Question about EnGenius EL-2611CB3+ Deluxe (EL2611CB3+DELUXE) Wireless Adapter
No connection. scenario: I am trying to route my internet connection to a buliding where my office is. It is about 1500 feet away. I am using two parabolic antennas and the wireless lan boxes. The cd info to me is very confusing, keeping in mind that I am not a computer guru or throughly literate in this kind of stuff. I think my biggest problem is trying to understand what needs to be an access point and or bridge.....?? what the heck? What makes sense to me is that where my cable internet comes into the house, does not this need to be the access point and my shop need to be the bridge? or access point here too? Am I wrong? Point to point? multi-point? I am getting a signal quality of usually 49 and communication of at least 60- 74, but it will not connect to the internet. Any suggestions are well appreciated. This is driving me nuts.
  • 481 Answers
You are trying to establish a point-to-point link between two buildings. You need one access point and one bridge. Technically, it doesn't matter which one you put at which end. Traditionally, you put the AP where the network connection is, because it makes adding future remote locations easier.
500 yards should be a cakewalk for this model.
Posted on Oct 28, 2009
I would like to get a fuel systems diagram that shows fuel hose routing for 1988 Kawasaki Vulcan 1500
Hi, Larry for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Kawasaki, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1988 Kawasaki Vulcan 1500 fuel line routing Google Search
Fuel lines and Air filters
http://www2.vulcanrider.se/DL/KawasakiVN1500_87-99ServiceManual.pdf
OEM parts for Yamaha
1998 Kawasaki Vulcan 1500 Classic Owner Manual
Nov 06, 2016 | kawasaki VN 1500 Vulcan Classic...
Tip
VPN in Microsoft Server 2003
The full form of VPN is Virtual Private Network. VPN gives extremely secure connections between private networks linked through the Internet. It allows remote computers to act as though they were on the same secure, local network. Allows you to be at home and access your company's computers in the same way as if you were sitting at work.
Almost impossible for someone to tap or interfere with data in the VPN tunnel. If you have VPN client software on a laptop, you can connect to your company from anywhere in the world. VPN goes between a computer and a network (client-to-server), or a LAN and a network using two routers (server-to-server). Each end of the connection is a VPN "endpoint", the connection between them is a "VPN tunnel".
When one end is a client, it means that computer is running VPN client software. You can use a virtual private network (VPN) to connect components to one network by using another network. VPN do this by "tunneling" through the Internet or another public network. With a VPN, connections across the public network can transfer data by using the routing infrastructure of the Internet, but to the user, the data seems to travel over a dedicated private link.
A VPN gives you the benefit of a dial-up connection to a dial-up server, plus the flexibility of an Internet connection. Using an Internet connection you can connect to resources all over the world. If you have a high-speed Internet connection at your computer and at your office, you can communicate with your office at full Internet speed. This is much faster than any dial-up connection that uses an analog modem.
VPNs use authenticated links to make sure that only authorized users can connect to your network, and they use encryption to make sure that others cannot intercept and cannot use data over the Internet. A Tunneling Protocol is a technology that helps make the transfer of information over the Internet more secure from one computer to another.
VPN technology also permits a corporation to connect to its branch offices or to other companies over a public network, such as the Internet, while helping to maintain secure communications. The VPN connection across the Internet logically operates as a dedicated wide area network (WAN) link.
VPN in Windows 2003 Server: You need a high speed Internet connection to configure and run VPN server. Two individual lan card must be present in a single system where you want to configure a VPN Server. The lan cards should ping each other. Also need a User which's Dial in allow access should be enable. Microsoft 2003 server two tunnelling protocols for a secure VPN connection, one is PPTP (Point-to-Point Tunnelling Protocol) which Provides data encryption using Microsoft Point-to-Point Encryption. The other is L2TP (Layer Two Tunnelling Protocol) which Provides data encryption, authentication, and integrity using IPSec.
Steps to create VPN Server in 2003 Server: At first I go to Start and point to Administrative Tools, then click Routing and Remote Access. Then I click the server icon that matches the local server name in the left panel of the console. If the Routing and Remote Access service was previously turn on, you may want to reconfigure the server.
