Question about Boating
When I put the battery in yesterday somehow the wires burned in the harness that runs from the battery up to the front of the engine
  • 5,501 Answers
Hello, I have a Cabin Cruiser myself and I hate when stuff like this happens. The one sure thing is that you have a short on either end where the wires connect. Make sure your +POS and -NEG terminals were hooked up correctly on the Battery.
Remove the parts that the burnt wires were connected to and take them to an Auto-parts store for a bench test or use a Multimeter and see if the connections are grounded to the case.
You may want to take photos of the damage, because with better insurance coverage, this may be covered under a fire or casualty claim. The Marine grade wire is a different than auto wire and is more expensive.
You did not indicate if this is an outboard or Inboard/Outboard setup. First, fix the problem and then look for new wiring looms if the Insurance is kicking in. There are Marine Salvage yards on the Internet and sometimes you can find what you need as a used item if you are paying for the repair. Depending on the damage, you could replace only a few wires and be done with it.
I hope you find my solution very helpful and Good Luck on this problem.
Posted on Apr 11, 2011
Controls on my 05 Jetta Drivers Door, aren't working, even though I replaced the faulty wiring harness.
What Door Harness(s) did you replace? Why? List each function in Left Front Door that is not working. It is possible you damaged Left Front Door Harness. Are the other doors working fine? Disconnecting the Vehicle Battery is not necessary though it is safety step.
Mar 16, 2014 | Volkswagen Jetta Cars & Trucks
Wiring harness
look underneath did drive belt snap in two , rear has white plastic fan on top of it that should be rotating with engine running if not yep you broke a belt , don't know about wire could it be from front PTO they are electric so it will need a wire ,one possibility is that drive belt broke slapped front PTO and broke off wire , that musta been some snow your pushin ooh and a reminder never push a hydrostatic drive tractor without pump turning it will dammage it
Feb 08, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
My motor mount broke and my wiring harness was damaged when the engine landed on it. now my radio does not work.
You need to replace the wiring harness and re-do all the connections in the harness. It's very likely that the wiring harness your engine landed on is connected to your radio somehow.
Sep 11, 2013 | 2005 Cadillac Deville
Alternater wont charge battery and fusable link on starter keeps burning
Bad voltage regulator. Usually built-into alternator.
Start car and unplug battery, if it dies your alternator is dead. Get new alternator. If car keeps running, get a voltmeter and check voltage coming through - should be higher than 12v but less than 18v. Any other number means your voltage regulator is dead, cheaper to get a new alternator.
Jan 11, 2013 | 2000 Dodge Neon
Igot these for codespo443 p1747 po755 po750 po743 po113
P0443 Evap purge control
P1747 Pressure control "A"
P0755 Shift solenoid "1" malfunction
P0750 Shift solenoid "A"
P0743 Torque convertor clutch circuit
P0113 Intake air temperature high input
For now leave the P0443 that is a evap code. for code 755 750 743 how did you get these code? clear it do key on engine running. the reason I say this is somewhere especially at the tranmission harness you are somehow disconnected. Check the transmission range selector switch closely, inspect the harness and do a wiggle test on the wires. some how your wire are disconnected
Feb 26, 2012 | Cars & Trucks
I have a 2001 rodeo V6 standard. The check engine code is for mulitple missfires. Sometimes when you stop the rpm go down to zero and acts like it wants to die. Have tried taking off the coil packs one at...
whats your fuel pressure when this happens are there any O2 sensor codes also? or fuel trim codes?
if low is pump at fault? or is fuel filter blocked?
check fuel pressure regulator on rear of inlet manifold left side of car- pull off vacuum hose going to inlet manifold while engine is running to make sure fuel isnt leaking out of hose, might have to take of protecting bracket dont usually have to though.
what is your fuel quality like?(no water or contamination/stale fuel)
how many KM's what are plugs like or plug gaps?
and check is it burning oil? fouled plugs?
there was a problem with earth crimp in engine harness on left bank front section near injector that needs to be cleaned and soldred to repair or replace with new engine harness, its for O2 sensors, TPS, canister purge solenoid and IAC motor injectos also wires break in same harness on the front left head(rocker cover/cam box cover) while its running wiggle and pull on loom if engine starts to run rough or stumbles its probably wiring related.
dont disconnect coils wiring looms while engine running it can damage driver circuits in engine ECU!!!
so some things to look over hey.
Mar 10, 2011 | 2001 Isuzu Rodeo
This is on a 2001 Chevy Corvette with 70,000 gentle miles. One or the other of the front daytime running lights (turn signals) keep burning out. The recepticle (connection plugs) looks burned, and the...
this is just a stab in the dark, try cleaning the battery to engine ground and the engine to body(frame) ground, i have a strande geeling that during startup you are getting a voltage spike through the lights
Nov 10, 2010 | 2001 Chevrolet Corvette
I CUT THE RED N BLACK WIRE ON MY 2002 HONDA CIVIC N TRYING TO ADD LIGHTS WIRE N SOMEHOW I'M NOT GETTING ENOUGH POWER FOR MY HEADLIGHTS. PUT EVERYTHING BACK, N NEW BULB N STILL NOT WORKING ? DO I NEED TO...
If it was the Red/Black wire at the right headlamp, you cut the headlamp ground that grounds through the Daytime Running Light Module. If you then added more lights onto this circuit, you could have overloaded the drivers in the module and burned them out.
Oct 24, 2009 | 2002 Honda Civic
Ground Wire fried...
Unfortunately there are only two ways to do this. 1. open up the harness and trace & replace burned wire. 2. cut both ends of the burned wire and leave burned section in place, then run a new wire BUT you need to know if there are any branch circuits coming off it and destinations, and, if the burned wire has crossed over into any other wire you will not see it. Third option is to replace entire harness with a good one. (time intensive and expensive, but actually the best option) Note: you also need to find the reason it burned or anything you do will likely fry again!
May 11, 2009 | 1992 Saturn SL1
Won't start, engine turns over with no spark
I can tell you this from my experience with my dakota is that the wire harness that goes from cpu to the carb/coil/transmission is notorious for burning on the manifold. I have 2 dakota's and both had same issue. Just remove the harness and check all wires to make sure none are exposed.
May 10, 2009 | 1995 Dodge Dakota
Boating Logo
53 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
