Question about Frymaster Dean GF14-SD Deep Fryer
I got a dean that that is for natural gas and now I need to use propane...does it have to be re jeted or can I adjust the regulator or something
  • Frymaster Dean Expert
  • 683 Answers
It will be safe if you use a Conversion kit from natural gas to propane. The kit consists or burner and pilot orifice which has smaller holes compared to the natural gas orifice, gas valve spring which is thicker than the natural gas spring, and ann instruction manual. You can visit the frymaster website and ask the local dealer on your country for the conversion kit.
Posted on Apr 18, 2011
Replaced gas valve on oven. can't seem to adjust flame. Baffle wide open. large yellow flames. How can I tell if this valve is for Nat. gas. I have prop.
Too much gas or to little air or both with orange flame.
Check to make sure all pipes and airways after regulator are clear.
If you are sure air mix is max than you need to check how much pressure is going in and coming out of gas valve there is typically a port on valve to do so. You need a manometer to do this. In a pinch you can make one check internet..
For propane you should be getting 9 to 11 inches water column depending on BTU of oven.
Typically natural gas controller/regulator is less 4 inches wc in which flame would be very small if it was set up for propane and you installed natural gas regulator.
Jan 14, 2015 | Eaton Nc-1425-5a Gas Valve
I have a Sears gas range that doesn't burn right. Yellow flames leave the bottom of my pans black. Ther is no fuel/air mixture adjustment. I have changed the gas regulator and LP gas bottle and no change
If this is new or you just got it used and put it in and noticed the problem I am guessing that it is ported for natural gas instead of LP or Propane. The majority of gas ranges are setup to use Natural gas when delivered unless specifically ordered for Propane. If you have had it for a while and it worked fine before then this might not be the problem something else has gone bad like a pressure regulator or a line got bent affecting pressure.
If it is ported for Natural gas and you want to use propane then most companies sell a conversion kit that will make it work right.
Mar 17, 2014 | Kitchen Ranges
30000 btu reddy heater is throwing flame way out of the heater
The gas pressure is way to high... you need to adjust the regulator to a low pressure or replace the regulator...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Dec 10, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
Switched from natural gas to propane now oven flames up sides how do I fix? Model#362.75571691
Propane and natural gas are two different fuels and require adjustments to the appliances to which theye are connected. Typically, when converting to propane from natural gas, a pressure regulator and a change in gas jets are required. This is because propane has a different heating value (hotter) and behaves differently.
Also, propane doesn't burn as cleanly as natural gas so after you have made the hardware changes, if you start to smell something in the kitchen, you may need to crack a window slightly to provide for better venting.
Please be careful
Jan 01, 2010 | Kenmore Kitchen Ranges
Ge propane kitchen range changed to natural gas.can't get the ove
Hi, Did you flip the cap on top of the regulator? As far as adjusting the bake/broil orfices, all you will nee to do is turn them 2 full turns counter clockwise. Start the oven and watch the flame. It should have blue tips as much as possible.
You might have to raise or lower the orfice adjustment as needed.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How do you adjust flow regulator in gas oven
how do I adjust my regulator on a gas range
Dec 02, 2008 | Kitchen Ranges
Natural Gas to Propane
Hello
Yes you will need to buy the orifice to convertit to propane.
After you install the orifice, you will need to also adjust the manifold pressure with a monometer. And you will also need to put the stickers on the gas valve that will state that this unit has been converted for use with propane. If you have any other questions feel free to comment back.
Thanks
Apr 20, 2008 | Frymaster Dean 2424G Deep Fryer
Dean deep fryer
need to change from natural to propain sr42 g
Oct 08, 2007 | Frymaster Dean SR42G Deep Fryer
Frymaster Dean GF14-SD Deep Fryer Logo
306 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
