Question about Gateway 831GM PC Desktop
My old, trusted gateway 831gm won't power up... no nothing. little green light on psu on back is blinking... nothing else.
5 Suggested Answers
  • 397 Answers
SOURCE: I have a Gateway Model
Sorry to be the bearer of bad news but Gateway machines are fitted with Bestec power supply's (dreadful things) and usually when the power supply goes it takes the mother board with it.
I live in an area prone to electrical storms and I probably get one Gateway machine a week into my workshop with exactly this problem.
Posted on Aug 07, 2008
SOURCE: psu blinking green light, no power
I read all the solutions, followed the manufacturers instructions exactly, replaced the cmos battery and nothing solved the problem (blinking light on PSU after a power failure and no startup at all). I had ascertained that the PSU was intact by disconnecting all the PSU connections to drives and motherboard at which time the PSU LED stopped blinking and was constantly on.
Just before throwing my computer away I decided to follow the instructions listed by "guest" to unplug the power to the motherboard and then with the power supply back on to plug the cables back into the motherboard. No only did sparks not fly, but it started up and ran perfectly! Many thanks to "guest."
Posted on Sep 18, 2008
RAhUL_hunk
  • 63 Answers
SOURCE: Won't power up
hi
seems like your ram is bad and also change your vga [graphics card]
kind Regards
RAHUL_hunk
Posted on Mar 10, 2009
Crankstart
  • 696 Answers
SOURCE: Gateway 831GM Eratic Fan Noise
This can be caused by several things:
1. Bad temp sensor
2. Bad voltage, but that will usually cause the whole system to restart
3. Too low maximum temp setting inside the chassis(setting is in bios), often denote as max case temp.
One way to bypass the problem is rig the fan to a molex adapter with a variable voltage molex to 2/3/4pin fan connector and adjust the speed to the maximum quiet setting.
The 831's did run a bit warm so if the case temp setting is set to low it will fluxuate quite a bit. Try adjusting the max case temp up around 50c just to see if that does it, if it does either use the variable voltage dial solution or add a second case fan that's always on, prefferably a low RPM running direct off molex so it will reduce the average temp and therby the need of the monitored case fan to rev up.
Chris
Armor-IT
Posted on Apr 24, 2009
Hp pavilion slimline power supply
you bringing a marginal part or connection back up a working state. when it cools or voltage drops it goes to the non working state. hp power supplies are not good to begin with. replacing it will fix it till that one also fails
May 23, 2017 | Computers & Internet
My computer wont start up. The power supply light flashes green when plugged in then red. But still nothing , can someone please help?
Try a Power Supply Unit (PSU) Reset: Unplug the electrical cable from the wall and the PSU (Back of Computer)
Move the red voltage selector to the opposite position it is in and then slide it back. If you live in the USA 120Vac to 220Vac back to 120Vac
After you have done this you can plug the power cable back into the PSU. Connect the power cable to the wall power. If the PSU is still serviceable it will no longer be blinking.
2c170cb8-7c41-4ef0-8a3f-ff232e57320e.jpg fd10abb2-6218-42f0-8857-b761fffbcecd.jpg
Jul 08, 2013 | HP Compaq Business d530 PC Desktop
Have dell Inspiron 546 minitower. Been acting up lately where it won't power up. The LED light on PSU below voltage switch is green. Light on MB is orange. No power or indication at all on front...
PSU's put out several different voltages if the 12Vs isn't working it won't power the motherboard. Some outputs may still be functioning therefore you may see some lights on and even some fans running. Replace the PSU.
Jun 29, 2013 | Computers & Internet
Compaq FS7600 Computer not turning on
what tower? model, the monitor has nothing to do with power and dead fans in the tower.
'Sounds, (and silent to) means the PLUS in the PC is dead.
all things can be repaired, that is what technicians do.
here is the chain of events, ! to get noise (fans)
power in the wall 120vac , usa
power to the PSU,
the power button goes to the MOBO, and standby power is there
now and pushing said button the MOBO commands the PSU on
if the PSU is happy (PWROK) thinks PSU IS safe the PSU tells the PC its ok, and power stays up.
and fans run.
so my guess bad PSU, its easy to test with anyf $10 voltmeter,
ask.
tower PSU, 101
http://pcdied.com/power.html
May 21, 2017 | HP Compaq FS7600 17" CRT Monitor
The green light on my prince lionheart warmer won't stop blinking
I realize the original question is 2 1/2 years old but for future answer searchers... the flashing light means your power cord is no longer working.
Jan 18, 2013 | Prince Lionheart Premium Wipe Warmer
My hp elite won't turn on. it was running fine, and I left home for an hour, came back and it was off and wouldn't start. it's only 3 years old. The little green light on the back stays lit for...
The green power light will stay on after it is unplugged, as there is still residual power in the unit. The symptoms you describe point to blown main capacitors in the PSU, the only way to check is by fitting a new PSU (recommend one of 700 watts minimum). Not very expensive and as long as you are careful, easy to fit
Jul 02, 2011 | Computers & Internet
Gateway 831gm - press power on, power is there but will not stay
If the power button is not defective in/out, it means yuo have a defective power supply.
Thanks
Jul 30, 2010 | Gateway Computers & Internet
I have a Gateway 831gm It was working fine until I unplugged it to move into the other room. now it won't start. I can get the fans to start if I hold the button in but the lighted switch and power light...
You power supply is broken. It can happen at the drop of a hat. Plug in your PC model in google and follow it by the words power supply. You should be able to get one for $20 or less.
Sep 22, 2009 | Gateway 831GM PC Desktop
Gateway 310 X will not power on
Hi. this is a failed power supply. the power supply pack will have to be replaced. it located on the rear side of the tower in the upper corner. its where the power cord plugs into. replace the power pack and this will fix the issue at hand.
May 17, 2009 | Gateway 310 X (310XSP) PC Desktop
Psu blinking green light, no power
Oct 31, 2007 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Gateway 831GM PC Desktop Logo
210 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
