Question about Stairmaster 7000PT Nautilus Stepmill
Steps freely continue. No change when selecting up or down to free movement of steps. Is this transmission or motor?
Check alt. brushes
Posted on Jun 05, 2012
Hp officejet 4500 will not print from mac ibook g4
HP Officejet 4500 (G510) Series and 4500 (K710) Series All-in-One Printers - The All-in-One Does Not Pick Up or Feed Paper Issue The product does not pick up or feed paper from the paper tray. How to use the solutions in this document To resolve the issue, try each solution in this document in the order presented. c01733891.gif IMPORTANT : Each time you try a solution, try to print a self-test report to determine if the hardware is functioning correctly. To print a self-test report, use the steps in the following table. How to print a self-test report
  1. Load plain, white paper in the paper tray.
  2. Press and hold the Cancel button (c01235250.gif ) on the product control panel.
  3. While holding the Cancel button (c01235250.gif ), press the OK button (c01961874.gif ). The self-test report prints.
NOTE: Refer back to the steps in this table after attempting each solution. Solution one: Reset the All-in-One
  1. Disconnect the power cord from the back of the product.
  2. Wait 30 seconds.
  3. Reconnect the power cord to the back of the product.
  4. Press the Power button (c01602202.gif ) to turn on the product.
  5. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue , and the test page prints , there is no need to continue troubleshooting.
  • If the issue persists , continue with the next solution.
  • If the test page does not print , continue with the next solution.
Solution two: Check the paper The condition of the paper or the amount of paper loaded might prevent the rollers from picking it up and feeding it through the product. Use the following steps to check the paper in the input tray.
  1. Remove any wrinkled or damaged paper from the input tray.
  2. Make sure that all the paper is the same size and type.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper contains from 10 to 25 sheets of paper.
    NOTE: Do not overload the input tray. Make sure the stack of paper is shorter than the top of the paper width guide.
  5. Insert the stack of paper into the product, and then gently push the paper width guide snugly against the paper. Figure 1: Load paper c01970609.gif 1 - Load paper 2 - Adjust the paper width guide Illustration of loading paper and adjusting the paper width guide
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Solution three: Check the print settings The paper settings in the print driver must match the paper size and type loaded in the product. Use the following instructions to adjust the paper settings.
  1. In the software program you are printing from, click File .
  2. Click Print , and then click Setup , Properties , or Preferences .
    NOTE: The specific options might vary depending on the software program.
  3. Click the Features tab.
  4. In the Basic Options pane, select More from the Paper sizes drop-down list.
  5. Select the size of paper loaded in the product, and then click OK .
  6. In the Basic Options pane, select More from the Paper type drop-down list.
  7. Select the type of paper that you loaded, and then click OK .
    NOTE: These changes do not change the default print settings. The print settings revert to the default settings the next time you open the program.
  8. Change any other print settings necessary, and then click OK .
  9. Click OK to print.
  10. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Solution four: Clean the rollers Follow these steps to clean the rear rollers and the pick rollers on the HP product. Step One: Clean the rear rollers
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the rear of the product.
  3. Remove the rear access door. Press in the tab on the left side of the door, and then pull the door away from the product. Figure 2: Remove the rear access door c01961876.gif Remove the rear access door
  4. Lightly moisten a lint-free cloth with distilled or bottled water, and then wipe the paper rollers. Rotate the rollers with your fingers to clean all the way around. Figure 3: Clean the rollers c00246512.jpg Graphic: Showing paper rollers
  5. Make sure that the paper feed rollers on the rear access door are clean, free of paper bits, and rotate freely. Figure 4: Access door rollers c01590938.gif Access door rollers
  6. Allow the rollers to dry completely.
  7. Reattach the rear access door. Push the door forward until it snaps into place.
Step two: Clean the pick roller
  1. Remove any paper from the paper tray.
  2. Remove the rear access door. Press in the tab on the left side of the door, and then pull the door away from the product. Figure 5: Remove the rear access door c01961876.gif Remove the rear access door Figure 6: Rear rollers and location of pick roller c01976220.gif Image: Rear rollers and location of pick roller
  3. Lightly moisten a lint-free cloth with distilled or bottled water, and then wipe the pick roller. Rotate the pick roller upward with your fingers to clean all the way around. Figure 7: Pick roller c01975068.gif Image: Pick roller in the product
  4. Make sure that the pick roller and the rollers around it are clean, free of paper bits, and rotate freely.
  5. Allow the pick roller to dry completely.
  6. Reattach the rear access door. Push the door forward until it snaps into place.
  7. Load the tray with plain white paper.
  8. Reconnect the power cord to the rear of the product.
  9. Press the Power button (c01602202.gif ) to turn on the product.
Solution five: Service the All-in-One
Mar 06, 2013 | HP Officejet 4500 All-in-One Printer G510G
Service engine light is on the p0741 code poped up on 2002 grand prix se
Hi there:DTC P0741 - Torque Converter Clutch (TCC) Excessive Slip, Transaxle Chuggle, Slip/Surge (Inspect and/or Replace Various Internal Transaxle Components
There is some service info, that may very well be your problem. here is the info...
