Question about HP F4480 All-In-One Printer
The printer says connected to the system, but there is a red light blinking always. Printing does not happen because it says "printer offline" Please help.
Try going into the print job queue (open the printers folder and double click on the printer). On the upper left of the print job window, click Printer, and in the dropdown box, if Use Printer Offline is checked, click it to uncheck it. Then try again by clicking on the print job and under Document, click Restart.
Posted on Apr 11, 2011
Zebra gx 430t printer when I turn it on the light is blinking green/red
Do a factory reset on the printer.
Check you printer driver settings if you are printing using it.
Jan 14, 2016 | Zebra GX430t Thermal Printer
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
No action is necessary.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
Aug 01, 2011 | HP LaserJet 1020 Printer
Please help with the following: Printer BIXOLON SRP 350 IG When I turn it on Power light: Green Error light: Red Paper light: Red The printer "beep ... beep" continously
Looks like you'll have to contact Samsung http://www.samsungminiprinters.com
The operators manual does not give any indication about what to look for if the error light is on.
Here's what the manual states about the paper light:
This light indicates the near end of the paper roll. Install a new paper roll and the printer will continue printing. When the light blinks, it indicates the self-test printing standby state or macro execution Standby state when the macro execution command is used.
Jul 18, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
It doesn' t work, only I turned on and tryed to print a doc. and nothing happens what can I do?
Any error messages/ red or blinking lights? Is the printer connected? Try a new data cable and a direct connection if using a print server or USB hub. Make sure that the USB ports work for a known working device. What does the printer status indicate on the computer? Are any files stuck in the queue (spooler)? Sometimes items stuck in the spooler will be cleared if you reboot or disable and then restart the spooler. (In Windows, you can do this at the command prompt (Run as Administrator on Vista or Win7). Type "net stop spooler" without the quotes and then hit Enter. At the next prompt, type "net start spooler" again without the quotes followed by Enter. When the command completes, reboot the computer. Try printing after the restart.)
I hope this helps.
(blinking lights and error messages will depend on the actual message; one issue can be "waste ink tank full". This is noted by a usage counter not when the tank is actually full. You can actually rinse the pads and blot up the waste ink and reassemble the printer then do a counter reset. However, it isn't always worth it. The counter is based on the estimated life expectancy of the printer and additional failures may occur soon. The Epson reset utility that I'm aware of is downloaded from Epson.com after entering your printer's serial number and other information to prove it is your printer.)
Jul 23, 2010 | Epson Stylus CX5700F All-In-One InkJet...
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
Red qoutation light keeps blinking/a440 print dock
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Office Equipment & Supplies
Both red lights on my printer are blinking
Blinking wit general error message : head carriage error. It cause by head cannot move to parking position or chip at ink tank not good connected. Try to use another chip. Just turn off printer for a moment for clearing epprom.
Nov 09, 2008 | Epson Stylus C83 InkJet Printer
Red light blinking and not printing.
hi there... whats ur printer model? maybe it has no ink already that's why it is not printing... and usualy if red light is blinking your ink is already empty....
Feb 26, 2008 | Ithaca iTherm 280 Thermal Printer
Blinking light -no connection
reinstall your printer drivers
Sep 02, 2007 | Lexmark Z600 InkJet Printer
HP F4480 All-In-One Printer Logo
213 people viewed this question
Seeker5211
Seeker5211
