Question about Biostar P4M80-M4 + Celeron 2.5G Motherboard (P4M80-M4 + CELERON 2.5G (COM...)
After flash BIOS DMI Update fails ? - Biostar P4M80-M4 + Celeron 2.5G Motherboard (P4M80-M4 + CELERON 2.5G (COM...)
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 157 Answers
If you are able to boot into Windows, don't try it again. If you are not able to, try to reflash it. If that fails, contact the tech support for the bios and see if they have any suggestions, sadly I doubt they will. You may end up having to replace the mother board.
Here's the link for biostar's tech support: http://www.biostar-usa.com/techmain.asp
Posted on Apr 11, 2011
Computer fails to boot --screen says AMD Data Change Update New Data to DMI
Boot to bios and from there you can reset dmi log to default or disable. That error appear when some changes happened from your hardware configuration add or remove.
Mar 21, 2010 | Computers & Internet
I can't update my Travelmate 8104WLMi. Every time
it is not flashable then you dont ever update your bios unless it has a problem.
Oct 19, 2009 | Acer TravelMate 8104WLMi Notebook
My Zenith PC displays Verifying DMI pool data . Update Success
Sometimes this can be even simpler. Put in your Windows CD and boot to safe mode command prompt and type fixmbr. This will repair your master boot record for your primary boot harddisk. Eject the windows CD and reboot and see if it fixes your problem.
Sep 02, 2009 | Computers & Internet
Update for my BIOS... help me!!
Here is latest bios update for Aopen MX46 motherboard:
ftp://ftp.aopen.com/pub/bios/mx46/wmx46r112.zip
And this is the same old R1.12, because there is no newer update since 2002
Aug 22, 2009 | Computers & Internet
I have Award Modular BIOS v6.00PG, DMI verrsion : BIOS supports minimum version 2.2. Latest is version 2.3, kindly suggest me where should i get upgrade for the bios.
My suggestion would be to not look for the specific bios version to update, but to go to the motherboard's (if you have a custom built), or computer manufacturer's (for pre-built models like Dell or HP) website.
Most of these sites have extensive support sections that list the most current BIOS updates and drivers for the motherboard chipset.
This method is also a little safer, because the last think you want to do is update (flash) your BIOS with an update that is incompatible/not tested to work with your motherboard.
Hope this helps!
Cheers,
- Demolitio
Aug 03, 2009 | Computers & Internet
Acer desktop T180 is stuck on verifying DMI pool DATA..
verifying DMI( Data Migration Information/or Dynamic Migration Information) pool data refers to hard disk function. check the hard drive to see if it functioning properly.
Jul 12, 2009 | Acer Aspire T310 PC Desktop
Bios update failed *flash*
Did you make copy of your original bios before flashing...if yes then reflash with your original.
If No then trying reflashing again making sure no power cuts, dont touch computer until flashing is complete.
Are you using the correct bios for your MoBo?
Jul 04, 2009 | Acer Computers & Internet
I've update my bios by flashing it and during the process it failed. After i rebooted my pc, i get this error "Verifying DMI Pool Data..." and just hangs there. Whats the...
Hello ,
Use this link http://files.getdropbox.com/u/747181/FLASHCD%20ACER%20T180%20R01-B4.ISO
Thats a bootable cd image that i made containing the latest bios for your board (R01-B4) and a flash utility. This bios has been modified to include overclocking options and extra features which are not in the standard bios!
Burn this image to a cd and boot into the DOS Prompt. At the prompt type the following
awdflash.exe 61AO427.bin /py /sn /cc /r
wait for it to finish reflashing the bios , then eject the disc and restart.
If you found this solution helpful , please rate it below
Kind Regards
1234s282
Jul 02, 2009 | Acer Aspire™ T180 PC Desktop
Corrupted DMI Strings in BIOS
May be the bios chip on the mother board defective.Plse contact a technician who is doing chiplevel servicing mother board
May 01, 2009 | Computers & Internet
Frezes at verifying DMI settings. Already changed MB and Power supply. Lan connection only flashes green once in a while should be constant. Tried on a working terminal and does the same.
