Question about Samsung SCX-4725FN All-In-One Laser Printer
Was working fine. Now wont print. IP error? - Samsung SCX-4725FN All-In-One Laser Printer
    Scholar:
  • 111 Answers
There are two things possibile, first the waist container is full so you need to empty this.
Second for some reason the printer driver is demaged and you need to replace the driver, now there are two ways to do this, first you use your original printer cd is with the printer at the day of purchase, second you can go to the web; open google and write "samsung printer SCX 4725fn" open the side of samsung and chose the newest print driver version for your printer and download it for installation to your computer; then do the same with the scanner driver and install them both on your computer, now check the funktion.
Posted on Apr 12, 2011
Network installation error access denied on hp lj1020 my printer was working fine. i have installed printer on xp m/c its working fine but when i install it on win7 it give error print spooler error or...
HP says to use the Vista drivers. You have to install it a a local printer follow these steps....
1. Make sure the printer is turned on and connected to your network. Verify that you can access the printer's internal web page by browsing to its IP address before continuing. Print a network config page or make note of the IP address and Name. (should be a static IP)
2. Click >> Start >> Control panel >> Devices and Printers.
3. Click the Add a printer
4. Select Local printer
5. Select Create a new port and select Standard TCP/IP Port and click Next button.
6. Under Device type, select TCP/IP Device. Under Hostname or IP address, enter the printer's host name (found on the printer's network configuration report the generated above). Click Next.
If you get a message about Additional Port Information Required, then the printer was not found using the host name. You can go back and retry or using the printer's IP address instead of the host name.
7. Select HP or Hewlett-Packard from the list of manufacturers and select and select your printer model. Click Next.
If your printer model was not listed, then select Have Disk, browse the HP CD that came with your printer and select the first file that starts with hp and ends with inf.or use currently installed driver if you have teh correct on installed. Click Open then OK. Select your printer model. Click Next.
8. It will ask for the Printer name -- enter a new name or use the existing one. This will be the name of the printer that you select from other applications.
9. You may be asked to share the printer. Make a choice and click Next.
10. The Print Test Page box appears. Go ahead and print it.
11. Click Finish.
Dec 19, 2010 | HP LaserJet 1020 Printer
Our HP DesignJet 500 will not print.
If they changed the server queue, or possibly did not even reinstall the printer queue on the new server, all is not lost.
First try connecting to the printer directly using USB or parallel if that's an option. If you can set it up as a local printer and that works, at least you know the printer is fine.
If you can print a diagnostic page with all of the specs of the printer, you can find the IP address and print directly to the printer, bypassing the server print queue. You can also find it in the Setup, IO Setup section of the printer's control panel.
To create an IP print connection, add a new printer, choose local printer, then choose "create a new port" of type "Standard TCP/IP port". Then enter your printer's IP and point to the driver as before, and you should be able to go direct.
Jun 10, 2009 | HP DesignJet 500 InkJet Printer
Hp laserjet 3055 offline when print out via networking when direct to the laptop, its working fine.......
Go to reports print configuration page it will give to netwrok configuration page check if the printer IP Address is in the same range of the IP Address of the laptopn.
If yes than check if you are able to open web browser of the printer on lkaptop using IP address of the printer if yes in laptop go to printer driver properties there go in Ports Tab and check if the Standard TCP/IP Port has IP Address of the printer of some other IP Addressif it is different IP Address than change it to the IP Addess of the printer.
Thanks and Regards.
Apr 27, 2009 | HP LaserJet 4100 Printer
Wireless printer does't work code IP=192.168.2.4
The message is a network adress, most likely for your printer.
Open up Internet Explorer or Firefox and in the address field, type;
192.168.2.4
If it comes up with an error, then your computer is not connecting to your printer correctly.
Dec 11, 2008 | Office Equipment & Supplies
Network Error CE-02
There is a Windows Port that is being blocked. First make sure the IP it's scanning to and IP on the machine are the same. disable the firewall. I'm working on narrowing down the port now and will post as soon as I find it.
-Mike
Oct 31, 2008 | Computers & Internet
Useing Linksys wpsm54g with tcp/ip
that will depend on the IP address of the print-server and the network, specially if the printerver is not set to a static IP, you may get communication errors when you try to use or install the printserver.
you may try to set the PS to have a static IP address or you may use the printserver name instead of its IP address.
use custom settings then use "RAW" after that chnage the queue name to p1 or l1.
there are many work arounds for this kind of limited configuration, but i would strongly suggest you call Linksys Toll Free Tech support for more configuration
Sep 30, 2008 | Linksys WPSM54G Print Server
2nd printer on print server
Hello Kawena66,
There may be an ip conflict as the error suggest.
what is the ip address on your XP system?
Sep 16, 2008 | D-Link DP-G321 Print Server
Connecting Brother MFC 7420 thru Dlink DP301P Print Server to home network with ONLY dynamic addressing
I went and got static IP addresses from internet provider...Must of caught them on a good day
Apr 24, 2008 | Brother MFC 7420 All-In-One Laser Printer
HP C6180 Print Queue Error
click start, click on network, when you see the printer on the network, right click the printer and copy the IP address shown there.
click start, click on printers, right click the printer, click on properties, past the ip address into the location bar, then clikc on ports and make sure the correct IP address is check marked, if not add the corrent one using the add port button,
Apr 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
Samsung SCX-4725FN All-In-One Laser Printer Logo
64 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
