The dvd-drive worked properly a long time but now there is no cd/DVD-drive in the explorer and there is a yellow exclamation mark sign behind the drive in the device manager. Even I asked the system to find new drivers it says that's impossible. I think I need the drivers to reinstall the drive. R.Ruhwinkel
    Master:
  • 341 Answers
Download the drivers and install.
If it was helpful please rate or token of appreciation will be esteemed and facilitate this service.
Posted on Apr 11, 2011
My toshiba l-550-00f dvd burner is not working properly
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
Aug 31, 2012 | Computers & Internet
My dvd cd tower is not working
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Aug 06, 2012 | Computers & Internet
My hp laptop lost the cd/dvd
The drive is likely dead. Time to have it replaced or buy an external CD/DVD drive that connects via USB.
Jul 14, 2012 | HP Computers & Internet
Cd stuck in emachine and there's no pin hole
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope it helps
Jun 15, 2012 | E-Machines emachines (emachinees) CD-ROM...
Cd/DVD ROM Isnt working properly what can I do on a Acer Aspire 4315
you have not stated the problem could be registry if you cant see your cd/dvd rom drives
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 24, 2011 | Computers & Internet
My drive is HL-DT-ST DVDRAM GH20NS10. the dvd drive is working properly[reading & writing] with disks which are full or partially full.but it is not reading or writing a BLANK DVD. What should i...
is it a cd/dvd rw
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jun 22, 2011 | Computers & Internet
Windows7 on ASUS 1018P netbook wont recognize HQRP external CD/DVD drive.
make sure the leads that are attached to your external cd/dvd are securely seated and are not faulty
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
Jun 17, 2011 | Apevia HQRP?® USB 2.0 External Slim DVD /...
My cd drive writer 640c won't work, I check the device manger and it had a Exclamation sign in yellow by it
HI,
open device manager, right click on cd-dvd driver with yellow ! mark and select uninstall
it would be disappeared.
then open the following Fixit software weblink and run it
http://support.microsoft.com/kb/929461
restart computer, yellow !mark would be gone ..
issue resolved :)
May 26, 2011 | Computers & Internet
Dvd does not work. Light blinks but not seeing it . is there a driver i need or what do i do to fix this
You must determine if the problem is the media you are using (CD, DVD) or the drive itself. (CD/DVD Rom)
First see if the driver is installed for the CD/DVD ROM by Right clicking My Computer and choosing Properties, Hardware, Device Manager. Clikc the plus sign next to DVD/CD Rom Drives to see if there is a yellow exclamation point, or question mark. This means you need to install the correct driver. If there are no yellow exclamation marks or question marks your driver is installed properly.
Next try playing difffernt CD's to see if any of them work. Confirm they are good CD's by playing them on another device, then try them on your Compaq. If the Cd's play on another device you may possibly be experiencing read errors on the CD/DVD Rom drive. Try using a CD Laser Cleaner that will clean the laser head of the CD /DVD Rom. it looks like a CD with small brushes on the music side. This may solve a read error problem. if that does not solve your problem you may need to replace the CD/DVD Rom drive.
Jun 14, 2009 | Compaq Presario Notebook
DVD and CD drives not working
Drive may need a firmware update. If you have internet access then go to drive's manufacturer, and check for an update. There could also be a drive configuration problem, need to see if drives are recognized, by the system.You can right click my computer select explore and look for drives or go to settings, control panel right click system, open, then hardware, device manager. Then look for cd and dvd drives. If you see yellow exclamation marks or question marks then updates drivers. This is a start, try to see if the drives recognized.
Dec 16, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