To reconfigure the server Right-click the server object, and then click Disable Routing and Remote Access. Click yes to continue when you are prompted with an informational message. Then Right-click the server icon and then click configure and Enable Routing and Remote Access to start the Routing and Remote Access Server Setup Wizard. After that click Remote access (dial-up or VPN) to turn on remote computers to dial in or connect to this network through the Internet. Then I have Click to select VPN. In the VPN Connection window I click the network interface (Lan) which is connected to the Internet and go the IP Address Assignment window, then I click Automatically because there was present a DHCP server in network. However, if DHCP is not available, you must specify a range of static addresses.
If you use from a specified range of addresses, open the Address Range Assignment dialog box and Type the first IP address in the range of addresses that you want to use in the Start IP address box. Type the last IP address in the range in the End IP address box. Windows calculates the number of addresses automatically. After that I have accept the default setting of No, use Routing and Remote Access to authenticate connection request and finally Click Finish to turn on the Routing and Remote Access service and to configure the server as a Remote Access server.
For the remote access server to forward traffic properly inside your network, you must configure it as a router with either static routes or routing protocols, so that all of the locations in the intranet are reachable from the remote access server. It also need for security purpose.<SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Verdana','sans-serif
on Mar 22, 2011 | Microsoft Windows Server 2003 Enterprise...
My device routes me to major highways miles away to get to the destination even if I am only a few feet away
You are probably trying to navigate in car mode instead of off road. make sure you have they type of navigaion correct
Aug 05, 2014 | Garmin GPSMAP 60CSx
I have my internet Broadband connection in my office .And I want to share this broadband connection network into my home through WiFi . But the problem is that my home is almost 1 mile away from my office...
No. Wifi has a distance of 120 feet indoors and 300 feet outdoors in a perfect environment.
Even if you were able to install wireless repeaters for the wifi you will experience many networking issues.
If you wish to share your internet you may want to look into a mobile hotspot. You can take that device anywhere where the service provider is covering.
Dec 18, 2012 | Computers & Internet
I am having trouble with Microsoft Office Home and Student 2007
This article describes how to troubleshoot problems that you may experience when you try to activate a 2007 Microsoft Office application. Additionally, this article contains several methods that you can use to troubleshoot activation issues.
This article is intended for a beginning to intermediate computer user.
You may experience the problems in the following scenarios:
Scenario 1
When you try to activate a Microsoft 2007 Office suite, you may experience one of the following symptoms:
  • You receive the following error message:Your software cannot be activated because the product key you installed with is not valid. Please uninstall the software and reinstall it using a valid product key.
  • The activation process fails. Additionally, you receive a message that states that you have reached the limit on the number of computers on which you can activate the 2007 Office suite.
Scenario 2
When you successfully started a 2007 Office application and all functions worked correctly for you in the past, you receive an error message. The error message indicates that significant changes were made to the configuration of the computer. In addition to this error message, you may also experience any of the following symptoms:
  • When you try to activate the 2007 Office suite, the Activation Wizard disappears.
  • When you try to to activate the 2007 Office suite over the Internet, you receive a communications-related error.
  • When you try to activate a 2007 Office suite , the Activation Wizard does not start. Additionally, you receive no error messages.
Scenario 3
You try to activate the 2007 Office suite over the phone. However, after you enter the confirmation ID that the support staff supplied to you, you receive an error message. The error message states that the confirmation ID is invalid.
Scenario 4
When you successfully started a 2007 Office application and all functions worked correctly for you in the past, the 2007 Office application now runs in a reduced functionality mode.
Scenario 5
When you start a 2007 Office Trial version for the first time after you complete License Activation, the 2007 Office Trial version runs in a reduced functionality mode, and the Office Activation Wizard is displayed. Additionally, the following text is displayed:
2007 Office system is expired. In this expired state, many features of the version are unavailable until you convert to the full product. Click Convert to begin the conversion process.