Subject: Incorrect Transmission Shifts, Poor Engine Performance, Harsh 1-2 Upshifts, Slips 1ST and Reverse, Torque Converter Clutch (TCC) Stuck Off/On, DTCs P0730, P0756, P0757, P0741, P0742 (Clean Transaxle Valve Body and Case Oil Passages of Debris)
Models: 2001-2005 GM Passenger Cars with 4T65-E Automatic Transmission
2001-2005 Buick Rendezvous
2005 Buick Terraza
2001-2004 Chevrolet Venture
2005 Chevrolet Uplander
2001-2004 Oldsmobile Silhouette
2001-2005 Pontiac Aztek, Montana
2005 Saturn Relay
with 4T65-E Transmission (RPOs M15, MN3, MN7, M76)
Some owners may comment on any one or more of the following conditions:
* The SES lamp is illuminated.
* The transmission slips.
* The transmission does not shift correctly, is very difficult to get the vehicle to start moving or the engine lacks the power to move the vehicle.
* Poor engine performance.
Cause
The most likely cause of the various conditions may be chips or debris:
* All years--Pressure Reg. Valve (Bore 1) or Torque Signal Valve (Bore 4) stuck.
* On 2001-2002 vehicles, a plugged orifice on the case side of the spacer plate.
* On 2003-2005 vehicles, restricted movement of the 2-3 shift valves in the valve body.
* On 2003-2005 vehicles, restricted movement of the 3-4 shift valves in the valve body.
Technician Diagnosis and Correction
* The technician's road test reveals the vehicle launches in third or fourth gear (high RPM with slow vehicle acceleration).
* On 2001-2002 vehicles, a DTC P0756 or P0757 may be stored.
* On 2003-2005 vehicles, a DTC P0730, P0741, P0748 or P0757 may be stored.
* Refer to the appropriate Service Information (SI) for additional Diagnostic Assistance.
* With a Tech 2 connected to the vehicle, road test the vehicle and perform the following steps:
If the above symptoms are present proceed with the following steps.
With the valve body removed and on a workbench, carefully push the valve against spring pressure to check if the valve will snap back to the original position. Or for the valves seated in home position, use a small flat-bladed screwdriver and carefully pry the valve off its seat, quickly remove the screwdriver allowing the valve to return to its seat. If the valve does not snap back unencumbered, then the valve will need to be removed from the valve body.
Once the valve is removed, inspect for any scratching or scoring.
If any scratching or scoring is found, then the fingernail test will need to be performed.
Important: It has been found that in most cases that the scratches are not severe enough to catch your fingernail.
Using your fingernail, move over any scratches to see if your nail will catch on the scratch or score.
* If your nail catches in the scratches, the valve will need to be replaced.
* If your nail does not catch in the scratches, continue with the next step.
Important: Clean the valve body with the machined side down so debris may escape.
Clean the valve and bore using brake cleaner.
Blow off with shop air.
To verify free movement of the valve, dip the valve into clean ATF and install the valve back into the appropriate bore. The valve should move freely. If the valve moves freely, in most cases the valve body will function properly when reinstalled.
Reassemble and retest .
(1)Bore 1, Pressure Regulator (Reverse Boost Valve inside bushing)(2)Bore 2, 1-2 Shift Valve, Solenoid "A"(4)Bore 4, Torque Signal Valve, Pressure Control Solenoid(5)Bore 5, Pressure Relief Valve(6)Bore 6, PWM and TCC Control Valve(7)Bore 7, TCC Regulator Apply Valve(11) Bore 11, 3-4 Shift Valve, 4-3 Manual Down Shift Valve(12) Bore 12, 2-3 Shift Valve, 3-2 Manual Down Shift Valve(14) Bore 14, Secondary 1-2 Accumulator Valve(15) Bore 15, 2-3 Accumulator Valve, 3-4 Accumulator Valve(16) Bore 16, Solenoid "B"
Hope this helps.
