For an HP Color Laserjet 4650n: Have an error code of 49.4401. Can you please advise?? Thanks. Charlie 973 903-7635
  • 2,632 Answers
Welcome to Fixya. You can try to use the steps below to fix the issue.
Power off and remove the formatter and reseat the Compact Firmware module. If that doesn't work try 'Initiliase Disks' to reset the firmware.
1. Power off the printer
2. Power on the printer and watch for the memory count in the display
3. When the memory count appears in the display, press and hold the Menu button
4. When all 3 LED's are on and steady, release the Menu button.
5. Press and release the Back/Exit button
6. When you see INITIALIZE DISKS, press and release the Green Tick button.
If error returns replace the Compact Firmware Module
If you have questions please let me know. Thanks for using Fixya
Posted on Apr 11, 2011
5120 code error
Any of these error codes (51.20 51.21 51.22 51.23) points to a failure with one of the laser scanner assemblies on the HP Color LaserJet 4610 an 4650 series. To solve these error codes, replace the corresponding laser scanner. Sometimes when the laser scanner fails you will also hear loud noises (often higher-pitched noises like screeching sounds); the noises can be another sign that the laser scanner needs replacing.
51.XY
PRINTER ERROR
For help press
alternates with
51.XY
PRINTER ERROR
A printer error has occurred.
X Description
1 beam detect error
2 laser error
Y Description
0 no color / black
1 Press to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and DC controller PCA
(J1009 - J1012).
4 Replace the defective laser/scanner
assembly. Calibrate the printer after
replacing the laser/scanner.
Mar 17, 2014 | HP LaserJet 4650n Printer
I have a error code 59.30 on HP laserjet 5550
here is the solution for your hp color laser jet 5550 printer
fbd1ddf.jpgThis will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 23, 2010 | HP Color LaserJet 5550hdn Printer
I have a HP 4650n and when I print there is line through the middle of paper or picture. Replaced cartridges and fuser. Not sure what to do.
Probable : Dirty paper Xport rollers
Possible : Main molibdene shaft scratched (if line always same position)
Feb 06, 2010 | HP LaserJet 4650n Printer
When trying to print on HP 4650 printer stops and displays 49.4C06 error code, how can I fix it? thank you
update the firmware first...if problem persists try removing the jetdirect card..if error goes away your jetdirect card will need replaced
Dec 16, 2009 | HP LaserJet 4650n Printer
Display reads "card slot not initialized"
Turn the printer on.
2 As the printer performs its power-on sequence, press and hold the PAUSE/RESUME (HP Color
LaserJet 4600 models) or MENU (HP Color LaserJet 4610n and 4650 models) button until all
three lights on the control panel are lit.
3 Press . The message INITIALIZE DISK appears on the control-panel display.
4 Press The printer initializes the hard disk and continues its power-on sequence.
Feb 26, 2009 | HP LaserJet 4650n Printer
Scanner error 6 for hp color laserjet 2840
After the hp color laserjet has finnished initiallizing it gives me error code 6
Dec 07, 2008 | HP LaserJet 3050 All-In-One Printer
Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Dec 05, 2007 | HP Color LaserJet 2600n Printer
21 people viewed this question
k24674