Note This activation problem indicates that the Opa12.dat file is corrupt for the 2007 Office application. Scenario 6
When you try to obtain an activation key for a trial version of the 2007 Microsoft Office system over the Internet, you receive the following error message:The Microsoft Activation Assistant was unable to request your trial activation key
This issue is temporary until the updated version of Try Microsoft Office 2007 is available. Microsoft is in the process of updating Try Microsoft Office 2007 based on the January 2010 update for Office Word. For more information, click the following article number to view the article in the Microsoft Knowledge Base:978951 Description of the January 2010 update for Office Word
Oct 26, 2011 | Microsoft Office Home and Student 2007...
I want to buy a wireless network adapter USB. I do not have internet home, but there is a public connection that is a couple hundred feet away from my house that is public because it is a cafe. Can anyone...
A couple of hundred feet away may be too far for a good signal receiption.
You can increase your signal with an aerial.
You may need to go into the cafe or park yourself nexr door to the cafe.
Use Google to see what is available on the Internet.
Here are a few WEB sites for you to look at.
http://www.gadgetbuy.com.au/index.php?/office-gadgets/usb-802.11n-wifi-dongle-for-desktops-+-laptops-150-mbps.html
http://shop.ebay.com.au/sis.html?_nkw=USB+WiFi+Dongle+Desktops+Laptops+150Mbps+Wireless+Adapt
http://www.mobilefun.co.uk/usb-wifi-dongle-p11590.htm
May 02, 2011 | Computers & Internet
I cannot get to the internet
This might seem like a silly question, but are you in a location where there is access to the Internet? The system uses the 802.11 b/g WiFi standard, which means you have to be within approximately 460 feet outdoors, or 125 feet indoors of an access point to connect to the Internet. It's not like a cell phone where you can be miles and miles away from a cell and still have service. A number of well known fast food restaurants, bookstores, other businesses and libraries have free wireless Internet for their customers. So check around and give it a try where you know there is access available if you don't or aren't sure of access in your location.
Dec 24, 2010 | Sylvania G-Netbook
My belkin wont keep connection
1. Powercycle your equipment (unplug the power to your router and your modem)
2. Wait 15 seconds then plug equipment back in.
3.If your Modem runs off signal from a tower try and get more signal simply by moving modem closer to a window.
4.Check your connections to the modem and to the router, ensure the wires are plugged all the way in.
5.Using your wireless signal from your computer pc or laptop ensure you have sufficient signal you may have to move closer to the router, once in a while you will be to far from your router to have a good connection.
6. Make sure the ventilation slots on modem and router are not blocked.
7.Check to see how far your modem is away from any electrical equipment your modem should be away at least 3 feet away.
8. If you are able to keep connection directly plugged into your modem from your computer most likely there is an issue with the router, In this case you can always reset your router there may be a configuration error in your router, To reset simply press and hold reset button on the back of the router for approximately 15 seconds or until router restarts, Caution by resetting your router will reset back to factory default and your router will be unsecure once again.
9. When your are disconnected from the internet make sure that the Connection itself isnt still connected if your connection itself is connected and you are unable to get online you may need to renew your ip address. usually your ip address automatically renew's once the router and modem have been powercycled (unplugged and plugged back in) however you may need to manually renew your ip.
10.Windows Xp: Start/Run/CMD and press ok
A.Type ipconfig /release
B.Type ipconfig /renew
Windows Vista/7 Start/All Programs/Accessories/Right click on command prompt and hit run as administrator.
B.Type ipconfig /renew then restart your computer
If you are a Mac user:Here is a link to show you how to renew http://support.apple.com/kb/TS1920 If your continue to get disconnected contact your ISP (Internet Service Provider) Check and ensure that it is not an issue on there end
Nov 15, 2010 | Belkin (F5D5231-4) Router
Openvpn Network Connection
u can do that with IP routing or with default gateway. Try to give one default route for destination.
Mar 17, 2009 | Computers & Internet
IP phone to IP phone through an IP trunk Issue
Is this an IP office? If so, maybe try to untick the "direct media path" box in the extension tab.
Jul 07, 2008 | Avaya 4610SW IP Phone
EnGenius EL-2611CB3+ Deluxe (EL2611CB3+DELUXE) Wireless Adapter Logo
102 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
