Question about Ovens
Maytag Gemini, MER6772BCB. Top oven broil element blew, sparks, a little fire, right at the support. Shut everything down, Removed element, repowered unit, no display, no clock, no oven controls. Stovetop works, burners, but nothing else. Power is on, checked at connection on back of stove 220 V coming in. I can't see anything in the drawings or manual about a fuse or reset?
  • 2 more comments
  • terrym123 Apr 11, 2011
    I have not replaced the element yet, hopefully getting the correct part today. Can the dead display be a result of not having an element in place? I will try to determine if there is power at the display and inspect as close as possible, couldn't see anything from the open back of the panel though. Does the display/control operate on 120V or is it fed from the transformer at a lower voltage?
    Thanks, I can check that when I get home, is the relay external to the circuit board do you think?
  • terrym123 Apr 12, 2011
    It appears there is power at the timer so I guess the timer is the only option, unless you have any other ideas. Thanks for the help.
    When I enter the model number MER6772BCB and/or enter the part number from the parts list provided with the stove, (74004542) it crosses to this part number - CLOCK ASSY Whirlpool Corporation 12001661 in most cases. That's not the same part number you sent me, am I ordering the wrong part?
  • Ovens Master
  • 2,605 Answers
Hello, Welcome to FixYa. It won't matter as far as the immediare issue, but have you replaced the broil element yet? Now to address the dead clock/timer issue...does the timer have power going into it ? If YES, and there is no display and no other function, the timer is damaged. I would remove the timer at thst point (mark the wires, take a picture, something ) open it up and visually inspect the circuit board for burnt relays, diodes, and the like. Let me know what you find and I'll see what I can do. It sounds like a case of a damaged control though. Thanks for choosing FixYa and good luck. Regards, Macmarkus :) Regards, Macmarkus :)
Posted on Apr 11, 2011
  • 2 more comments
  • Mark MacDonald
    Mark MacDonald Apr 11, 2011
    Thank you for the reply Terry. The display itself does indeed operate at a lower voltage, usually 12 -24vDC via the transformer, however the timer as a whole should have 120vAC on terminal's L1 and 120vAC at L2 if you measure from either to the terminal marked "N" for neutral.
    The issue from the standpoint of not having the broil element should not have any bearing on those voltage readings, it will only show as an open broil element when trying to energize.
    I would hold off on purchasing a new element until you've diagnosed the timer since you will perhaps need to replace it as well, and the there's the issue of economics...at around $300 just for the timer control, is it worth it ? I'm sure it is compared to the cost of replacing the range, but it must be asked by yourself, it's your money.
    This is one of the downsides to electronic controls in my opinion...sure they're cheaper for them to make, but too sensitive to surges or shorted components. I wish the manufacturer would put some type of surge protection from the elements, but they know best :P
    Let me know what you find and I'll continue to help in whatever manner I can. Good luck.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Hello again Terry,
    Let me back up a second. I was just looking at a diagram for your range and there actually is a "double line break" coming off of L2 before going into the timer.
    So check the voltages to the timer, if it is getting proper voltage, you'll need a timer. However it may just be the "double line break" relay.
    If you don't feel comfortable doing this please call a pro. It must be done "live" so take caution.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Hey sorry for the delay, I'm actually out right now as well with only my iphone. I believe that relay will be remote from the main board. I will double check the schematic when I get home...though you may know by then.
    Regards,
    Macmarkus :)
  • Mark MacDonald
    Mark MacDonald Apr 12, 2011
    Hi Terry. Unfortunately it does point to the timer if there is voltage going into the timer.
    Check around for possible "rebuilt" or refurb. controls. Some places do offer them, but they are available new at most brick & mortar appliance part providers as well as on-line at places like "searspartsdirect.com" or "repairclinic.com" to name a couple.
    part number is 5701M403-60 and should include what's show here....
    Let me know how you make out or if I can help in any manner going forward. Good luck.
    Regards,
    Macmarkus :)
Broiler wont work on maytag oven
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
Apr 27, 2014 | Kenmore 30464 / 30465 / 30469 Gas Single...
What could be the problem when i put the oven on broil every thing is ok the top element come on ,but when i put it on bake only the bottom comes on
Hello, W/D here.
That's the way it is supposed to work. The top element comes on only for broil, but not for bake, and the bottom element comes on for bake, but not for broil.
Best regards, --W/D--
Feb 22, 2011 | Maytag Ovens
Electric Maytag Oven will not heat over 200 F
Check the bake element.(bottom Element).
It is likely burnt out.
Sounds like your only getting some pre-heat from the top(broil element).
Nov 26, 2010 | Maytag Ovens
Maytag gemini oven tough controls won't work --
Check the door switch and the temperature probe. If they are ok, then the problem is likely in the control board. These boards can be rebuilt.
Jun 26, 2010 | Maytag 24" Built-In Double Electric Wall...
Bottom element doesnt work in oven, but top does.
NOPE!
  1. Broil element does not have welded-on legs and will touch the bottom of oven, overheating itself and will end up the same way your bake element did; besides, the bottom of the oven will corrode pretty quick
  2. Many ovens use both elements during bake cycle
  3. self clean cycle uses broil element
  4. The bake and broil elements typically have different mounting brackets and screw holes ate in different places
  5. you'd have to cover the hole, left after removing the broil element, and insulate the wires, which went to broil element
  6. the ends, protruding behind the mounting bracket may have different length and different connectors. you may end up shorting the wiring to the casing, which may in turn destroy the control board if there is one
  7. Bake elements usually cost only $40-$60. No jury rigging required.
Hope this helps ;)
Mar 29, 2010 | Ovens
Oven takes a long time to preheat
If it's electric ... could be one of:
1. Bake or Broil element has gone bad. The Broil element is cycled on and off during Bake pre-heat, so if it is bad this would slow down pre-heat. Does Broil work OK? (If gas, may be ignitor problem).
2. Temperature sensor problem. Does the oven eventually get to the right temperature?
3. Control board failure. If #1 and #2 are ok ... we see the control board fail and cause these symptoms. If so, we may be able to help you, we repair control boards at
www.fixyourboard.com.
Sep 29, 2009 | Maytag Ovens
Thermador SC301T heating elements not working (top and bottom). elements look fine, oven turns on but elements stay cold.... any help would be appreciated. thanks, Tony
Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very center...it will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
Jul 09, 2009 | Thermador SC302T Electric Double Oven
Maytag oven top heating element won't come on unless on broil
You are probably going to find the lower heating element has failed. Your symptoms describe that failure exactly.
Reply back if you want instruction as to how to repair.
Feb 15, 2009 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
134 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
