Question about Maytag SDE4606A Electric Dryer
Dryer takes a long time to dry. How long should an average cycle take?
  • Maytag Master
  • 7,482 Answers
The normal drying cycle for a normal load of clothes should be around a hour if you dryer is 220 Volts.
Chances are you have a Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a Free answer, Please rate me.
Posted on Apr 11, 2011
  • hillaryw2003 May 11, 2011
    This was great!!! I feel confident that this could be my problem and when I have a service person come in to check on my dryer I will have some knowledge !!! Thank you
  • 8 Answers
SOURCE: Takes a long time to dry one load
The fact that the dryer takes so long to dry indicates either an air flow problem or a "heating" problem. You don't say weather the units gets hot or not but you do say that it has been giving you this problem for 3 years so I'll assume that it does heat. You should make sure that there is air flowing through the dryer by just going to where the dryer is exhausted to the outside after turning on the unit and see if it is blowing hot air out. If there is good airflow but it is not hot you may have a bad element or thermostate and you should contact a professional to diagnose the exact problem and repair it. If there is not a strong warm airflow from the exhaust then you probably have an airflow restriction of some type. The first thing to check is the lint filter. Every dryer has a lint filter that should be cleaned out after each load. Check you owners manual to find the location of yours and make sure it's clean. If it is plugged, clean it and check the airfow again. If that does't solve the problem, you need to determine if the dryer vent hose is kinked or plugged. The vent hose is usually located at the bottom of the back of the dryer and are usually only attached with a clamp of some type. Just disconnect the dryer vent hose from the back of the dryer, turn the dryer on and check the air flow at the dryer exhaust. The there is little or no air blowing out of the dryer it could be a defective fan. This is a complicated repair and should be done by a professional. If the exhaust coming out of the dryer is strong you know the problem is with the exhaust hose so check for kinks, crushed duct or blockage and repair it then re-connect the exhaust duct to the dryer, turn on the dryer and go back out to the outside exhaust and see if it is now blowing strong. GOOD LUCK. I hope this resolves your problem.
Posted on Nov 29, 2008
Jimster
  • 240 Answers
SOURCE: Taking to long to dry
This could be two problems. First problem, you must have good ventilation. Blow out the dryer vent with a leaf blower or some other type of fast moving air. Also be sure that the vent on the outside isnt blocked by little woodland creatures trying to find a nice warm home. Also be sure that the vent isnt kinked or blocked between the dryer and the wall. If that doesnt work, you may have only 1 of the 2 elements actually heating behing the drum. This would entitle removing the front and drum to check. Let me know if you need further help.
Posted on Dec 09, 2007
docjohn174
  • 943 Answers
SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Posted on Sep 27, 2008
  • 11 Answers
SOURCE: it takes usually 3 complete cycles to dry an
try taking the vent hose off your dryer and running it through a cycle with it off...if it drys ok then you have a clog somewhere in your venting.
Posted on Jun 23, 2009
canbruce75
  • 1776 Answers
SOURCE: Dryer has some heat but is taking a long time to dry clothes
This type of problem can be caused by a partially burnt heating element, a blown thermal fuse, or a faulty high limit thermostat. All of these components can be checked using an ohm meter or multimeter. Sure hope this helped and best wishes.
Posted on Jul 27, 2009
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
I want to know how hot my dryer gets. I do not have temp. controls on my model
Good Morning Tabitha,
I see that you are looking to see how hot your Frigidaire dryer, model# FER311FS, actually gets, due to you not having temperature controls on your particular model. Being that you have just the timed dry cycle, it provides up to 100 minutes of drying time at high heat for regular and permanent press items. When drying permanent press items, turn the cycle selector to 40-50 minutes. This is the average time needed to dry most loads of permanent press items. The load tumbles without heat during the last 10 minutes of the Timed Dry cycle. Use this setting to refresh clothing, pillows or blankets or to dust draperies. Heat-sensitive items such as plastics, foam rubber or similarly textured rubber-like materials or items containing feathers or down should be dried only with this setting. Hope this is helpful.
-Best Regards-
Mar 17, 2014 | Frigidaire FER311FS Electric Dryer
The dryers is 16 months old and it's taking multiple cycles to dry an average load.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 03, 2011 | LG DLE2101 Electric Dryer
Dryer wgd5300, takes a long time to dry. seems
The burner is supposed to05245ec.jpg cycle on and off all through the drying cycle. Over time the operator coils 279834 get weak and quit. They are really easy to replace. This short video show a normal Burst of heat from a dry and the normal length of time it fires off
May 19, 2010 | Whirlpool WGD5300S Dryer
We have a WHIRLPOOL dryer model # KGYE670BWH3 and the problem is that when switching from a high to low temperature it stays high at hot rather then low temperature. but then after awhile it will go low.
Hi and welcome to FixYa. I am Kelly.
Lets talk about the physics of changing drying temps mid cycle. The dryer has built up an average temperature that is high when you had high selected. The clothes are hot. The drum is hot and the chassis / ducting is also hot. It can take almost 10 minutes for that residual heat to be removed before you notice that the drying temp has changed.
Having said that, there are a few things to check as to why it is taking an extended period to dry your clothes and why the dryer seems to be running hot.
1. Check the outside dryer vent flapper for lint build up.
2. Check the ducting for lint fromt he dryer exit to the outside vent flapper.
3. Remove the lint filter and look for lint build up around the lint filter ducting. (if it needs cleand do NOT use anything sharp to remove the lint.) A vacuume crevice tool and an old coat hanger folded in half works great.
After checking all of the above and making sure they are ALL clean, try your mid cycle change again an see if it takes less time to notice a difference.
If it is still taking a long time there may be a problem with the temp selector switch.
That is it for now.
Thanks for using FixYa.
Kelly
Mar 05, 2010 | Dryers
Dryer is taking multiple cycles to dry average weighted clothes/
Make sure the dryer heats up and that the proper cycle is selected. If the dryer doesn't heat, the cause will need to be determined. This can be an ignitor issue, the timer, or a gas supply problem.
If it's heating, check the vent line from the dryer to the outside of the dwelling for lint clogging. Also check the diverter (flapper valve) at the dryer vent outlet to be sure it opens all the way and that the air stream is pretty strong. Lint clogging is one of the most the most common causes of dryers not drying very well or taking an extended drying time period.
If the vent line is longer than 20 feet and has multiple bends, backpressure in the line can cause additional clogging.
Jan 25, 2010 | Whirlpool LGR3624JQ Gas Dryer
What is the correct temp at dryer exhaust when dryer is on ''high'' I have a electric bill that has doubled and I am researching each appliance in my home.
The high thermostat usually cycles around 145°F (on average), but it is the time it takes to dry a load that really matters. Nothing should take more than an hour. Usually around 40 minutes average.
Jan 02, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer wed5200tq0: I have to run cycle
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
****(((Please disregard step three if this is a GAS dryer)))
Aug 21, 2009 | Whirlpool Dryers
It takes usually 3 complete cycles to dry an average load of clothes.
Jun 22, 2009 | Roper REX5635E Dryer
It now takes on average an hour and a half to dry one normal load of laundry. The clothes come out hot but I constantly need to add more time before they are all dry, any suggestions to the problem... it...
Ok, this is a venting issue or, faulty thermostat. check he following to combat this issue.
1. Venting
2. Thermostat
Jun 15, 2009 | Whirlpool Dryers
Maytag SDE4606A Electric Dryer Logo
793 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
