Question about Gestetner DSM 651 Copier
At first when machine get ready then i place the original in ADF and set start the copy get out and message (please wait) appear on display and machine hung up then i removed NVram and Sdram and sc 672 appear so i ask your help as soon
  • khaled mohammed May 18, 2011
    at the end the probelm has been solved as following steps:
    1-cleaning the earse lamp
    2-cleaning ID sensor
    3-cleaning drum herrnes
    thank you very much and i hope to keep in touch with me
  • 263 Answers
This code is related to a bad communications between the controller and the operation panel.
Could have the following causes:
- Controller installed incorrectly
- Operation panel harness disconnected or defective.
- Controller board defective.
(also check the jumper on the MBU fax unit. It must be set at the ON position)
I give this answer for the SC672 assuming that you know why you remove the NVram...
Posted on Apr 11, 2011
How to store documents from computer to ricoh 3035?
When the machine is printing a
document stored using the copier
function, wait until printing has
finished before you store a document
in the Document Server.
A Press the {Document Server} key.
B Press [Scan Original].
C Enter a file name, user name, or
password if necessary.
Note
- If you do not enter a file name,
one is automatically assigned.
Reference
p.41 "To register or change the
user name"
p.41 "To change the file name"
p.42 "To set or change the password"
D Place originals either on the exposure
glass or in the ADF.
Reference
For information about types of
originals and how to place
them, see Copy Reference.
E Make any required settings.
Reference
For details, see Copy Reference.
F Press the {Start} key.
The document is stored in the Document
Server.
Note
- To stop scanning, press the
{Clear/Stop} key. To restart a
paused scanning job, press [Continue]
in the confirmation display.
To delete saved images
and cancel the job, press [Stop].
-When a password is set, appears
on the left side of the file
name.
- After scanning, stored documents
appear on the Select Files
to Print display. If this display
does not appear, press [Scanning
Finished].
- When placing an original on the
exposure glass, press [Scanning
Finished] after all the originals
have been scanned
To register or change the user name
A Press [Scan Original].
The Scan Original display appears.
B Press [User Name].
If user names are already registered,
the Change User Name display
appears. To use an
unregistered user name, press
[Non-programmed Name].
When no user name are registered
in the Address Book, the User
(Destination) Name entry display
appears.
When using a registered user
name in the Address Book
ASelect a registered user name
from the list, and then press
[OK].
To change your user name to an
unregistered user name, proceed
to the next step.
Reference
p.76 "Registering a New
User Code"
When using an unregistered user
ATo enter an unregistered user
name, press [Non-programmed
Name].
BEnter a new user name, and
then press [OK].
Reference
p.161 "Entering Text"
When no user name has been
registered in the Address Book
AEnter a new user name, and
then press [OK].
Reference
B Press [File Name].
The Change File Name display appears.
C Press [Delete All] to delete the old
file name.
Note
- You can also use [Backspace] to
delete unnecessary characters.
D Enter a new file name, and then
press [OK].
Note
- Up to 20 characters can be entered
as a file name. Note that
only 15 characters of each file
name appear in the document
list.
Reference
B Press [Password].
C Enter a password using the
number keys (four-to eight-digits),
and then press the {#} key.
D Reenter the password (four-to
eight-digits) for verification, and
E Press [OK].
May 22, 2014 | Ricoh Aficio 3045, 3035 Kit
Faxing
How to clear the "Check Original " error message? Description: This error can occur if the document being sent or copied is not inserted properly, fed incorrectly or is too long. Follow the troubleshooting steps and recommendations listed below:
  1. Remove any paper that is not jammed from the ADF.
  2. Open the top cover by lifting the lever on the right side of the top cover.
  3. Pull the original toward the front of your fax machine.
  4. Close the top cover. Press down on both sides of the top cover until it clicks.
jam06.gifBefore placing the document(s) in the Automatic Document Feeder (ADF), verify the error message "CHECK ORIGINAL" no longer is displayed on the LCD. If the error message continues to appear on the display, unplug the unit for 30 seconds and then plug it back in.
Let me know if you need any further help
May 06, 2008 | Brother MFC-8440 All-In-One Laser Printer
Canon_fax_b820_error_342
Do the following procedure 1. Press the buttons in the order of [FUNCTION]- [*] - [5]. 2. [TIME SET HH:MM] is displayed. 3. Current time is displayed following the date [12/12/12 xx.xx]. 4. Press the [START/COPY] button. 5. [DATA SET] is displayed. 6. [CS PRESCAN] is displayed. 7. [INK DETECTOR] is displayed. 8. [PRESS START/COPY] is displayed. 9. Press the [START/COPY] button. 10. [ # TST START:STBY] is displayed. 11. Press the [START/COPY] button. 12. [Please Wait] is displayed. 13. The machine enters the standby mode. 14. Press the [FUNCTION] button and then [#] button to enter the service mode. Execute [All Clear]. 15. [Please Wait] is displayed. 16. The machine enters the standby mode. 17. [LANGUAGE] is displayed. 18. Press the [START/COPY] button. 19. Select the language. 20. Press the [START/COPY] button. 21. [DATA ENTRY OK] is displayed. 22. [COUNTRY SELECT] is displayed. 22. Press the [START/COPY] button. 24. Select the country. (If country of your choice does not appear, turn the machine OFF and then ON. Press the [FUNCTION] button and then [#] button to enter the service mode. Select the country from the [Type Setting].) 25. Press the [START/COPY] button. 26. [DATA ENTRY OK] is displayed. 27. The machine enters the standby mode. 28. Press the [FUNCTION] button to set the date and time. If your problem not solved replace the SCNT PCB
May 01, 2011 | Canon FAX-B820 Plain Paper Bubblejet
I bought a new photocopier, i plug it the power supply but when i tried to make some copies i failed. I asking if there are some settinng required. Name:Sharp AR-5518
to make acopy you have to load the paper on the cassette and install a new ink cartridge. and you need to place the original on ADF or on the glass and press the start botton if you are unable to make a copy please read the lcd for the or message displayed.
