Question about Dell Dimension 2400 PC Desktop
Hard disk 0 configuration error post error keyboard error dell dimension 2400 xp
  • 721 Answers
Unfornate motherboard failure. Ran into many with the same problems. The usb ports fail, then the ps2's,etc. Needs a mobo.
Posted on Apr 16, 2011
Dell dimension 2400 freezes up shortly after boot. I replaced cooling fan but error log shows keyboard failure.
if you see lights get on Keyboard.. your motherboard is fine.. else it is your Keyboard or Super I/o Chip that is not working..
Mar 27, 2013 | Dell Dimension 2400 PC Desktop
Disk 0 seek failure
You must re-install windows or whatever OS your machine came with. If you have a windows CD, boot from that and follow the instructions given.
Sep 23, 2012 | Dell Dimension 2400 (24006YYVP31) PC...
Can i make a bootile usb for dell dimision 2400
If the BIOS setting for the Boot up device order does not have the USB as a boot up device then it is not possible to boot up your computer with an USB device.
For a Drive 0 seek problem -
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 19, 2012 | Dell Dimension 2400 PC Desktop
No boot device available stike f1 to retry boot and f2 for setup utility diskette drive 0 seek failure a dell dimension 2400 series
Your computer cannot find a boot-able storage device, i.e. hard disk drive, to boot from. Either your hard disk drive is defective or the OS (operating system software) is corrupted and needs to be re-installed.
Jul 27, 2011 | Dell Dimension 2400 PC Desktop
DELL DIMENSION 2400 ERROR STOP: 0x00000024, (0x00100203,0X82F898
You seem to have an error in the boot sequence of the Operating system. If you are unable to access the safte mode of the OS, then you will have to do a hard boot (boot from disk). My suggestion is seeing that you have a Dell, many times they will give you a boot disk or charge you $10 for one to be sent to you. Boot disks are not expensive at all.
Once you recieve the boot disk, go into the BIOS and change the boot sequence that it boots from your CD/DVD drive first instead of your hard drive (C). Then restart the computer with the disk in the disk drive and it will load from the disk.
If that does not work, you will have to do a reimage. For that you will need a Windows OS CD (XP, Vista - whatever OS you use). From there you can either have your data slaved over to another drive prior to reimaging, or if you dont mind loosing the data, just push in the Windows OS CD and it will ask if you want to over write or reimage, answer yes, and it will begin to wipe your computer and place a brand new copy of the OS on there.
Jan 02, 2010 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2400 with windows xp profewssional. When I try to turn the system on i get an isass.exe application error that says the application failed to initialize properly (oxc0000005). click...
if you have a window xp disk put it in start the machinfne and when it ask you to replace or repair windows you want to repair window xp hope this help .........................
Nov 23, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
Before I start my dell dimension 2400 computer up, I have to disconnect my usb mouse and usb keyboard because if I don't I will get these 2 errors, Primary drive 1 not found and Secondary drive 1 not...
The resolution for this is to go into the BIOS with the help of F2. Then look for the option USB Legacy devices. If it is enabled disable it or vice-a-versa. Also look for Boot from USB devices. Please disable that option. And select the first boot device to be the HDD (Internal hard drive)
Jul 11, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400
Click this link:
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/advtshoo.htm
It contains the list of the beep codes for dell dimension 2400.
There is also a guide on how and what to troubleshoot. Motherboards use beep codes to indicate what error might caused the system to malfunction.
Dec 17, 2007 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
81 people viewed this question
Alun Cox
