RCA HDTV Monitor when I turn it on It makes a beep sound and will turn off
  • chhriss Aug 08, 2008
    I have the same problem you pushh the on button or use the remote and it blinks and acts like it is trying to come on, about three times then it doesnt do anything else. i hear it clicking in there when i get up close, while it is trying to come on
  • big banana Aug 12, 2008
    HDTV/monitor Model D52W19B yxa
  • 8,617 Answers
I will need the model number of your set in order to help. Please respond to this same post when replying
Posted on Aug 07, 2008
  • Sonny Berry
    Sonny Berry Aug 12, 2008
    that model has had consistant problems with bad flybacks. I would assume that the flyback is whats giving you the proble. as well. You can get a replacment flyback at the following link with free online support to help you install it. you need flyback 259296. heres the link
    http://servicemanuals.vstore.ca/
Model D61w20 thanks
Posted on Aug 12, 2008
I bought a cable that plugs into my laptops monitor outlet and turns the other end into S video and RCA jacks. i Go to my control panel and try to set my tv as a monitor and it makes a couple of buzzing...
there is a piece of hardware that you will need that goes inbetween the laptop and t.v. im not sure what its called but you can call any computer store and they will tell you what it is
Apr 02, 2010 | Sony VAIO PCG-K35 Notebook
Lately, my RCA HDTV monitor has been shutting off
Probably bad capacitors on the power supply board. There are about four that should be replaced all at once. The to of the capacitors will be "puckered" or bulged out. They are located toward the front of the power supply.
Oct 14, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19B makes high pitched buzz when on
Sounds like a coil is vibrating or a component is bad causing the transformer to whine. Could possibly just need soldering.
Jul 08, 2009 | Televison & Video
TV picture went out.
power supply problem check capacitors...caution
high voltages..large capacitors retain nasty charge for a long time.........
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 Power Light Turns On/Off with a Sound
If set makes a squealing sound you have something shorted in hori M/B hori output Transistor NTE2324 also CK second ribbon make sure it is in good/making correct connections. On capacitors IF cp150 2200uf 16v is puffed up on top replace all 3 caps.
Jan 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Beeping Sound
Maybe the horizontal IC output are damaged need to be replaced
Nov 04, 2008 | RCA F36650 36" TV
TV making high pitch sound
Hi, There are usually 1 or 2 fans inside the TV's. Could be worn bearings, or fan blade interference. Sorry, without my electric ear working, I can only guess.
Apr 21, 2008 | RCA HD52W56 52" Rear Projection HDTV
Tv don't turn on
This set has problems with ribbon cable coming from front panel to ssb board. Check to make sure seated properly. For more info ctechnicians.com
Jan 06, 2008 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
452 people viewed this question
Top Televison & Video Experts
