Question about Acer AL1916W 19" LCD Monitor
Input Not Supported
I have Acer in Safe Mode, but cannot eliminate "Input Not Supported from rotating on my screen. Even with Safe Mode - it doesn't remove it
    Champion:
  • 221 Answers
You need to go into display settings, click advanced, and then click the monitor tab, and change the hertz setting to 60 HZ
Posted on Aug 07, 2008
Input not supported acer x193w
Hello Shaul
Hints:
1) Change to Plug and Play monitor driver
2) try changing the screen resolution on the PC, and driver.
3) try changing to 60Hz the refresh rate of the monitor on driver section or options on the monitor driver.
Carl
Apr 05, 2016 | Acer X193W LCD Monitor
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
Sul monitor Acer AL1515 compare Input Not Supported
When a monitor displays "Input not supported", the display resolution is set too high. To resolve this, change the resolution to a supported resolution of the monitor. What you can do is restart your computer to safe mode first. These are the steps going into safe mode:
1. Make sure your computer is off.
2. Turn on computer then tap F8 repeatedly once per second. Similarly, Windows advanced options menu should be up on you screen.
3. use arrow keys to highlight "safe mode".
4. press enter twice.
5. log on to your user profile
6. you will get a window asking you to press "yes" or "no". CLICK the YES button.
7. perform the next steps below according to your windows version (operating system)
In Windows XP
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
  2. On the Settings tab, under Screen resolution, drag the slider to the desired resolution and click Apply.
  3. When prompted to apply the settings, click OK. The screen will turn black for a moment.
  4. Once the screen resolution changes, confirm the change by selecting Yes. A timer will count down for 15 seconds to ensure the change is desired.
    Click Yes to confirm the change; click No or do nothing to revert to the previous setting.
In Windows Vista
  1. Press the Start button , select Control Panel, select Appearance and Personalization, select Personalization, and then Display Settings.
  2. Under Resolution, move the slider to the desired resolution and click Apply.
NOTE: For Windows 7, it should be similar to the steps for Windows Vista.
Jan 16, 2011 | Acer X193W LCD Monitor
Input not supported on my screen I have a Acer P191W monitor
your resulition is set too high. to fix this you need to either change it on another screen if you have one or restart your computer into safe mode. usually in safe mode it will be on the lowest setting and you will have full access to change it from there.
Jun 30, 2009 | Acer P191WBD LCD Monitor
Input not supported icon shows up
Is there a reset, restore button on the monitor? If so, press it.
If this doesn't solve the problem, start Windows in Safe Mode by pressing on the F8 key as it is booting. When you get the black & white menu, choose safe mode. You should be able to change the resolution to a really generic one (like 600 x 800) here to allow you to start over.
You may have set the refresh rate incorrectly in the display screen, too.
Jan 30, 2009 | Acer X193W LCD Monitor
Input not Supported
Run in safe mode and try to change the screen resolution to 800x600 and reset your machine.
Oct 27, 2008 | Acer V193w LCD Monitor
INPUT NOT SUPPORTED
Start your Windows in Safe Mode (pressing F8) during boot process and adjust your Display Settings to a lower resolution.... say 1024 x 768. Once fixed, you can play around again increasing the resolution a notch at a time. Fix ya!
Aug 28, 2008 | AOC A15X221 15 in. LCD Television
Input not supported
Vista Driver perhaps required
Try Acer Website
Jun 13, 2008 | Acer AL1916W 19" LCD Monitor
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
502 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
