Question about Maytag Neptune MAH5500B Front Load Washer
Not spinning fills the water, then doesnt wash/spin the clothes.
  • 639 Answers
Dear j arzaga73,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
Posted on Aug 26, 2008
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
Hot water stops filling too soon.
Fill setting has to be adjusted and the belt is slipping on the spin cycle and not generating enough centrifugal force to get the water out.
Aug 25, 2017 | Kenmore 22422 Top Load Washer
Washer does not have enough water, and when it spins it doesnt spin enough to get all the water out of the clothes.
a few things to try... the water fill pipe that feeds the machine, check the tap at the end to make sure its on full, if it is then turn water off and unscrew pipe from rear of machine and see if connection on machine is blocked or clogged. then usually located at front of machine at the bottom, unscrew the filter to see if its blocked with small change ( usual suspect ) and try.
Dec 16, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Machine will not agatate when clothes are in the machine
does the machine fill up with water? if you were to put the machine in drain/spin, does it drain/spin? if water comes in and it doesnt drain/spin, then your lid switch is bad. if the machine fills with water, drains but doesnt spin, the your motor coupling is worn.
Feb 03, 2011 | Washing Machines
Filling with water but not draining or spinning
Its not the water - it's the weight of the clothes. Remove some clothes and re-try.
If this doesnt solve - the ECU is failed and must be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 26, 2009 | Kenmore Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
The washer doesn't spin out the water. Clothes come out soaked?
if it washes ,,check your lid switch,,if it doesnt wash and spin check your motor coupling...onthejob
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Creda machine won't agitate with clothes in it
Your load is prob to heavy for the older washer. it just doesnt have the power to handle it no more. time to replace it, sorry.
Jul 30, 2007 | Creda W120VW Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
