Question about Marshall Amplification Marshall Footswitch for MG100HDFX and MG250DFX
I have a Marshall channel/dfx footswitch. The jack plug has been chopped off leaving me with a red, blue and yellow wire. Can you tell me where each one is soldered to on a replacement stereo jack plug? Thanks so much
  • Marshall Amp... Master
  • 5,603 Answers
NEVER trust colors... with an ohmmeter you can tell which is the common lead by testing... find the lead that has continuity to EITHER switch independently... It is PROBABLY the blue one... this will be the "sleeve" of the plug. The schematic documentation is so bad the jack wiring cannot be decipered as to which contact is the tip and the ring. HOWEVER once you find the common of the switches and connect it to the sleeve you have only two choices for the other wires so just try them.
You can also take the back off the pedal to find which color goes to BOTH the switches... connect that one to the sleeve. Try the other two wires for proper operation before final soldering.
Posted on Apr 11, 2011
Testimonial: "Great, I'll give that a try now. Thank you so much."
    New Friend:
TRS: Tip - red, Ring - blue, Sleeve - yellow
Posted on Feb 24, 2013
Bought amp with no footswitch
The schematic shows it as a standard 1/4 inch stereo plug. Wire the ground common to both switches (Channel and DFX), the ring to one switch and the tip to the other...I.E. ground (sleeve) to ring for one switch and ground to tip for the other. You'll have to experiment with which switch operates what function and label them accordingly.
Nov 02, 2012 | Marshall MG100HDFX 100-Watt Amplifier Head
MARSHALL FOOTSWITCH FOR DSL100 TROUBLES
Does your M foot switch work on the Fender? If you know how to use a multimeter you could check continuity by putting meter leads on plug of M foot switch(1 on tip, 1 on sleeve ) You should see a change in the multi meter when you depress switch. If so switch is good. Another easy test is with cap off a spare 1/4 plug -plug it in to foot switch jack.put a alligator or some such metal clip or wire and join(called short or shorting) the two inputs . If connecting and unconnecting results in switching then the foot switch is suspect. One fairly common thing is that foot switch and input jack are often sautered straight to a circuit board to save $ on production cost. Used to be all point to point where a wire was attached to 1/4" input and then wire went to circuit board or tubes. The wire has give, but not so with direct wiring to board. So the nut holding the 1/4" amp input gets loose(doesn't have to be loose for the following to happen) and a pull on the chord causes a break in the soldier and thus a break in the sound chain. Sometimes it will work intermittingly by putting a little pressure left, right, up or down on the plugged in plug. If so, it's the input jacks connection to the amp. If not it still could be that because putting pressure on plug may not be sufficient to affect a temporary reconnection. Since switch(the new one you made)works on Fender, but not Marshall I suspect the jack or foot switch circuitry past the input jack. If using some of the above the above tests leads you that direction,remove housing(unplug a/c power 1st ) inspect jack,wiggle it slightly see or feel a break then resodier from back side. You should be able to use the soldier already present without adding extra.
Sep 27, 2017 | Music
Marshall AVT 100 dfx doesn;t work
junn561,
Thank you for asking me directly to help you with your problem. However, either the question you are asking is not within my area of expertise (I am an automotive repair technician), or the question is incomplete and does not contain enough information for me to help you.
Dec 11, 2011 | Music
How to connect the foot switch.
Using the CORRECT footswitch for this model, you just plug it into the footswitch jack. You MUST use the correct one for the model.
Aug 05, 2011 | Marshall Amplification Marshall MG50FX 50...
When I plug my P803 2 Way footswitch into my Haze40 amp the effects light flashes and the footswitch will not change channels or effects.
The P803 is designed to work with the "Valvestate" and Tube amps. I don't think it is compatible with the Haze40 since they have an optional 4 button footswitch so the optional one would necessitate different interface than the P803.
Jun 02, 2011 | Marshall Amplification Marshall P803 2-Way...
My clean channel wont turn on. Light just stays red on distortion.
Insufficent information !!! Are you controlling this by the footswitch or the onboard switch? If the onboard switch and you HAVE at some point used the footswitch, likely the contact on the footswitch jack has failed that transfers control to the internal switch. If you haven't tried the footswitch see if that has control. I can send you the link to the schematics if you know how to read them. Here they are:
http://elektrotanya.com/marshall_mg250dfx.pdf/download.html
Scroll down to the little link that says "Get Manual" and click on it to download.
Apr 15, 2011 | Marshall Amplification Marshall MG250DFX...
I have a marshall JCM 900 when I plug in my foot switch and try to play it pops and cracks .I know it's not the foot switch or my guitar.I checked the tubes they look alright so what part is broke in my...
I doubt that you have checked the tubes... tube checker's are rarity now and you can't look at a tube and "tell it is alright". If you leave the footswitch out does it do the same thing?
The probllem could be many things...and you haven't mentioned how you tested the items you are exhonorating. A common problem is a noisy or broken INPUT jack. Musicians forget to loop the guitar cord through the handle and the cord gets moved and yanked sideways wearing the jack and often breaking internal parts. Yjos also goes for the cord to the footswitch as well. Cords and connectors/jacks are the common problems. Less common but frequent are damaged volume control pots due to damage when handling... including broken solder where these attach to the circuit boards.
Feb 11, 2011 | Marshall Amplification Marshall JCM800...
I seem to have the wrong cord on my footswitch as the female end on my amp is one of those computer types, How can i get around this?
The footswitch should be a 1/4 inch stereo type (TRS) plug to fit the footswitch jack of the MG250FX. It is a three wire connection.
Jan 06, 2011 | Marshall Amplification Marshall MG250DFX...
Howdy. I need to replace the jack plug on my PED802. can you tell me exactly what type jack plug is required and what pins to solder the red, yellow and blue wires to? Much appreciated, thank...
The plug is a 1/4 inch STEREO type plug. Readily available at Radio Shack and many online sources. It will have three connections commonly known as TRS (Tip-Ring_Sleeve).
Dec 29, 2010 | Marshall Amplification Marshall PED802...
The dfx doesn't switch off with either the foot switch or the front panel switch
http://www.ampix.org/albums/userpics/10003/MArshall_MG100DFX.pdf Heres the schematic. Check the footswitch jack for bad solder joints to the board. If the channel indicator isn't lighting up check for 5 volts at R38 and R39. If you have no experience with troubleshooting I wouldn't recommend working on the amp unless you learn more about the subject. To start do not work on the amp while it is powered up as the capacitors store a lethal charge and even if you don't get hurt it is easy to damage components via a short circuit. I hope some of this helps.
Aug 04, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall Amplification Marshall Footswitch for MG100HDFX and MG250DFX Logo
1,174 people viewed this question
Top Marshall Amplification Music Experts
Michial Gueffroy
matt martin
matt martin
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