Dec 24, 2010 | Sharp AR-M237 Copier
I've got a new hp m2727nf laserjet (3 weeks old), and an error message "ADF door is open" appears in the product display. I have turned off and unplugged the power several times, I've removed the adf and...
From HP's web-site:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3377075&prodTypeId=18972&prodSeriesId=3377075&objectID=c01236058
Make sure that the ADF lid is closed.
Remove the ADF and reinstall it.
If the message persists, turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If the error persists, contact HP. See www.hp.com/support/LJM2727 or the support flyer that came in the product box.
Dec 05, 2009 | Computers & Internet
How to do copies,ie what buttons do i press
Making a Single Copy
Place the original face down in the ADF.
2 Press Copy/Help twice.
To cancel, press Stop.
Do NOT pull on the paper while copying is in progress.
Copy Options: Single or Multiple Copies,
Reduce/Enlarge, Sort/Stack
You can choose additional copy options. First, you can select the number of copies. Next, you can
choose whether multiple copies will be STACKED (all copies of page 1, then all copies of page 2, etc.)
or SORTED (collated). Finally, you can choose an enlargement or reduction ratio. To automatically
reduce the copy to the paper size you have set for the paper tray, select AUTO. To reduce the copy by
a fixed percentage, choose 93%, 87%, 75% or 50%. Or, to enlarge the copy, select 150%, 125% or
120%. To copy a document at its original size, select 100%.
1 Place the original face down in the ADF.
2 Press Copy/Help.
3 Enter the number of copies you want (1-99).
For example: Press 9 for nine copies.
To start copying now, press Copy/Help.
If you would like to select additional copy options, like
SORT, ENLARGE or REDUCE, press Menu/Set.
Oct 02, 2009 | Brother FAX-T74 Plain Paper Thermal...
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hello, I have an HP OfficeJet 7310 all-in-one print/scanner/fax etc. I purchased about two years ago but don't use very often. Yesterday while I was trying to send a fax I received a loud winding-up...
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
Apr 12, 2008 | Office Equipment & Supplies
Print Qualityfor DC12
I am not 100 percent what you are asking but I will answer the best I can with your question.
  1. Press the [Administration] button located above the numeric keypad on the Control Panel. The Administration button has a wrench symbol located above it. The Access screen will be displayed.
  2. Select [Tools] on the Touch Screen. The Tools Access Number screen will be displayed.
  3. Enter your numeric password using the keypad.
    NOTE: If you do not know the password, contact your administrator. The initial password at machine install is 11111.
    If the administrator encounters a problem with changing or forgetting the machine password, a service call must be placed:
  4. Select [Enter] on the Touch Screen. The Tools screen will be displayed.
  5. Select [System Image Quality]. The System Image Quality screen will be displayed.
  6. Select [Image Recognition]. The Image Recognition screen will be displayed.
  7. Select 'Screening Adjustment' by selecting the [Up] or [Down] arrow buttons.
  8. Select [Change Settings]. The Screening Adjustment screen will be displayed.
  9. Select [Apply to Copies Only] then select [Save]. The Screening Adjustment screen will be displayed.
  10. Select [Close]. The System Image Quality screen will be displayed.
  11. Select [Auto Screening Adjust]. The Auto Screening Adjust screen will be displayed.
  12. Select [Halftone Screen]. The Halftone Screen will be displayed.
  13. Select either [Halftone 200 line screen] or [Photograph 200 dpi].
    NOTE: Do not select 'Printer use' as this will effect print calibration; which will be handled directly by the color server set up to print to the copier / printer.
  14. Select [Save]. The Auto Screening Adjust screen will be displayed.
  15. Insert at least 2 sheets of white, 216 mm x 279 mm (Letter, 8.5 x 11 inch) paper in Paper Tray 5 (Bypass Tray).
  16. Select [Print Test Original] to print a sample of the settings. The message 'Please wait…Printing test original' will be displayed and the test original will print.
    NOTE: If selecting [Print Test Original] displays the message ‘System Disabled' then Screening Adjustment is disabled. Select [Close] and repeat steps 5 to 16.
  17. Open the Document Glass Cover.
  18. Place the test original face-down on the Document Glass with the two magenta squares against the left edge of the glass.
  19. Place 5 sheets of blank white paper directly on top of the test original.
  20. Close the Document Glass Cover.
  21. Select [Start Adjustment] from the Touch Screen. The message 'Please wait….Adjustment in progress' will be displayed, then the Auto Screening Adjust screen will be displayed.
  22. Select [Adjustment Complete]. The message 'Please wait…Printing current settings' will be displayed and the adjusted original will be printed.
  23. Examine the adjusted original to make sure the image quality is satisfactory and continue to the next step. If the image quality is not satisfactory repeat steps 12 through 22.
  24. Select [Close]. The System Image Quality screen will be displayed.
  25. Select [Close]. The Tools screen will be displayed.
  26. Select [Close]. The default copy screen will be displayed
Dec 27, 2007 | Xerox DocuColor 12 Printer
Gestetner DSM 651 Copier Logo
364 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
