Question about Whirlpool Refrigerators
Whirlpool ET1CHMXKQ04 Refrigerator: I have a major defrosting problem at the back side of my top freezer. The freezer is not effectively cooling. The temperature in the refrigerator is working overtime to stay between 35 to 45 F. I would like to fix this myself. Can you help me?
  • 5,370 Answers
Its the defrost problem.You are correct, its defrosting problem.
. First try manual defrost reset procedure. The procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. ------------ The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. --------------
In your case, the compressor starts, then cools the freezer, but when its time to defrost, its not defrosting and over ice is getting collected on the evaporator coil and this blocks the fan, so the cool air is not passing from freezer to fridge ands all gets remain in freezer.This is causing the problem-------- So first try manual defrost reset procedure, which i have mentioned above and see, if the unit gets resets and works properly.But if same problem is noticed, then its defrost problem. ----------
If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.-----------
This should help.Thanks.Helpmech.
Posted on Apr 11, 2011
Water is leaking in side refrig,
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 14, 2011 | Whirlpool ER6AHKXPQ Top Freezer...
All of a sudden, water started comming from the freezer. Seems the freezer stopped (refrigerator) cooling/ What do you think is the problem, and is it a major situation. ????
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 24, 2010 | Whirlpool GS6NBEXR Side by Side...
I have condensation on the top in side of my frige that drips down and soaks my food
heatman101
Oct 19, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
My side by side whirlpool refrigerator is icing up on the back wall of the freezer and the refrigerator side is not getting cold enough. I think it is the defroster what do I do to find out. I think the...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 08, 2010 | Whirlpool Refrigerators
Refrigerator is not cooling but light is on.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Jul 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
the first one sounds like it is slowly leaking freon.
  •  the second Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
134 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
