Question about Sony PlayStation Portable (PSP) Console
Psp non-responsive My psp was on 5 minutes ago then the screen went dark, the green power light is still on and i can still adjust the brightness of the screen but the system wont respond. Can someone help me please?
    Problem Solver:
  • 9 Answers
Check out the guide at http://www.squidoo.com/psp-repair They can probably help you.
Posted on Aug 07, 2008
My psp is cracked with lines all over
When i try to open my psp,my screen do not show any respon..i just can see it when i get to closd to psp screen..its to dark..plz help me sir..tq.
I would say the back light went out if you can see the screen but very dark. Unless you haven't tried adjusting any video settings it may have.
Apr 02, 2013 | Video Game Consoles & Games
My sons psp has a black screen
Without a functional screen, the PSP doesn't have much of a purpose. If the power light next to your screen is off as well, all your PSP needs is a good long battery charge. But if the power light is on and the screen is still dark, a few quick troubleshooting steps can help you get to the root of the problem. If troubleshooting doesn't work, you will need to contact Sony eService through its support site, particularly if your PSP has recently been dropped or had liquid spilled on it.
Step 1Turn off your PSP. Remove the battery pack. Replace the battery pack, making sure that it is securely inserted. Turn the PSP back on. If the screen is still black, continue to Step 2.
Step 2Press any system button. If the backlight is turned off, pressing a system button should reactivate it. If the screen has turned back on, go to the PSP settings menu. Select "Power Save Settings." Select "Backlight Auto-Off." This option automatically turns off the screen if the PSP has been idle. If you do not wish to have this feature active, select "Off." If this step did not solve the problem, continue to Step 3.
Step 3Press the screen brightness button below the screen. This button is marked with a small donut-like icon. Pressing the button will incrementally increase the brightness of the screen. Holding down the button will turn off the backlight. It is possible that this button was accidentally pressed down after placing the PSP in a pocket or a backpack. If the screen remains black after the brightness has been increased to full, continue to Step 4 if your model of PSP is any but the PSP Go.
Step 4Open the top hatch on the PSP. This will eject the UMD disc. Only touch the UMD at the edges, as fingerprints can interfere with the disc's functionality. Clean the surface of the UMD with a clean, dry cloth. Do not clean the UMD with water or any other chemicals. If the disc looks scratched or damaged, this is likely the cause of the screen issue. Additionally, moisture can condense on the UMD if the PSP has undergone a recent temperature change, such as being brought into a warm house from a cold car. If the UMD looks wet, turn off the PSP and allow the UMD to air dry. Wait several hours before trying to restart your PSP.
Dec 27, 2011 | Sony PSP (Piano Black)
Im using psp 3001 with version 5.03 PROME-4...Ads by GoogleInflatable Movie Screens www.OpenAirCinema.usSeamless, high quality screens Portable, washable, outdoor screens By richmond_sic on Mar 07,...
You should have not installed ChickHen in your PSP 3001 since there are no known ways so far, not even by Dark Alex, to fix it from "Brick"-ing. YOur attempts to remove the battery and so on to fix it is futile because even Pandora Battery and Magic Memory Stick won't work on those versions of PSP.
Try sending it to S0ny...
If you intend to buy a new PSP, either buy those Slim that is version 2000 and those that are NON (remember NON) TA088v3 MoBo. From this MoBo onward to PSP 3000s, all is unhackable and cannot be fixed from Brick.
May 31, 2011 | Sony PSP (Piano Black)
Psp fell ,turn psp on.green light turns on.screen stays off
Hi first i will say sorry for that. I will recommend that you see a certified technician to fix it up, there are a few things i guess are wrong with your psp... the system of psp are fragile and should be handled with care because i think one or more parts are broken and need replacement. Cheers
Dec 23, 2009 | Sony PlayStation Portable (PSP) Console
PSP Power light is green but screen is black
BIOS is corrupted on the mainboard inside of the PSP. Unplug the battery and also unplug the ac adapter.
After about 5 minutes plug up just the ac adapter and turn on the psp and see if you get video of any kind. If you can't get into any menus or any video to come up then your motherboard is corrupted and would need to be replaced. Hopefully if your psp is still convered under warranty you can get a replacement.
Jun 29, 2009 | Sony PlayStation Portable (PSP) Console
Back light does not work on board
All You Need To Do Is Press The Small Square On The Bottom Of The PsP
Feb 24, 2009 | Sony PlayStation Portable (PSP) Console
PSP green power light on but screen stay black
Need more info but are you sure you didn`t press by mistake the brightness button? Try to press it again...
Sep 14, 2008 | Sony PlayStation Portable (PSP) Console
Psp
If the PSP works correctly when the power adapter is plugged in but not when just running on battery then yes, you need a new battery.
Also triple-check that your PSP's screen brightness is turned up all the way (hardware buttons along the bottom of the screen.)
Dec 18, 2007 | Sony PlayStation Portable (PSP) Console
Psp green light on but now screen
Try Holding the R trigger and turn the power on at the same time. This puts you n a diffreent mode, then press the display brightness button to see the version. Power off and back on agin to see if that resets it. This is only a guess I would appreciate at least a thanks for trying.
Nov 04, 2007 | Sony PlayStation Portable (PSP) Console
Power problems
Hi Gohan102,
Open the battery compartment, and remove the battery.  Look at the bottom inside corner for a little square sticker with has marks on it. is it dark or light,  If it is dark, your PSP has come in contact with moisture. I suspect that your PSP has gotten wet or damp.  If the sticker is dark, you need to keep your battery out for about 2 days, and keep the UMD door open and the whole PSP kept in a dry environment.  Try it after 2 days of drying to see if it is recovered. Good luck Gohan....
Oct 17, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
56 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
