Question about Garden
What are the gap specs for points and fly wheel to mag on a 4hp b&smotor
  • 608 Answers
15 thou on points and 8 thou on mag. Regards Phil
Posted on Apr 11, 2011
It not starte
For the saw to start it needs 3 things. 1. fresh fuel. If the fuel it is older than 2 months dump it out and put in fresh fuel. Next it needs air. Check the air filter. If you hold it up to a light you should be able to see light through it. If not clean or replace it. Last it needs spark. Pull out the plug and let it touch the saw so it makes ground. Pull the starter cord and you should see the spark jump the gap in dim light. If no spark the points and /or the condenser have failed. They are under the flywheel. You will need a fly wheel puller to get to those. To remove the fly wheel you must take off the nut. To do this must keep the fly wheel from turning. I have stuffed some rope that will not shed particles into the spark plug hole. Then put your wrench on the nut and spin it off. Use the puller to remove the fly wheel. The points and condenser are usually in a metal box to keep them clean. You will need to know the proper point gap. You can measure the gap fully open with a feeler gauge and set the new points to the same gap. Reassemble and the saw will run.
Nov 24, 2015 | Garden
What iscoil gap on gx160 honda5.5
Call a small equipment dealer & ask
for the specs
Jul 14, 2014 | Honda Quincy 17 - Gallon Air Compressor...
What are the specs.on a poulan pro 428s
Use a business card to set the gap and it will go.
Apr 24, 2014 | Poulan 17" T&E Gas Trimmer
No spark
The spark generator that sits close to the fly wheel only needs a mm gap. Make sure that this is the case. If there is a small gap there is possibly a break in the wire or the points under the fly wheel may also be rusty.
Jun 29, 2013 | Garden
What should the clearance be betwwen mag and fly wheel toro
The gap should be about .010 (Ten Thousandths of an inch), but truthfully, the way I set it is to loosen the coil bolts and place a shiny business card in between the coil and flywheel. Tighten the coil up snug against the business card and then remove it. This should set the gap close enough to the correct setting for you; done. Hope this helps and best of luck to you.
James
Nov 11, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
How to install a ARMATURE-MAGNETO on a BRIGGS &STRATTON 18 H. ENGINE? Is there a certain gap between the fly wheel and the armature-magneto?
removw chop screen and blower housing unplug little wire under mag remove 2 screws and remove mag reverse prosess with new mag but pull mag away from fly wheel and snug screws center magnet on flywheel over legs of magneto place .010 feelre guage inbetween and loosen screws, hold mag against flywheel and tighten remove feeler guage reinstall kill wire on bottom of mag install blower housing and chop screen hope tis helps
Aug 07, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
This engine is an old 8horse on a snowblower. it has no spark and the plug is good. so is the coil bad and is the coil the piece that sits above fly wheel,and does the fly wheel need to come off to connect...
doesn't mean coil is bad, may just need points and condensor. They get old and wear, old b/s part no. 299061 , these are under flywheel , and points cover. either replace points and condensor or try cleaning them with flex file.(temp. repair) points gap is .020. not sure of air gap of coil to flywheel. coil can be tested at most shops, You will be able to see if points are burnt visually. hope this helps.
Jan 13, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
I am trying to find the magneto gap for amakita dcs 340 petrol chainsaw
use a regular post card inserted bet fly wheel and mag close enough
Oct 05, 2008 | Makita Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