Mar 04, 2013 | 2002 Pontiac Grand Prix
One blade seems to jam even after i free it up
Put a wood broomstick down in the opening, or use allen wrench on bottom of motor, and see if you can free up the cutter disk.
You want the disk to rotate freely.
Then use vacuum cleaner hose to make sure all the small stuff is removed.
If the disk rotates freely, but continues to jam, then you probably need to replace disposal.
I wrote ez disposal replacement steps from when I worked apartment maintenance.
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jul 06, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Got F 50 code on Whirlpoos Cabrio wash machine. Tub spins, nothing under agitator, replaced control board, nows blows breaker.
F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation.
Does basket turn freely? If not, make sure bottom shipping pack has been removed. Determine cause of friction.
If basket turns freely,perform the test below..
This test checks the wiring to the motor and rotor position sensor; and the motor and rotor position sensor themselves. NOTE: Drain water from tub.
  1. See Activation of Manual Diagnostic Test Mode, and check the motor and electrical connections by performing the Agitate and Spin tests under Manual: Motor. The following steps assumes that this stepfailed.
  2. Unplug washer or disconnect power.
  3. Check to see if basket will turn freely. If basket turns freely, go to step 4. If basket does not turn freely, determine what is causing the mechanical friction or lock up.
  4. Remove the console to access the machine/ motor control assembly. See Accessing& Removing the Electronic Assemblies.
  5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6.If visual checks fail, reconnect P5 and P10 and repeat step 1.
  6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7. If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to step 7.
  7. Tilt machine forward to access the bottom of the machine and the drive motor area. Remove the motor bolt, then the motor cover to access the motor connections. S
  8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9. If visual check fails, reconnect the electrical connections, reassemble stator and motor cover and repeat step 1.
  9. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector If there is continuity, go to step 11. If there is no continuity, replace the lower machine harness.
  10. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector. If there is continuity, replace the drive motor. If there is no continuity, replace the lower machine harness.
  11. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test in step 1 to verify repair.
  12. If the Diagnostics motor test in step 1 failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Motor Diagnostics in step 1 to verify repai
Dec 04, 2010 | Whirlpool WTW6200S Top Load Washer
Code f50 is what?
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Motor Circuit
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range shown in the wiring diagram on page 7-1.
step 7.
7. Tilt machine forward to access the bottom of the machine and the drive motor area. See Figure 1 on page 6-13. Remove the motor bolt, then the motor cover to access the motor connections. See Figure 2 on page 6-13.
9. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector. See Figures 2 and 4, pages 6-13 and 6-16. If there is continuity, go to step 11. If there is no continuity, replace the lower machine harness.
12. If the Diagnostics motor test in step 1 failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Motor Diagnostics in step 1 to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What is code F 51
Hi
Thanks for using FixYa and I am sorry to hear whatever happened. Error
F 51 flashes when there is a motor rotor position sensor (RPS) failure. Please follow the step by step instructions to resolve this issue: This test checks the wiring to the motor and rotor position sensor; and the motor and rotor position sensor themselves. NOTE: Drain water from tub.
1. See Activation of Manual Diagnostic Test Mode, and check the motor and electrical connections by performing the Agitate and Spin tests under Manual: Motor. The following steps assumes that this step failed.
5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6. If visual checks fail, reconnect P5 and P10 and repeat step 1.
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range. If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to step 7.
8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9. If visual check fails, reconnect the electrical connections, reassemble stator and motor cover and repeat step 1. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector. If there is continuity, go to step 11. If there is no continuity, replace the lower machine harness.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does F51 mean? This comes up on screen. Also leaks from the bottom.
Hi
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 26, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F 51 error code what does this mean
Hi
Thanks
Rylee
Aug 23, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Code Error F50 Whirlpool Cabrio WTW6600SW
Mar 24, 2010 | Whirlpool Washing Machines
I keep getting a f50 code it says press stop and start again but it still comes back with the f50 code
Hi
Thanks for using FixYa. F 50 flashes when the motor rotor position sensor (RPS) senses no rotation(Motor Stalled). Does basket turn freely? If not, make sure bottom shipping pack has been removed. Remove the basket and look for foreign object. If basket turns freely, then perform the below mentioned diagnostic test--
Motor Circuit TEST
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range shown in the wiring diagram on page 7-1. If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to
step 7.
9. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector. If there is continuity, go to step 11.
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Sep 22, 2009 | Kenmore Washing Machines
Stairmaster 7000PT Nautilus Stepmill Logo
154 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
zr800o1le
zr800o1le
Level 1 Expert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
