Question about Sears Craftsman 17 In 27 Amps Extended Reach Hedge Trimmer
Hedge trimmer hard to start .also when running it stop often.
    Guru:
  • 479 Answers
Have a look at these engine starting tips:
http://www.fixya.com/support/r9200607-problem_starting_hedgetrimmer
Posted on May 13, 2011
Electric hedge trimmer want run why?
electric hedge trimmers have 2 switches to press before it runs
one is the trigger that you pull and the other is in the handle that you hold in your left hand
both have to be on before it starts
it is a safety feature to stop operators cutting off their fingers
Jun 09, 2016 | Little Wonder 2230S 30 Single Side Hedge...
I have a petrol hedge trimmer TRY26PHTA. The engine will start fine but the blades will not move
If the engine starts 'fine" then it has not seized.
Many, if not most, hedge trimmers are , for safety, equipped with a "CENTRIFUGAL CLUTCH" between the engine and the blade to prevent blade operation unless the engine is at full RPM.
IF your machine is so equipped, it's possible that the clutch is worn and slipping so badly that the blade can't move.
Jun 11, 2014 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Hedge trimmer does not stay on
Will it start & run OK, does it stop after it gets hot then will restart & run again when it cools untill it warms up then stops again,it yes it can be a bad coil,I had this problem on a leaf blower.sometimes just testing for spark won't help you out it may still have spark but the electronics inside the coil that controls spark timing goes bad you could still have spark but it's out of time so the engine still won't run if you suspect this problem change the coil,bad coils can also make them hard to start.good luck
Mar 06, 2014 | Weedeater Gas Powered Hedgetrimmer...
Stihl fs80 hard to start and will not run at power
I would check the spark arrestor screen in the muffler. They are known for plugging up and causing serious running problems.
Aug 15, 2010 | Oregon Scientific Complete Carburetor for...
Once my excalibur hedge trimmer runs out of gas it is hard to start again
firstly dont let it run out of gas
secondly if it does run out totally air can get into the system so it can be as u have found a nightmare to start
Jul 25, 2010 | Garden
Trimmer starts and runs for 15 seconds and stops. won't start for a few minutes and does the same ,
Check the air filter, replace the fuel if it is last year's, clean the spark plug or replace. Also lube the blade. Good luck...Lee
Jul 14, 2010 | Craftsman 22" Gas Hedge Trimmer
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Remington Axcess hedge trimmer wont run at all.
Check your fuel lines. It is probably getting air into the system. Also check inside the gas tank to make sure the fuel pick up line is still attached.
If you need more assistance please provide an exact model number and I can better help you.
Kelly
May 10, 2009 | Remington Factory Reconditioned 17-Inch...
Sears Craftsman 17 In 27 Amps Extended Reach Hedge Trimmer Logo
151 people viewed this question
Top Sears Garden Experts
Tim Whalen
John M Grubb Sr
Superior Maintenance
Are you a Sears Garden Expert? Answer questions, earn points and help others
