Question about Keurig Elite B40 Coffee Maker
My handle is stuck or jammed and lid won't close
Why is the bottom drawer stuck?
Is this a Fisher Paykel Dishdrawer?
If so, the lid is likely not returning properly to the upmost position.
Caused by faulty lid actuators, easily fixed by replacing them.
Try not to open and close forcefully as it will damage the rubber seal (built into the lid), then you will also have to replace the lid.
May 14, 2014 | Dishwashers
Mazda 3 2010 driver's door locked and won't open
This is what fixed the my car's driver's door that was stuck closed and locked: the plastic piece that function as the manual lock/unlock on the inside of the door (it's black but when the door's unlocked it has a red side facing out) had essentially popped out and everything was jammed. So you push the button back in while you flip the inside handle open. But maybe I was lucky, in that it was only the button that was jammed.
Feb 03, 2013 | 2010 Mazda 3 1.6
1995 Voyager Front passenger door latch stuck - door won't close
insert blade of screwdriver behind cam like piece pull up on handle and push up on cam like piece this should reset the latch
Dec 10, 2012 | 1995 Plymouth Voyager
How to get out the jammed paper
open the unit lid. not just the scanner. in the back you will see a handle that you can pull up. under the that paper cover you'll be able to pull the paper out. replace the cover, close the lid and turn follow directions on the printer screen.
Nov 24, 2012 | HP DeskJet 3520 InkJet Printer
Trunk won't close in 1999 cl500
ck latch may be jammed if ok ck striker latch is in lid striker is in rear panel .
Aug 01, 2012 | Cars & Trucks
Trunk won't open
can you access it from the back seat.? you might have to remove the bench seat and then the back rest to shine flashlight to see if indeed something is jammed in the latch.
Aug 12, 2017 | 2007 Chevrolet Corvette Convertible
Memory card does not get in
make sure you're putting it in the right way round. if you're trying the right way then it will slip in easily, if it's the wrong way it will just jam and the lid won't close
May 12, 2012 | Casio EXILIM EX-FC100 Digital Camera
My Keurig is stuck. The top of the handle won't go in :( it won't close. Stuck open.
Remove the Kcup basket and clean. Rest and strat over. Pull down and reset handle.
Jan 21, 2012 | Keurig Elite B40 Coffee Maker
WF860 Door stuck in closed position.
FIRST switch off and unplug.
Pull machine out and remove lid by undoing self tapping screws at the top back. May have to slide lid back a bit to lift off.
Internal catch mechanism will be reachable from top for manual release. You may need someone to push door inwards while you release catch.
Good luck
Dec 17, 2007 | Hotpoint Ultima WF860 Front Load Washer
Keurig Elite B40 Coffee Maker Logo
660 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