The Desktop Management Interface (DMI) is a new
method of managing computers in an enterprise. The
main component of DMI is the Management Information
Format Database, or MIFD (the DMI Pool Data). This
database contains all the information about the
computing system and its components.
At times, some systems may experience hang
conditions after partitioning, formatting and initial
bootup of a hard drive. The message, "Verifying DMI
Pool Data" appears and the system hangs. This
condition may continue after the drive has been
removed.
! WARNING ! ALL SUGGESTIONS LISTED IN THIS
INFORMATION BULLETIN ARE BIOS RELATED. FOR
A PERMANENT SOLUTION, MAXTOR RECOMMENDS
THAT USERS CONSULT THEIR SYSTEM OR
MOTHERBOARD MANUFACTURER FOR BIOS
UPGRADES.
Suggestions to Resolve the Condition:
1.Apply power to the computer.
2.Access the system BIOS.
Set the drive type as None or Not Installed.
Load BIOS Defaults
Load SETUP Defaults
3.Save the BIOS changes and reboot the PC to a
System Boot Diskette.
4.Shut down the PC after the memory count is
displayed.
5.Reconnect the power and interface cables to the
hard drive.
6.Access the System BIOS.
7.Auto-Detect the hard drive. Ensure that the LBA
Mode option is enabled.
8.Save the BIOS changes and boot the PC with a
System Diskette.
9.Partition and format the hard drive via the
operating system.
10.Reboot the system. On bootup, the screen should
read:
Update Successful
The system should continue booting normally.
Other Possible Solutions:
2.Access the System BIOS.
3.Disable both the Internal and External CPU Cache.
These features are located in either the "BIOS
Features" or "Advanced Settings" options of the
BIOS Setup.
NOTE: Consult the System or Motherboard User's
Manual for exact location of the Internal and
External CPU Cache settings.
4.Save the BIOS changes and reboot the PC to a
System Boot Diskette. On bootup, the screen
should read:
Update Successful
5.After the system successfully boots, re-start the
PC and access the system BIOS.
6.Enable the External CPU Cache. This feature is
located in the "BIOS Features" or "Advanced
Settings".
Manual for exact location of the External CPU
Cache setting.
! WARNING ! User's MUST re-enable this feature
for optimal system performance.
7.Save the BIOS changes and reboot the PC to a
should read:
Update Successful
NOTE: If the aforementioned suggestions fail to
resolve the issue, contact the system or motherboard
manufacturer to:
Remove the "Clear CMOS" Jumper and reset the
system BIOS
Obtain a Flash BIOS Upgrade
from pc help;
SYSTEM HANGS AT MESSAGE: "VERIFYING DMA POOL DATA":
You did not say what operating system you are running but I assume Windows 95 or 98. It is possible some Windows
system files are corrupted or perhaps the system doesn't like your ram (if you added or installed ram recently). There
is also a possibility that there is something wrong with your BIOS and you *may* have to update it, but I would avoid
doing that if at all possible.
A quick fix - if the problem is software related - is to:
1. boot to a Windows startup disk (one that matches your operating system). this step assumes that your PC is setup
to boot to the A: drive before the C: drive (via the BIOS SETUP program). If you don't have a Windows startup disk,
you will have to make one on another person's computer that has the same version of Windows. You make one via:
my_computer/control_panel/add_remove_programs/startup_disk
2. run "scandisk c:" to make sure that any file corruption is fixed before going to next step
3. do a "sys c:" from the "a:" prompt to transfer a good copy of Windows system files to c: drive
4. remove the boot floppy, reboot the system and see if all is well.
If that does not solve the problem you may have to reinstall Windows 95/98. Ouch!
I recently had someone bring me a computer that had this DMI error message problem and I tried the "sys c:" method
(with the startup disk) without success and had to entirely reinstall windows 95 (and almost all applications except for
some programs that did not need to be placed in any Program Files directory or other special location) to cure the
problem. However nasty a job that is, it did cure the problem.
Jun 23, 2008 | Computers & Internet
Biostar P4M80-M4 + Celeron 2.5G Motherboard (P4M80-M4 + CELERON 2.5G (COM...) Logo
116 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Martin Murray
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
