Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Partition external 250gb drive
I've just purchased a WD external hard drive (250gb) and converted it to NTFS from FAT32, I can't remember how to partition it so that I can split the 250gb off. Using windows XP so any clues would be appreciated.
Thanks
Darsh
  • 129 Answers
Why would you want partition it??? XP will recognise the 250. Partition was useful for win 98, but pointless excercise with XP.
Posted on Sep 25, 2008
Hi, my ps3 won't recognise my 1tb wd external hard
The problem with the new 1Tb WD Passport that I just purchased is that it is a USB 3.0 format and apparently PS3 doesn't recognize that speed.
Haven't found a workaround for it yet, but all these people advising you to reormat anew Passport drive are wasting your time.
Jul 02, 2012 | Computers & Internet
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
Is WDBAAU0015HBK is fat 32 system file format? IsWDBAAU0015ABK is also available? How to convert my existing seagate 1tb hard disk from ntfs to fat32 with out making partition?
You can convert FAT32 to NTFS, but you cannot reverse this process. If you want to set up the hard drive for FAT32 you need to delete the NTFS partition the create a new partition and then format in FAT32.
Aug 24, 2011 | Western Digital WD Elements Desktop...
Im copying a game that is 5 Gb and my free space is 160Gb why does it say that the "there is no disk space" is there anything i could do?
1.plz check your hardisk about any virus..
scan your hardisk a good antivirus
and check your partition type FAT or NTFS, FAT32 only support maximum file size 3gb
if FAT32 please convert as NTFS.
please letme know this helpful
Feb 01, 2011 | Western Digital WD Passport 250GB Portable...
Can not get hard drive to convert from fat32 to ntfs
Convert FAT32 to NTFS In Windows XP:
  • Click Start -> Run
  • Enter "cmd" into the text field labeled "Open".
  • Click OK button
  • If you want to convert drive D (D:), enter the command "vol d:" in the command window, to find the volume label for the D: partition
  • Then enter the command "convert d: /fs:ntfs" to convert the D: partition from FAT32 to NTFS
  • When prompted, enter the volume label for the partition
Convert FAT32 to NTFS In Windows Vista and 7:
  • Click Start sphere.
  • In the Start Menu search box, simply enter "cmd" and hit enter.
  • If you want to convert drive D (D:), enter the command "convert d: /fs:ntfs" to convert the D: partition from FAT32 to NTFS that way can be confusing so an easier way is to download a free software heres the link http://www.partition-tool.com/personal.htm
Oct 20, 2010 | Maxtor Hard Drive
My Ps3 is not reading this new external hard drive I just purchased.
The trick with the PS3 is that the HDD must be in FAT32 format. Most External drives nowadays are shipped preformatted using the NTFS file system.
You will have to convert the current partition or a portion of it to FAT32 to allow the PS3 to see it.
You will need a PC to do this on
HDD Partitioning Tool : http://visopsys.org/files/partlogic/partlogic-0.69-iso.zip
Manual : http://partitionlogic.org.uk/manual/index.html
Have not used this particular product myself yet, but it should be quite easy if you follow the steps in the manual.
Regards,
BD
Sep 06, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Hitachi external hd 250gb SimpleDrive Mini is not showing up on recovery commander manual disk [partitioning, Bootfixer, I tried to optimize, format, delete, move, create, change vol level, validate explor...
The only thing left is the USB cable and the conversion circuitry between it and the drive connector. Listen to the drive. If it clicks a lot it isn't getting enough power from the USB port on the PC anymore. If it's OK, then it's back to the cable or the conversion circuit.
Jun 15, 2017 | Hitachi SimpleDrive Mini 250GB USB 20...
Xp not recognizing my 250gb WD passport
The Western Digital My Passport line, besides the Essential Series, is originally formated for a Mac (in the HFS+ format) and as such cannot be read by Windows PCs. You can either get a program to read the External such as Macdrive, or format it to NTFS or FAT32; formats that are readable by Windows. I would recommend formatting it to NTFS, because you can only transfer up to 4 Gigabyte files to FAT32, while NTFS is nearly limitless.
May 03, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
I have a 250 Gig WD hard drive originally hooked up to Mac OSX 10.5.6.  I put files on it and then a co-worker looks at those files on a PC. Now, she's given the drive back to me to add more files. These...
Greetings.
files bigger than 4 gigs cannot be save on fat32 drives. NTFS file system is capable of saving files bigger than 4 gigs.
The MAC - to PC did nothing to change it. It did not change while she look it at her pc.
If u want to be able to copy files bigger than 4 gigs to your drive, change the format to ntfs.
  • It is easy to convert partitions to NTFS. The Setup program makes conversion easy, whether your partitions used FAT, FAT32, or the older version of NTFS. This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive. Whether a partition is formatted with NTFS or converted using the convert command, NTFS is the better choice of file system. For more information about Convert.exe, after completing Setup, click Start, click Run, type cmd, and then press ENTER. In the command window, type help convert and then press ENTER.
Link to steps and other info
http://technet.microsoft.com/en-us/library/bb456984.aspx
Hope that helps.
Jan 10, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Formatted (on PC) 1TB WD hard drive cannot be altered on Macbook
What OS are you running? What is it formatted as FAT32 or NTFS and how big are the partitions. Various operating systems, hardware and formatting schemes have different limitations. If you want to use the drive in Leopard formatted with NTFS which is the only way to create partitions larger than 20 or 30 GB you may need to install an NTFS file system driver like FUSE.
The other option is to format it as HFS and install Macdrive 7 in Windows to use Mac formatted drives in Windows.
Hope this helps.
Dec 27, 2008 | Western Digital 250GB MyBook External USB...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
189 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
