Question about Garden
My lawn tractor dies out once you ingage the deck or put in gear.
    Brigadier General:
  • 3,911 Answers
I would look into two possibilities:
1) a bad safety switch or safety switch relay is killing the engine when you let off the clutch
2) a set of bent push rods on one cylinder keeps it from doing any work, sounds OK with one cylinder running but has no power. common on B&S engines
Posted on Apr 11, 2011
Blades wont ingage on my craftsman lawn tractor #917.274811?
After hitting a tree root, blades will not cut when I press to engage
Aug 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Want to download manual for craftman 42' 17hp briggs&stratton motor
Hi My Craftsman will not ingage into gear . is the cklutch and transmission one unit . is this an easy fix. Jim
Jul 11, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I took off the rear wheel to put air in it and have it poped back on the rim since replaceing the wheel the tractor will not ingage in to foward or reverce gear . is there some trick to this
Often there is a keyway in the axle corresponding to another on the inside of the rim hub. Did you check this and make sure the key is there. If the key is gone the axle's turning will not spin the tire.
Jun 07, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
42 in. Deck 19.5hp Lawn Tractor: Craftsman Lawn tractor my engine clicks but will n...
battery has a low charge or the starting gear on the starter is bad. just remove cover and see if the starter ingages and cranks the fly wheel. look at the gear itself to make sure the teeth are good ,if not replace the plastic gear. takes 5 min.
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
