Question about Freezers
Kenmore freezer model 253.26432100. Doesn't keep temperature down. ie: steaks and meat stay frozen but bread doesn't.
Tech007
  • 63 Answers
SOURCE: Kenmore model 2539280412 upright freezer alarm keeps going off
might have a defrost problem check to see if it is building up with on the back panel if it is you need a defrost timer or limiter or heater or fan
Posted on Aug 29, 2007
  • 62 Answers
SOURCE: Kenmore Upright Freezer Model 253-9280810
is it possible the door has not been closed at some point?
If so they can build up with ice in the evaporator which the defrost system cannot handle....Try a manual defrost.
Depending on where the unit is installed high ambient temperature can drop the internal temp enough to set the alarm off though they will still freeze sufficiently
Posted on Jan 06, 2008
  • 323 Answers
SOURCE: Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Posted on May 12, 2009
woodchuck789
  • 4059 Answers
SOURCE: Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Posted on Jul 02, 2009
  • 3 Answers
SOURCE: Sears Kenmore Deep Freezer settings
i tilt my chest kenmore deep freezer to remove water when cleaning it by the time it was connected it didnt work
Posted on Jan 21, 2010
Kenmore model 19502 chest freezer green light blinking
My Kenmore chest freezer just went dead today. It ruined my Ribeye steaks, my shrimps and other meats. I will not buy a Kenmore again.
Jan 12, 2013 | Kenmore 5.1 cu. ft. Chest Freezer - White
My freezer does not keep my ice cream hard, yet it freezes meats, etc. without a problem. What is wrong?
You don't note whether or not you've adjusted the thermostat. Ice cream (and juices) requires at least zero degrees, if not minus 5 degrees, for storage. Meats, fish, bread, etc. can become rock hard at much higher temperatures. Try setting the thermostat lower.
Jun 07, 2011 | Freezers
Orange light in front is flickering almost constantly. What might this mean? The food seems frozen -ice cream is fine as are breads and meats.
It is normal for those lights ot flicker.. as long as the unit is working then do not worry about that...the light really is just showing you that you have power to the unit...
heatman101
Aug 26, 2010 | Kenmore 15 cu. ft. Chest Freezer 16542
My freezer does not seem to be freezing properly. Some of the meat is staying frozen while some is getting soft. All my bread products are not freezing at all they are staying cold but soft???
THE RED WARNING LIGHT KEEPS COMING ON AND I HAVE TO KEEP PRESSING THE FAST FREEZE BUTTON, THIS IS EVERY FEW DAYS. IF I DONT NOTICE ALL THE FOOD DEFROSTS!
Mar 23, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My wife and I bought a Kenmore chest freezer (14.8 cubic foot) about 6 weeks ago. It is made by Frigidaire for Sears, and the model number is #253.165.42105, serial # WB94341279. It has been working OK. ...
This is well with in factory specifications. Hot air rises and cold air drops. Because a chest freezer does not have a fan to circulate the air it is normal for the basket to be warmer than the bottom of the freezer. The bottom of the freezer is used for food you want to keep for a longer period of time.What you store in the basket is food you will freeze for a short period of time. Ice cream should not be kept in the basket. As you fill your freezer with food you will find that the temperature will equal out because the frozen food will take up the place of the frozen air which will give you a more stable freezer temperature.
Try your test when you have it full of food.
Dec 29, 2009 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer not freezing
not freezing icedraem is an issue, bread not so much, different breads contain different ingrediants that may or may not freeze, forst offthough wher is unit located??? in garage??? if so be aware that it may not operate efficiently ion ambient temps lower then 55 degrees, but if this is in your kitchen i would suspect a "refrigeration"/sealed system issue, perhaps "low on charge and not able to maintain a frozen set temp. Meat may stay frozen ( for a little while anyway, but the ice cream is the first to show indications of problem
Jan 11, 2009 | Freezers
Temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Dec 03, 2008 | Kenmore Freezer 14.1 cu. ft. Upright...
Freezer Burn
It sounds like you may be overloading your unit. If you place a large quanity of non frozen items in the freezer at one time, it may take a few hours to bring the temperature back down. This usually happens with a chest type not an upright. Insure when adding items to the freezer there is room for air movement. With out looking at it I think the problem is the defrost timer or sensor. Maybe staying on too long increasing the overall temperature of the unit. When ever the defrost cycle is on, the cooling unit is also off. As far as the meat freezer burning, none of the freezer bags I have used prevent this. I pr-wrap my meat in freezer paper and then place it in a bag, sometimes freezer bags sometimes not. I try not to buy meat from grocery stores, I grow my own meat and have it butchered and vacuum packed, it doesn't change color. Please note that items in a freezer bag moved around after the contents have frozen will cause air leaks in the bags very easily.
Nov 26, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
FREEZER ALARM WILL NOT SHUT OFF
Use a freezer thermometer and tell me the actual temperature. Or at least store some ice cream and see if it stays brick hard. Unless I have some idea of the actual temp I can't tell if defective freezer or alarm
May 11, 2008 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
225 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
