Question about Lite On LVW-5001 DVD Recorder
Hi I have a liteon lvw5001 when I insert any DVD it tries to load it but keeps coming up no disc. I have tried to DVD cleaner but still it will not recognize that either. Many thanks John
SOURCE: WRONG DISC
it is the internal lazer light. if you communicate with coby they will fix it . it seems to happen quit often ed
Posted on Feb 02, 2007
  • 31 Answers
SOURCE: No discs inserted
This is a common problem with the Lite-on LVW range of DVD recorders due to changes in the construction of more recent DVD R media. It can be solved with a relatively simple firmware upgrade.
Goto : http://r00.liteonit.com.tw/DC/english/download/index.asp
You'll need to have a blank CD and a CD/DVD writer in the PC you use to download the file.
Follow the instructions to upgrade your firmware, this should then allow you to write to DVD's once again.
Posted on Mar 06, 2008
  • 31 Answers
SOURCE: liteon lvw-5045
If your DVD recorder can still access CD's the goto the following link and select your DVD recorder from the drop down list under audio/video and download the firmware file.
http://www.liteonit.eu/index.php?option=com_wrapper&Itemid=178
Write the file contained in the zip file to a CD and insert it into your DVD recorder. Follow the instructions in the user manual to complete the firmware update.
This should solve your problem.
SOURCE: LiteOn LVC - 9016G dvd recorder Problem.
throw it in the trash- I got 1 from costco, liked it so much, bought another a week later. First one started giving me the "invalid" msg, 2nd one did the same 1 wk later, so I guess they're programmed to do so after so many hours after being plugged in. Too bad, cuz it was the easiest to use of 5 previous models I tried. Their easyguide onscreen menu was the greatest, plus the status of time, pause & recording indicator, which you could turn on or off as needed, were very useful.
A real shame to have to throw in the trash. Won't ever buy another thing from them.
Posted on Mar 15, 2008
  • 5 Answers
it maybe the spindle motor that rotates the disc thats why there is no information read by the laser or the laser itself is the problem. if it is only the motor it can be replace but the laser it should be compatible or the same model. one simple thing to do open and try to clean the optical lens by a cotton buds gently rub around the lens and close and try.
Posted on Jun 10, 2008
Samsung dvd vr330 combo keeps trying to load a blank dvd-r
HI Not fixed yet but reading some of the answers that appear to be very common I am going to try a dvd cleaner on the machine so hope it works
thanks for tue info
crawfordj939
Jan 31, 2010 | Samsung DVD-VR330 VCR and DVD Recorder
When disc is inserted, the window show loading for about 60 seconds, then tray comes back out. have tried all type of discs, same result. the vhs side works fine.
TRY A LASER LENS CLEANER IT IS A DISC WITH TWO PIECES OF LIKE FELT ON IT SHOULD COME WITH CLEANER JUST PUT IT IN AND PLAY TO CLEAN THE LENS IF THE LENS IS DIRTY IT WILL ACT LIKE ALL CDS ARE TO SCRATCHED TO PLAY
Jan 19, 2010 | GoVideo Go Video DVD/VCR Combo
Disc won't load. Get
there a problem of the DVD disc...
try to insert another disc..
if "wrong disc" message appear again...
insert the Disc Cleaner of the DVD.. so that you can clean the lens surface of the DVD Player...
Oct 23, 2009 | Televison & Video
Won't read Dvd/Cd as loaded
It is a problem of the optical head being covered up by foreign particles obscuring the optical lens. Try using a CD/DVD cleaner disc which has double brushes and one add some solvent which comes along with the pack.Simply play it & keep ejecting and inserting the disc makes the disc to spin, till your player starts reading it..............................sodeep
Oct 06, 2009 | Coby DVD-224 Player
DVD player doesn't play when disk is inserted
may be a problem with your lens try DVD disc cleaner. This cleaner looks just like a disc with some extra little brushes on its surface. Some DVD cleaner kits even come with supplies to clean and modify scratches on your discs.
please leave a fixya rating
Apr 25, 2009 | Televison & Video
LITEON LVW 5001 doesnt recognize DVD's
Laser either dirty or starting to go.Try cleaning laser with commerical disc cleaner,put a drop of rubbing alcohol on brushing.Laser can be cleaned manually with a Q tip dipped in rubbing alcohol but this requires opening burner.If you do this MAKE CERTAIN ELECTRICAL PLUG IS PULLED,lasers cause nasty burns.
Some times the problem is just the brand of disc,some brands don''t work in Liteon's.
If laser is going the burner can be replaced.Most of the Liteon 5001's used Liteon 401s burners,411s or 451s dvd burners all will work.The dvd burners mount from the bottom PC burners mount from the side so they would have to be adapted,many PC burners won't work in these older liteons some freeze up the second you hit fast forward.
Jan 18, 2009 | Lite On LITEON 8X DVDRW +/- Burner
Dvd player on lite on not working
Try to buy a Head-cleaning disk and follow the instructions that comes with it on how to clean the player. Or ask a guide to use the CD lens cleaner.
After cleaning try using the drive... If not repeat cleaning process 3x
If it fails then the drive needs total replacement.
Good luck...
Jan 29, 2008 | Lite On LiteOn 16x Black internal oem DVD...
Lite On LVW-5045 DVD Recorder - won't record onto disc
Liteon lvw 5045 problem action failed.please consult our customer service for recovery. (error code: 0x810D0004)
Dec 11, 2007 | Lite On LVW-5045 DVD Recorder
Liteon LVW-5045gDL+ dvd recorder will not burn to blank dvds
SAME HERE. I Have tryed a lens cleaner and seems to be working at the moment
Oct 09, 2007 | iLO DVDR04
Lite On LVW-5001 DVD Recorder Logo
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
