Question about Sunbeam Heating & Cooling
I have portibale sunbeam aircon model sac-500 how do i get it to make the room warm and not cold on what setting must it be.i just need the warm air that blows out on the back to blow out infront
SOURCE: dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Posted on Feb 15, 2007
SOURCE: centrex airconditioner
I bought a house with one already installed. Found that it isn't switching from 'hot' to 'cold' After time the unit will beep and flash LED's on the unit itself and then switch off. Rather handy on 40 degree days. Good luck sourcing parts for the unit as the company have gone bust. I do know an honest working fellow that installs units - he suggests that Kelvernator are a no go, Mitsubishi, Panasonic are the ones to look at. Pay the extra cash for a brand name, they're less likely to go bust for a start, and if there is a problem, parts are readily available.
Posted on Jan 09, 2008
SOURCE: not blowing cold air
check the folowing reason of no air flow
-thermostat
- the selector switch
- wiring
-fan motor capacitor
- fan motor
Posted on Apr 27, 2009
  • 358 Answers
SOURCE: AC unit outside blowing out cold air, vents
If you have a heat pump probably there's a wrong connectionin the thermostat, but if is not a heat pump ,the compresor is not working or the unit leaked all the refrigerant.
Posted on Aug 30, 2009
Testimonial: "thank you, we have had a problem in the past with refrigerant leaking, was supposed to be fixed"
  • 534 Answers
SOURCE: air conditioner doesn't blow cold air. Continues
If the a/c fails to continue to blow cold there could be a few problems you can look for. First once you activate the system check to see if the compressor kicks in. You will hear the compressor humming . Once the a/c quits cooling go and see if the compressor is still running. If its not running its probibly gone into thermal overload (compressor overheated). If that is the case then you need to check to see if the coils are icing up if they are icing up then the problem is with 1) air flow restriction filter dirty, coils dirty simple repairs there replace filter, clean evaporator coil with a coil cleaner that can be purchased at a home repair store cleaning the condensor coil the same. 2) system is low on freon in which case the system will need to be recharged. Also, If you have a digital thermostat replace the batteries that may also be of some help. Good Luck on repairs
Dave
Posted on Aug 31, 2009
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
Hi i need to know what size window air con for a room 30sq meters cooling onjy and what model
Hello there.. :) your room 30 sq. meters needs 2 - 2hp window type aircon as computed. But you can consider the purpose of putting up the aircon and how many occupants will stay.. :0
For the model:
NATIONAL, 2HP, Model CW-1808VPH 2HP LG Window Type Aircon Manual 2HP Koppel Aircon w/ remote model: KWR-18R1
or check the internet for other models that you want.. :)
Feb 03, 2011 | Heating & Cooling
Aircon is not cold heater is not hot
the air con unit need recharging
Jul 05, 2010 | Heating & Cooling
Heater warms up in morning but over the day only gives cold air despite being set at 22degrees. VW dealership says when set at 22degrees it will warm up to 30degrees and then introduce cold air to bring...
vw fit 3 types of aircon,
1.full climate control (you set temp is stays there)
2.climatronic (as your dealer said.....)
3.aircon std (cold draft)
you cannot change whats fitted to another type.
Apr 08, 2010 | 2004 Volkswagen Eurovan
Samsung aircon remote not working
Does your remote have batteries? If yes change them. Somewhere on the unit there should be a selector switch, put it into test and manually lower the thermostat setting
Feb 14, 2010 | Heating & Cooling
Our air conditioner seems to be working fine yet t won't blow cold air. Its just room temp air actually feels like you're standing in front of a small fan.
check outside unit large pipe should be cool or even very cold small pipe should be warm to touch that will eliminate some questions in order to solve problem also check circuit breaker for outdoor unit see if fan on outdooor unit is running and listen for compressor hum
Jul 02, 2009 | Sunbeam Heating & Cooling
Unable to turn on aircon with remote control and no manaul on button on the air con unit
I recommend putting new batteries in the remote. If that alone solves your problem great. If not, get back and let me know
May 25, 2009 | Heating & Cooling
Blows warm air
you need to disassemble the rear fan shroud and clean the back of the condensor. If the compressor runs and the lines are cold, it is dirty. The rear condensor is the one discharging the hot air. Both sides must be clean and free of dirt/grime
May 06, 2009 | Sunbeam Heating & Cooling
Heating & Cooling Logo
103 people viewed this question
Top Sunbeam Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
