Question about Craftsman Garden
Model#917-273764 when i let off brake pedal it stalls and will only run with pedal depressed
    Brigadier General:
  • 3,911 Answers
I would look into:
a bad safety switch or safety switch relay is killing the engine when you let off the clutch. look especially where the safety switches are all wired into a central relay.
Posted on Apr 11, 2011
Key programing toyota 2002
No need to panic rush through this procedure, just do it right. Haste makes waste.
1. Simultaneously depress and release brake and accelerator pedals 1 time.
2. Insert an original Master Key into the ignition but do not turn it.
3. Within 15 seconds depress and release accelerator pedal 5 times.
4. Within 20 seconds depress and release the brake pedal 6 times and remove key.
5. Within 10 seconds insert New Key into ignition but do not turn it.
6. Within 10 seconds depress and release the accelerator pedal 1 time.
7. Now sit and wait for about one minute until the security light in the center counsel stops blinking and turns off.
8. Remove new key and depress and release brake pedal 1 time.
9. Test your key now. It should work if you followed the instructions. If not, you may want to try the following instructions:
This procedure is for 2002 Camry and most other models in this year of Toyota. In the future always give the model as well as year and make. Thanks
Nov 06, 2016 | Toyota Cars & Trucks
92 ACCORD what causes the gauges to quit working when the brake pedal is depressed, another problem is turning on the headlights and the engine dies any answer's ?
Hi Christopher:
I'd be checking to make sure that the grounds are nice and clean and working properly. When you step on the brake pedal you are activating a switch that sends power to the brake lights. The brake lights share bulbs with the signals and emergency flashers, so it is also possible that a dead short in any of those components could "steal" the power from the ignition.
At this point, it's a trouble shoot game for you to figure out what is working, and what is not.
That's part of the fun. Enjoy.
Apr 01, 2015 | 1992 Honda Accord
My scenic megane will start but only if clutch pedal is depressed (not brake pedal), and as soon as brake is applied when running, it stops. What is the matter with it?
Sounds like you have a standard transmission if it has a clutch.
Start requires the clutch to be pressed in for safety reasons.
If you have it in gear when you press the break the engine
will stall without your feathering the clutch. Sounds like you may not have learned how to drive a standard transmission car yet.
Otherwise there's a short between the clutch safty switch and the brake light circuit.
Feb 26, 2015 | Cars & Trucks
I have a Lexus RX300 1999 model and have this recent problem. engine running normally but gear gets stuck in Parking mode and won't shift. had to depress the emergency button on the gear shift and
Some automatic vehicles rely on the brake switch (mounted on brake pedal) to be activated by depressing brake pedal. This signal then operates a relay and switch, to release the gear lever.
Firstly, I would check the brake pedal switch (are your brake lights working?).
If brake switch is confirmed OK, then inspect the relay (and related circuit components) of the gear release switch.
Mar 04, 2013 | 1999 Lexus RX 300
Vw golf 2000 the brake pedal is to soft when you apply it and seems like is not going to stop but it does, what is the problem?
Not sure if you have done all this.
BRAKE BOOSTER INSPECTION
Functional test:
1. With the engine stopped, Depress the brake pedal several times, then depress the pedal hard and hold that pressure for 15 seconds. If the pedal sinks, the master cylinder, brake line or a brake caliper is faulty
2. Start the engine with the pedal depressed. If the pedal sinks slightly, the vacuum booster is working. If the pedal height does not vary, the booster or the check valve is faulty
Leak Test:
1. Depress the brake pedal with the engine running then stop the engine. If the pedal height does not vary while depressed for 30 seconds, the vacuum booster is OK. If the pedal rises, the booster is faulty
2. With the engine stopped, depress the brake pedal several times using normal pressure. When the pedal is first depressed, it should be low. On consecutive applications, the pedal height should gradually rise. If the pedal position does not vary, check the booster check valve.
Check valve test:
1. Disconnect the brake booster vacuum hose at the booster.
2. Start the engine and let it idle. There should be a vacuum available. If no vacuum is available, the check valve is not working correctly. Replace the check valve and retest.
END TEST
Nov 06, 2012 | Volkswagen Cars & Trucks
Would a bad Flasher relay cause the brake lights not to work?
The flasher does not stop the brake lights from working. Check # 18 fuse in fusebox under lower left side of dash. if it's ok, the brake light switch, on the brake pedal arm is next. light green wire with red stripe is hot if fuse 18 is ok. Depress brake pedal, light green with no stripe should have power. if not, replace brake light switch. If light green wire has power with pedal depressed, combination switch under the steering is next. Remove the cover from around the combo switch {under the steering wheel}. depress brake pedal, light green wire should have power. If it does, pedal still depressed, orange with light blue wire & wire with light green & orange should have power. Those 2 wires are brake & rear turn signal wires. { The turn signal switch should be in the middle, not right position or left. while checking for power in the last 2 wires. Good Luck drvolt.
Feb 06, 2011 | 2004 Ford F250
Starts fine,idles fine,stalls when put in gear to drive away
Try depressing slightly the gas pedal to see if the engine continues to run when you put it in gear. Might have to depredd gas pedal and brake simultaniusly. if the engine continues to run, then the problem is in the idle circuit. Try decarboning the throttle body and the idle speed control.
Mar 26, 2010 | 1989 Honda Accord 4 Door
1993 Ford AWD Aerostar Van. When the engine is
Sounds like the front calipers are not fully retracting properly. Check the front caliper operation while a friend pumps the brake pedal, the rubber lines could also be cracked and allowing air into the lines. Check brake fluid level.
Aug 29, 2009 | 1993 Ford Aerostar Extended
Engine sputters when clutch/brake engaged; revs when brake only engaged
check under dash where pedals are as there may be wiring there that the pedals are touching and shorting out
Jun 02, 2009 | 1998 Jeep Wrangler
Garden Logo
157 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
