Question about Panasonic CT-32G6 32" TV
Panasonic CT-32G6E Intermittent single horizontal line
Approx. 7-year old CRT unit:
While watching tv, picture began to be squashed vertically until it was a single horizontal line. Sometimes turning set on or off or tapping side of cabinet would restore picture, but eventually there was nothing but a single horizontal line. Switched TV's for several months. Plugged in set tonight, and I appear to have a full picture again. Set has been running now for about an hour without a recurrance of the "single horizontal line syndrome."
I suspect a cracked PCB or a loose solder connection due to the intermittent nature and the tapping on the cabinet sometimes fixing the problem. If so, where should I look for cracked pathways or loose connections?
Thanks!
  • IowaStater Aug 14, 2008
    Thanks for the ideas.
    My PCB has two components side-by-side in a line that are similar, but not identical, to the picture link you sent. They do not have the black "hump" and have three holes in the metal part. Are these the ones that you are suggesting I resolder?
    Also, I have looked on both sides of the PCB and cannot find an IC295890 label. Can you please provide a "landmark" to help me locate it?
    Thank you!
  • 2,337 Answers
I would suggest to locate a part that looks like the one on this link and re solder all the pins, also check for any high power resistor nearby the IC295890 and put some fresh solder.
Let me know if you need further assistance.
Posted on Aug 07, 2008
SOURCE:
Panasonic CT-36G34 TV vertical deflection circuit
there is a single ic you need to find, usually location ic301 or 401---it will have between 7 and 13 pins in a single straight row---a generic number is printed on the front---usually begins with a LA but can be different
Locate the chip and gain access to the bottom of the board, the pins on the chip break loose from heat==SOLDER ALL THE PINS BACK AND YOU SHOULD BE GOOD TO GO---its a very common problem in these sets.
12_19_2012_7_41_26_pm.jpgsomething like this with more pins possible--will be attached to metal of some sort to keep it cool.
Dec 19, 2012 | Panasonic CT-36G34 36" TV
Horizontal lines across TV screen Pansonic CT 35g25
Check its vertical output section circuit for any component damage or loose soldering terminals. Check the solder terminals of the vertical output IC. Resolder all the suspected solder terminals by applying al little more fresh solder, without making any solder bridge short in between adjacent solder terminals.
If this do not help you, replace the vertical output IC. Lose of Vertical Scan is the problem of your TV.
Aug 04, 2012 | Panasonic CT-35G25 TV
Our tv, a Panasonic # CT-36D11E/CT-36D11 only shows a horizontal thin line across the screen. The sound is fine - any ideas? Is it time to replace or could it be repaired cheaply?
Resolder the vertical IC and replace those capacitors near and next to your vertical IC. If the horizontal line still appears, you may have to replace the IC. Thanks for asking and be caredful!
Jun 18, 2010 | Panasonic CT-36D11 36" TV
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Philips TV showing horizontal lines model 27pt6441/37
You likely have an elevtrlytic capacitor bad on the B+ line to the vertical ouput ic. If you continue to use the set like this it is likely the vertical ouput ic will fail.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Jun 26, 2007 | Philips 27PT6441 27" TV
Horizontal lines center of Panasonic HDTV
Usually there is a capacitor in the pump up circuit and/or an IC in the vertical circuit that causes this problem. Contact Panasonic at: http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001 To find a servicer in your area. This will give you an idea of the cost of repair. Hope this helps.
Jun 02, 2007 | Panasonic CT-27HL14 27" TV
Panasonic CT-32hX41 vertical picture problem (hourglass)
this product has a pincushion problem and requires servicing but unfortunatley it is what we call in the business NECO
Dec 05, 2006 | Panasonic CT-27HL14 27" TV
Panasonic CT-32G6 32" TV Logo
264 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
