Question about Kenmore 98702 Stacked Washer/Dryer
Clothes-snagging dryer The kenmore stacked washer/dryer in my apartment is destroying some items; specifically, it catches threads all over the items, puckering and snagging it.  So far, those items include bed sheets and pillow cases, a temperpedic mattress cover, and two underarmor shirts.  All of these items were brand-new and were ruined on the first wash; all were are marked as being OK to go in a dryer; all of these items were laundered in reasonably-sized loads without anything (like zippers or hooks) that could have caused the damage.  I believe the problem is with the dryer and not the washer because the items were fine when I moved them from the washer to the dryer. The apartment maintenance personnel looked inside the dryer and could not see or feel any sharp edges.  This was the extent of their inspection.  I am hoping that someone can give me a lead so that I can help them fix this to my satisfaction.  I appreciate any speculation offered.
  • apiary4 Aug 07, 2008
    ok, I rechecked for sharp edges and still can't find any.
    I did feel and look at the felt seals. They crumble into pieces when touched, but I don't feel anything sharp underneath/around them.
    Are bad felt seals without sharp edged enough to cause problems? Are the clothes, do you think, getting stuck in the space the seal is supposed to fill?
    Champion:
  • 210 Answers
First check for any sharp edges, look inside around back and front of drum the felt seals could be bad.
Posted on Aug 07, 2008
  • without a good seal its possible for clothes to get caught. be careful, there are some very sharp edges on dryers.
SOURCE:
Model 41798702891 Kenmore stacked washer/dryer is collecting lint inside the door and putting lint onto the clothes.
I am not much of an expert with dryers but i'll give it a stab. Should there be a filter that catches the lint so that it does not go all over the clothes? Have you got the manual. If not, see if you can find the manual online and see if there is anything mentioned about a lint filter.
Dec 14, 2013 | Kenmore 98702 Stacked Washer/Dryer
The hard plastic ring inside my Kenmore dryer has broken and it snags and catches clothes, can I remove this piece ?
You can remove but you need to replace the part or unit will get worse.Your clothes will start getting stuck
Sep 04, 2013 | Kenmore Dryers
Auto dry not working on stack washer/dryer
If your dryer isn't drying, check for a simple fix first. Make sure the dryer is set on a high heat setting, empty the lint filter, and reduce the size of the load by taking out some items.
Also, check to make sure the clothes are not dripping when you put them in the dryer and make sure a dryer sheet is not blocking the vent.
It could also be a problem with your dryer not being level or the vent hose is clogged. For more tips and solutions, check out these troubleshooting steps in Dryer not drying.
Sep 12, 2012 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stack dryer burns clothes
HI CAROMIA.unusual but check basics first1-dont overfill 2-no sintetics and nylons.if still burns its obviously overheating.3-check vents.hope this helps.ali
Jun 20, 2012 | Kenmore Dryers
The FEX831CS combo is destroying my clothes
change your front slides on the dryer this a common problem with frigidaire
Dec 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryer won't spin on my kenmore stacked model 417.90812991
This is the 2nd time I have this problem.
IF you look thry the drum to the back you should see 3 screw heads. Mine has one screw still in the hole and 2 empty holes.
This requires the drum to be removed (like take the drier apart). Behind the drum is Asmbly-shaft (ball hitch) (item 32 in the parts list). This what the 3 screws screw into.
I spent 2 days trying to put the screws in without removing the drum not possible (no way to hold the drum in place)
The first time I had to replace the drum because it wore the rim through.
I have to get 3 new screws and some thread locker.
I recommend that you check the screws every month, Use a long phillips screw drive
Nov 02, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Kenmore Model 94812301 Stackable Washer/Dryer
try adjusting the feet on the bottom. apart from that the bearings may need replacing.
Sep 01, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Washer Creates holes in clothes
We purchace a washer and dryer in Dec 08 Kenmore HE energy star. They started destroying cloth about 2 months after purchace.
under our warranty and many many calls they sent a new set. 2 months later same problem. HELP
Nov 12, 2007 | Kenmore 98702 Stacked Washer/Dryer
Snaged clothes
Check the lint trap on the dryer. We had the same problem and it was because we put the lent trap in backwards.
May 01, 2007 | Kenmore 94802 Front Load Stacked Washer /...
Kenmore 98702 Stacked Washer/Dryer Logo
856 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
