When I change the time on the clock in the Daf truck I can change the hour but cant seem to be able to alter the minutes
  • 55 Answers
SOURCE: Change Time
Setting the minutes involves the same steps as setting the hours. You press and hold the "Select" button for a few seconds until the screen reads: "Clock H", "Clock M", "SCM Link", "Level", "Area" or "Line In". To set the minutes, push the "Track Up/Track Down" button until "Clock M" is highlighted on the screen. Once "Clock M" is on the screen, you turn the volume up or down to set the minutes. Once the hours and minutes are set, hit the "Select" button again and the clock will start. Hope this helps...
Posted on Sep 03, 2008
  • 260 Answers
SOURCE: 2005 dodge durango how do i change the minutes on the clock?
look for little black dots located on face of radio top is hours bottom mins
Posted on Apr 14, 2009
SOURCE: BMW R1150RT
only displays military time
Posted on May 22, 2009
SOURCE: setting time on clock
Press "Title" until time is displayed. Then press and hold "Title" for a few seconds until time is displayed. Turn the silver knob to change the hour, after hour is set, press the silver knob to activate minutes. Turn sliver knob to change minutes. Press silver knob to end.
Posted on Oct 20, 2009
  • 10406 Answers
SOURCE: two clocks are set at 6am one clock gains 30
Compute the difference in clock-speeds, namely 90 seconds per hour.
Convert the units of time: 30 minutes becomes 180 seconds.
So, divide 180 by 90 to get '2', namely 2 hours after the 6 o'clock "start" time, which makes it 8 PM.
P.S. There is at least one error in the above solution. If you truly understand the solution, make the necessary correction, and submit the corrected "homework" to your teacher.
Posted on Jan 07, 2010
I caNT SEEM TO PROGRAM OR CHANGE THE TIME . HOW DO I DO IT
Page showing Woods timers and models:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment with specific model number and I will help.
Instructions below are for Woods 59203 24-hour digital timer:
Plug timer in until battery is recharged.
If display will not show, then timer battery is dead and needs to be recharged, or timer may be broken.
Set current time:
Press and hold CLOCK button.
Press HOUR and MINUTE to set correct time with am and pm.
Press Day button to set current day.
Release clock button.
Program timer:
Press PROGRAM button until "1 ON" displays. This is program1 ON.
Press MINUTE and HOUR buttons to set ON time for program1
Press DAY button to choose day or group of days for program1 ON
Press PROGRAM button until "1 OFF" displays. This is program1 OFF
Press MINUTE and HOUR buttons to set OFF time for program1
Press DAY button to choose day or group of days for program1 OFF
Press PROGRAM button until "2 ON" displays. This is program2 ON.
Repeat steps above to set ON and OFF time for 5 programs.
When programming is completed, press CLOCK button to exit programming.
Press ON/AUTO/OFF button until Auto displays.
Nov 27, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
How can i reset the clock?
Hi
With regard to setting the clock. Press and hold m
MENU BUTTON for 2 seconds. The display shows ADJUST CLOCK. Press
the SEEK/TUNING control to change hour setting. Press the MENU
button briefly which will to change th minutes flashing. Press
SEEK/TUNING control to alter.
Hope this helps
Mar 31, 2010 | 2003 Jaguar S-Type
How do I set the clock on a room tech beingz
There is a switch on the back to set time, alarm, or display time. Select the switch to time set first. Tap top of unit to toggle between settings blinking display is the one to be set. Change it bi tapping on the sides ( ) or(-) don't forget the 12 hour display or military 24hour. Switch back to clock display when hour and minute display are both blinking or the setting will not take effect
Jan 26, 2010 | Hasbro Room Tech Beingz Alarm Clock Radio...
Want to chnage time on digital clock
Dear Sir!
Beside the digital clock must be 2 switches, one is for hours and the other is for minute, if it is not when the time is 12:00 take out the clock fuse and enter it again the time will be automatic 12:00.
The clock fuse is under stearing wheel.
Hope to hepled you.
Mustafa, Kabul Afghanistan
Apr 26, 2009 | 2003 Toyota Corolla
Apr 14, 2009 | 2005 Dodge Durango
Need help changing the time on my clock
hi from uk to reset clock ? there are two buttons/stalks? on the speedometer clock the left one is for trip reset and the right one is for clock reset/alter time to alter twist left for hrs reset and right for minutes it springs back to neutral when you let go hope this helps ?
Jan 27, 2009 | 1999 Hyundai Accent
Cannot set clock on my JVC KD-G335
You need to hold the sel button down for a little while then it will change displays thats when you use youe right seek button until you hit the Clock H to change the clock hour or Clock M to change the minutes when you hit it you use your volume control button to change the time.
Jan 04, 2009 | JVC AM FM CD DET FACE CAR STEREO
Changing time on the clock
from the owners manual.
Setting the clock
To set the hour, press the hour (h)
control and press:
² (+) to increase hour and
² (−) to decrease hour
To set the minute, press the minute
(m) control and press:
² (+) to increase minutes and
² (−) to decrease minutes
Nov 21, 2008 | 1999 Ford Escort
Resetting clock
Press the SET button until you cycle through the alarms and the Colons on the time start to flash. use the right and left arrows from the CD buttons to adjust time; After time is set; press the SET button. Be careful to not fat finger and hit the CD button when pressing the SET buttons. That will turn on the AWFUL NAP timer. That's another headache.
. Stop the Nap alarm Press NAP to start NAP flashing. Press and hold NAP to cancel the nap setting. If this does not work; try again. It seems to take me a time or 2 to get it to work.
Feb 04, 2008 | GE 74801 Clock Radio
Computers & Internet Logo
490 people viewed this question
David Payne
David Payne
