Question about Smurf Village Send Smurfs
I have to buy lanterns but don't seem to have any to buy! What do they look like or should I be buying lamp posts?
I cant buy lanterns? Why?
Posted on Apr 20, 2011
Fluorescent lamp PL 9W 6500K (4pins) I ma looking for the fluorescent lamp for my Coleman rechargeable lantern
you can buy or order this from any store that sells coleman stuff... or online from coleman ...
Sep 05, 2017 | Coleman Camping, Backpacking & Hiking
How to change the battery for my 4345 coleman lanterne
There are two adapters for that lantern; one for the house and one for 12volt. You simply connect one of the adapters and it will power the lamp and also charge it. Those two adapters came with the lamp; if you don't have them you can contact Coleman to purchase replacements.
Jul 29, 2014 | Coleman 8D Family Size LED Lantern -...
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
I have a GE battery powered (4 D cells) camping lantern. It will not turn on. The batteries are new and have been tested. Is there a way to remove the fluorescent and check?
Fluorescent lamps need a high voltage in order to ionise the gas inside and make them light up..Torch batteries will not produce enough voltage alone so the battery voltage is boosted by an inverter that is incorporated into the torch or lamp body.
It is unfortunate but the majority of such lamp inverters use the cheapest, nastiest, flimsiest circuitry it is possible to use in such things and having taken a few lamps and torches (of respectable brands) apart and seen such things I find it easy to imagine they were thrown together in a far eastern handbag factory when there was a world slump in handbag sales.
When working correctly the inverter produces a voltage high enough to really surprise anyone touching the wrong parts but they do tend to be unreliable due to the usually low quality.
A handy person could conceivably persuade such a lantern to dismantle and check the switch and wiring and ensure the battery voltage is reaching the inverter but it would need electronic experiece to venture further into the reasons why it stopped working.
A replacement tube could be tried but they fail rarely and rarely do they operate long enough to actually wear out so buying a new tube is likely to be wasted money.
Aug 28, 2011 | GE SteelBEAM FluorescentLED Hybrid Lantern...
Why i cant buy lanterns in smurf village? Level 30
It took me forever to figure out, but the "lanterns" are two poles (striped red and white like a candy cane) with three little lights on them. Two are square, one is circular. They are $1500.00.
Apr 20, 2011 | iPhone Apps
I can't figure how to change the battery on this hardcase lantern took off the rubber surrounding the lantern face, but nothing else seems to come off without unscrewing, But seems like those sre rivits...
I've owned this flashlight for years. In the comment above, ignore the instruction to remove the rubber casing around the lamp area. Simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Apr 05, 2011 | Energizer Eveready TUF4D1E 4D Cell Lantern
I cant get any petrol to pump into the mantles
If the petrol doesn't come through first check that you have enough in the tank. If the tank is not full enough it won't come through. If it still fails to come through it's likely that the generator is blocked. This is the tube which the mantle sits on and it has a very narrow opening to force the petrol to convert to vapour when it's warm. Try heating it for a while and it may clear it. Otherwise you'll need to buy a new generator.
Note: while the dual fuel lanterns can burn petrol you should be aware that it gives off poisonous fumes, like cars did before they had catalytic converters. The lantern should not be used indoors with petrol. They are safe with coleman fuel. If you live in the USA, Coleman fuel is cheap but if you're in Europe it's much too expensive. Rather than buying a new generator, if you live in Europe, you could buy a parafin burning lantern like the Petromax 500 available from http://www.pelam.de/index.php?cPath=28_31&language=en&gclid=CIOe46DQnqYCFQkf4QodQxz2Zg
and other sites, or you can pick up second hand Optimus lanterns on Ebay. Both burn parafin, though they need to be primed, and provide at least as much light as the Coleman.
Jan 03, 2011 | Coleman Northstar Dual Fuel Lantern
In the Coleman 5312 Retro Series Lamp is it supposed to work off the mains charger even if the battery will not charge. Battery is confirmed dead but lamp will not work on mains nor on 12v car lead. Don't...
Brentonb, In the event that you don't get a direct answer (which is likely, since this is a pretty obscure question) I suggest you troubleshoot it this way. Remove the bad battery. Use the charging device that came with the lantern and wire it temporarily to the device in place of the battery. This will supply the correct voltage, but takes the possibly shorted battery out of the circuit. If you are certain you have the polarity correct and you know that the charger works, then you have your answer. good luck.
Dec 03, 2010 | Coleman Retro Rechargeable Battery Powered...
Westinghouse 64832 pole lantern specs
A standard lamp post is 3 inches diameter. The base of the lantern slips over the post. It's inside diameter is slightly larger than 3 inches and a screw is used to tighten the base against the post.
Nov 07, 2009 | Westinghouse Electric Westinghouse 64832...
Smurf Village Send Smurfs Logo
700 people viewed this question
Top Smurf Village Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you a Smurf Village Facebook App Expert? Answer questions, earn points and help others
