Question about Vacuums
I just replaced the upper knife on my pfaff coverlock 4862 serger and cannot get it to trim while I serge,
How do you remove front driver side door panel on a 1997 ford club wagon
Open door, remove handles, arm rest etc. then door panel screws and then with a thin blade tool like a putty knife or a proper trim panel tool feel out where the internal fasteners are and pop them out with a force pushing the panel away from the door.
Oct 04, 2014 | GE 1997 Ford E-150 Econoline Club Wagon...
What is the difference between a sewing machine and a serger?
Well..... A serger (or overlock) sews a different, and usually more complex stitch. Where a sewing machine usually only uses two threads to make the stitch, a serger can use two, three, four or even five threads and will sew around the edges of the work piece, as well as trimming the edge of the work just ahead of the sewing area, or as you feed the work in, the trimming takes place first. Sergers also make a stronger seam, attributable to more thread / stitching in the seam. Sergers are versatile and quick, but one drawback is the fact that sergers make a chain stitch instead of a lock stitch, like a machine with a bobbin, and lock stitches can be pulled out, like the stitching that used to close dog food bags and bags of charcoal. A lock stitch is just what it sounds like, it can't be pulled out. You only get a lock stitch with a machine that uses a bobbin, and sergers don't use bobbins. That fact makes serging desirable for the speed of production. Changing bobbins takes up a lot of time, even if you are using pre-wounds. Hope this helps!
Sep 10, 2011 | Vacuums
How to replace the sewing bulb on a Pfaff 97
A Pfaff is a Sewing Machine, not a vacuum. Here's a link for the instruction manuals. sewingonline.co.uk/pfaff-manuals.html
May 28, 2011 | Vacuums
I need to replace the electric cord and need to know how to take out the old one a replace it.
First remove the handle from the machine and remove the plastic trim around the switch button. There are two screws holding the trim piece in place. Next insert a small flat screwdriver into the small slot on the trim piece are pry up to pop it off. There is a cover over the bottom of the cord where it plugs into the side of the motor unit. Remove the screw holding it in place and push it gently forward to disengage the tab along the back edge. The cord plug then pulls straight out to remove the cord. Push the new cord into the motor unit, and re-install the cord cover. Hook the bottom of the cord cover into the machine first, then insert the grommet on the cord into the opening at the upper rear of the cover. Push against the rear edge of the cover with a flat screwdriver to snap it back in place and replace the screw. Lastly, the switch trim plate can be replaced.
Apr 19, 2011 | Kirby G4 Bagged Upright Vacuum
Do you happen to have the service manual for the pfaff 118? We corrected the straight stitch timing but can not do the zig zag timing. Can you help?
http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf
This is the webpage where you can download the pfaff 118 .pdf manual.
Handie Andie
Mar 22, 2011 | Vacuums
How do you get to the fan on the generation 3 kirby
First remove the handle, next remove the screws attaching the cord, and switch trim plate. The small screw and knob on the handle pivot must be removed to remove the switch trim piece - insert a flat screwdriver into the small slot in the plastic and pop the trim off to expose the rear motor shell screws. Remove the four screws holding the upper motor shell in place to expose the fan housing screws. Remove the five screws holding the fan housing in place, noting their positions. Pry the fan housing off to expose the fan. Hold the fan in place while turning the belt pulley CLOCKWISE to remove it. If the armature turns, it must be held in place with an open end wrench (about 9mm). There are flat spots on the armature just in front of the commutator bars. Pull or pry the fan and associated washer off the armature shaft. After replacing the fan and pulley, put a bead of silicon sealant on the fan housing and replace all parts in reverse order of removing.
Dec 01, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Vacuums Logo
53 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
