Question about Dryers
Its not getting hot. is there a reset button.
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Apr 11, 2011
Where is the reset button on a electric hot water heater Model # ME30H6-S45100 Serial # 1643103783645. I have no hot water and I want to check the reset button.
didnt specify unit--- generic answer --- on most where the thermostat and element connections are is usually a red reset button to push
Jun 18, 2017 | Water Water Heaters
Electric wh high temp shut off button keeps resetting
Water heater has upper and lower elements. Only one t-stat. Check to see where tstat is set to. Turn down to lowest level. If breaker still resets then replace tstat. It is letting the water get to hot no matter what setting it's on. So water is getting so hot that it trips breaker.
Dec 28, 2012 | Water Heaters
I have norton tankless water heater, and the reset keeps getting tripped... what can cause this?
It can be the breakers in your house or the reset button is malfunctioning
Aug 23, 2012 | Water Heaters
I have a Rheem Marathon 105 gal. electric hot water heater. No hot water ....
Check 240 circuit breaker.
Open top cover on water heater and push in ECO red reset button.
If reset button will not reset, then replace thermostat.
If reset is not tripped out, then either upper thermostat is bad, upper element is bad, or water heater might be getting 120V instead of 240V.
If you have some hot water, then best suspect is lower element.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 26, 2011 | Rheem MR105245 Marathon Electric Water...
Bwater does not get hot , no clicking sound when hitting reset button, already replaced upper element, it is gettting power but no HOT water
It could be that the reset button is faulty and will not reset. they are not very robust and can fail when operated repeatedly. The thermostat could also be open circuit especially if the original element had failed. Try replacing both reset and thermostat controls.
Sep 21, 2010 | Rheem MR85245 Marathon Electric Water...
No hot water. Circuit breaker not the problem. Which plate do I open to check the eco?
Remove access panels on water heater's side the top thermostat has a red reset button on it.
Press reset button and it will take about 30 mins or more to get hot water. If you have a meter or test light check wires to elements for power.
This would be the first thing to check on the water heater.
May 21, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Hot water wont get hot
1-First check for power to water heater and remove acces panels on heater to check power at thermostats. Thermostats have a reset button on them that trip and can be pressed to reset.
2- If none of the above have changed any thing and you have power you may have elements gone bad.
If an element is gone at top you will get scalding hot water then go to cold.
If an element on the bottom is gone you will get luke warm water then will get cold.
May 17, 2010 | Water Heaters
My doesnt get hot do i need to replace element took back cover of noticed reset button on element box was kicked do i need to replace element and re set switch to
Hi!!
Before spending money on another heating element, clean filter, vents and exhaust pipe (take it off and check both, the pipe and inside the dryer). A restricted hot air passage will make the heating elements thermal protection (reset switch) to activate.
Once unclogged, press the reset button and try again.
Good luck!!
Mar 20, 2010 | Dryers
Lochinvar electric hot water heater reset button
Is this a two element 220 Volt heater? Do you know how old the elements are?
I have a feeling your elements need to be replaced.
What are your thoughts on my remarks?
Dec 21, 2009 | Cell Phones
Dryers Logo
Top Dryers Experts
