Question about Ricoh Aficio 2015 Copier
The Porblem is Modole No. Ricoh Aficio - 2015 Photo Copy Machine, Just on Machine and comming Error Code no. 322 so what comming Error Code ? Pls Help me ! Thanks Basant
  • 263 Answers
This code is related to a Laser synchronization error.
It could be just dust but it also can be a defective Laser unit.
I advise you to call your technical assistance
Posted on Apr 11, 2011
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
Synchronization detect board unclean and mirrors in laser unit is dirty clean it if it's not work replace laser unit
How do i fix the error code sc 322 of my ricoh 3045 copy machine?
Have to open the Laser unit and clean the laser diodes carefully.
Dec 28, 2015 | Ricoh Aficio 3045 Digital Copier: 45cpm....
Ricoh MPC4500 sc290 error code
Hello, here is the error code manual for your copy machine. Error code 290 is on page 4.
https://printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20MPC4500&page=4
Good luck
Feb 02, 2014 | Ricoh 400879 Color Photo Conductor Unit...
How i can solve the ricoh 350 error sc-322
hii dear 322 means synchro1 not detected signal that go to sp mode yellow cancel and put 107 and hold on red cancel 3 seconds yo will see copy sp in asquar then put 2109and# and 2108and# and close machine and open if it's not work out try to clean mirrors in laser unit ok
Jan 25, 2011 | Ricoh Aficio 1035 Copier
Photo copier error code on ricoh 2018 code is 322
SC 322 is as follows.
322 C 1st laser synchronization error The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Causes
• Poor cable connection between the laser synchronization detector board and the LD unit.
• Laser synchronization detector board out of position and angle of reflection not correct
• Laser synchronization detector board defective
• LD unit defective
Basically there is something wrong with the laser unit. It is possible to take it out by removing the front of the copier between the paper tray and paper output deck. UNLESS YOU KNOW WHAT YOU ARE DOING DON'T DO IT. There is a laser in the unit that can cause instant blindness if you defeat the interlocks or repair it incorrectly. An experienced engineer would unplug the machine remove the unit, remove the top cover and clean the mirrors and glasses inside the laser unit without removing any of them, also check that the ribbon cable is correctly plugged in durin reinstallation.
I take no responsibility for these instructions or the text above, the laser unit has warnings on it that should be followed and it should only be repaired by the manufacturer in designated premesis.
Anyway hope this helps :)
Please rate.
Dec 23, 2010 | Ricoh Aficio 2015 Copier
Ricoh Aficio MP 1600 Le error code sc 322 occured during print job how do i clear it
Try to reset the machine by turn it off and after 5 second turn it on again by the red switch-plug which is located on the left side in the middle.
If this do not help you will need to cal a technician because the machine have problem with the laser unit.
Please answer do this is helpful.
Regards
Jan 12, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio 2015
Pressure roller warm up error. Usually means that the fuser roller isn't at the right temperature when you turn the copier on.
Try turning the copier completely off. Wait 30 seconds. Turn it back on again and see if it goes away.
If not a technician should look at the fuser section to see what the problem is.
Jul 15, 2008 | Ricoh Aficio 2015 Copier
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015 Copier Logo
96 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
