Question about AOpen MX46-533V (91.89U10.061) Motherboard
MX-46-533 WAN'T TO BOOT PROCESSOR IS GOOD (new one) also ram are new no bip when booting just processor fan runing .
  • AOpen Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 11, 2011
Asus Mother Board(P5GV-MX) display off, Boot time sound also off, The ram is OK. Processor can't check. Please give me solution.
Oct 18, 2010 | ASUS P5GV-MX Motherboard
Asus k8s mx not boots but fan rotates and without
Long beeps are saying 'no RAM'. Any beeps with RAM in place? Remove BIOS battery (silver) for 10 mins to return to factory defaults.
Sep 12, 2009 | VIA Asus K8V-MX K8M800 Chipset 800MHz FSB...
No Display in dell optiplex gx280 & Fan speed is veyy high
GM from pakistan fsd problem in motherboard chepset......you should repare u r gx 280 or heat the chepset with heat gun ........
Aug 16, 2009 | Dell OptiPlex GX280 PC Desktop
SYSTEM DOESN'T BOOT UP, GET LONG STEADY TONE WHEN SYSTEM STARTS
please check the system memory (RAM)
remove them and carefully clean in mouth with a clean A4 white sheet
or change the memory if possible...... and if problem still occur, please check the system processor too...
to check if the processor is functioning, remove the heat sink on the processor and boot the machine placing your finger on the processor chip.
it burns your finger after a short sec. BUT this should be done in a controlled way and after the memory had been tested for
May 10, 2009 | ASUS P4S533-MX Motherboard
Can't boot
i should have thank u, if u add some more details in ur query, anyway check the following :
1. check if ur power cable is properly connected and free from damage or broken
2. did u see any blinking indicators on ur front panel
3. open the cabinet and look if the fans are spining
4. did u hear any beeps during (POST) startup
***** if ur answer to the above is YES, then
remove all the power connectors (outside and inside) , all the add on cards, RAM sticks, (and also the processor if u have a pair of smart hand), carefully clean and blow out dusts, and reinsert all of them to thier respective places, and try again.
If u find all these solutions useless, ur processor or RAM or mainboard might defective.
May 06, 2009 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
ASUS MOTHERBOARD P5B-MX WIFI WON'T DISPLAY
Are you sure the onboard video is working? Try an external card and see if this works. All the beeps when you remove the memory is good because you know the processor is working.Are you sure you have the right memory? Some machines won't boot or anything when you have the wrong memory.
Dec 13, 2008 | Computers & Internet
Pc is not booting and no display in monitor
First, try resetting the CMOS. If it is not working, replace the RAM. Could be a damaged RAM
Sep 11, 2008 | ASUS (P4BGV-MX) Motherboard
ASUS P4VP-MX display problem
If I understand you right, your display is not coming on with your new hardware. Try the eliminaion process:
take out the new things. Install them one by one, and try booting each time you install one. If that passes, turn off and install the next one, until you isolate the one failing. Once you know it, installit properly or come back here for help.
Feb 18, 2008 | ASUS P4VP-MX Motherboard
AOpen MX46-533V (91.89U10.061) Motherboard Logo
44 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
