the Power Options control panel. DVD playback overrides the power options settings.
Mar 25, 2010 | Dell Inspiron 9400 Notebook
Dell Inspiron 1100 screen goes into power saver mode after 45 sec
it sounds like your most likely having trouble with the hibernate feature try this
start>>control panel>>power options>> click on the hibernate tab
un check enable hibernate mode
this should fix your issue
Apr 10, 2009 | Dell Computers & Internet
Screen stays black after closing and then opening Inspiron 6000
you try pressing the power button once?  or maybe even pressing any keys.
also try adjusting your power management
vista) start. control panel. power option.  Edit plan settings.
xp) right click anywhere.  properties.  screen saver tab.  power management.
Mar 09, 2009 | Dell Inspiron 6000 Notebook
Dell 948 printer- won't print in black and white
I had this problem. It's actually very easy to fix:
- Click Print -> Properties
- Go to "Advanced" tab
- "More options"
- Deselect "Use color cartridge for all black printing"
- Select "Use black cartridge to print black and white"
- Click "Ok"
You should be able to select the "Print in black and white" option now and stop all the frustration!
Anthony
Feb 05, 2009 | Dell 948 All-In-One InkJet Printer
Turning Off Power Save Mode on Dell All in One 948 Red Printer
you can find it from the printer properties tab in the print window
Aug 07, 2008 | Office Equipment & Supplies
Dell 1704 FPTt monitor goes black after about 20 min
Go to Start, Control Panel, Power Options and change your monitor setting to never turn off. If you do leave your monitor on all the time then you should set up a screen saver.
Dec 22, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
k24674
jasbo
jasbo
