Question about Gateway Computers & Internet
Why does my icon have a shield in front of it and how do i take it off
  • Coss May 11, 2010
    Please explain which icon has the shield?
    And when did it appear?
    Sergeant:
    Champion:
  • 236 Answers
In Windows Vista, all icons that have the shield mean that you need to have administrative rights to open that program.
To remove the icon,
  1. Launch MSCONFIG from the Run menu("Start" button + "R"
  2. Click on the Tools tab. Scroll down till you find "Disable UAC" . Click on that line.
  1. Press the Launch button.
  2. A CMD window will open. When the command is done, you can close the window.
  3. Close MSCONFIG. You need to reboot the computer for changes to apply.
Posted on Aug 07, 2008
Where is the horn location under hood of a 2007 mercury mountneer?
Remove the LH front fender splash shield !
Fender Splash Shield Removal and Installation
  1. Loosen the running board bolts and lower the running board to access the front fender moulding pin-type retainer.
    • To install, tighten to 23 Nm (17 lb-ft).
  1. Remove the lower pin-type retainer from the front fender moulding.
  1. Remove the 2 rear pin-type retainers from the front fender moulding.
  1. Position the front fender moulding aside and remove the splash shield lower screw.
  1. Remove the front splash shield screws.
  1. Remove the front splash shield pin-type retainers.
  1. Remove the front splash shield.
  1. Remove the front fender splash shield.
  1. To install, reverse the removal procedure.
Mar 25, 2015 | 2007 Mercury Mountaineer
How to remove front seat shield
please explain what you refer too on a front seat shield ,never heard of this before
Jul 10, 2014 | 2012 Chevrolet Captiva Sport
Hot spot shield automatically stooped / paused and message displays can;t connect to secre service how can i switch on the hotspot shield
You can turn your VPN on and off by tapping the Turn On/Turn Off protection button on the app home screen. When you are connected the shield icon in your icon bar at the top of the screen will be green. It will change to red when it is disconnected.
Feb 07, 2014 | Computers & Internet
How to Remove Blue and Yellow Shield.
You need to make sure your default applications are set correctly.No need to make new partitions etc it is a problem with your settings for which programs you choose to be the default ones I think.
Dec 23, 2013 | Microsoft Windows Vista Home Basic Edition
On windows vista some desktop icons have a security shield on right side of icon. how do you remove shield and not lose the security?
The icons having Shield icon associated with it means that they need administrator privileges every time they run. Not any kind of security as you think, this thing simply says that they should be run from any administrator's account or other account with administrator password.
Hope this helps, Mrityunjay.
Jun 20, 2012 | Microsoft Windows Vista Home Premium...
Jun 20, 2012 | Microsoft Windows Vista Home Basic Edition
Where is the fuel filter located on a 2004 mercury mountaineer
Hello, 2004 Mercury Mountaineer fuel filter is located in front and on top of fuel tank behind two shields. This is for 4.0L 2 wheel drive. When you look just behind the front passenger side tire you will see the first shield. Behind that is the second.
Thanks
Aug 10, 2010 | 2004 Mercury Mountaineer
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
Dryer does not heat and continues to run/will not shut itself off
This is probably due to a faulty heating element, something the average do-it-yourselfer can replace. Disconnect the power supply, then refer to the owner's manual for procedures to remove the front panel from your specific model. If your dryer has a toe-kick plate in front, that's all that needs to be removed.
1)Locate the heating element heat shield, a box on the lower right side of the dryer.
2)Using a screwdriver, pull the two screws at the front of the heat shield. Remove the front of the heat shield or, if it is on a hinge, flip it down.
3)Remove the wire leads from the heating element terminals by pulling on the leads. To avoid damaging the wires, do not grab them when you pull off the leads.
4)Remove the holding screw on the side of the heat shield that connects to the heating element.
5)Remove the heating element by sliding it out of the heat-shield box. Install a new heating element and secure it to the heat shield with the holding screw on the side.
6)Reconnect the wire leads to the new heating element by pushing them onto the terminals. Place the heat shield front cover back into position and secure it with the mounting screws.
7)Replace the front panel or toe-kick plate and reconnect the power supply to the dryer.
Aug 28, 2009 | Frigidaire Dryers
I dont know whats wrong-help!
What do you mean with "remotely involves an administrator action".
In terminal server session?
remote desktop?
Dec 06, 2007 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
