Question about Intel D945GCZ Motherboard
Curcuit digram of vrm section - Intel D945GCZ Motherboard
    Master:
  • 341 Answers
Dell precision 470 work station processor fans over speed
Dell Support > Precision 470 Workstation Desktop PC > Users Guide,
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/index.htm
Tools to Help Solve Problems > Diagnostic Lights,
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/advtrbl.htm#wp1057482
"A possible VRM 0 has occurred"
VRM = Voltage Regulator Module
Here is what the motherboard looks like,
http://www.ebay.com/itm/DELL-PRECISION-Workstation-470-XC838-Motherboard-with-2GB-/140795014004?pt=Motherboards&hash=item20c8096b74
[Note* Posted for photo reference only. Not for advertising.
Besides, I do not see any VRM's plugged in. Means you get the motherboard only, and no VRM's. You need a VRM ]
What the Voltage Regulator Module looks like,
http://www.thebestpartinc.com/kg229.html
(Again, not for advertising. Click on the photo of the VRM to enlarge)
Notice that your motherboard has two VRM's. This is because there are two Processors.
Apparently the VRM for one of your Xeon processors is bad. (Z-on)
Since it states VRM -> 0, it is for the Processor 0, or in the number 1 processor socket.
What does a Voltage Regulator Module do for a Processor?
Regulates voltage.
A Processor MUST have a steady, 'clean' supply of voltage, AND it must be within the voltage range for the processor.
Since the motherboard uses an Intel E7525 motherboard chipset, it can support Intel Xeon processors, with up to an 800MegaHertz Front Side Bus. (800MHz FSB)
Looking at a typical Intel Xeon single-core processor, with an 800MHz FSB, let me show you it's voltage requirements,
1.287 to 1.400 (DC)
May be just a bad VRM.
However, I would also like you to look at the Electrolytic Capacitors on the motherboard. From what I have seen, those motherboards are notorious about having capacitors go bad.
Visual identification of bad Electrolytic Capacitors,
http://www.capacitorlab.com/visible-failures/index.htm
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 09, 2012 | Dell Computers & Internet
Diagram of vrm section
Intel D845GVSR,
http://www.ebay.com/itm/Intel-D845GVSR-Socket-478-Motherboard-Gateway-E-2100-/380449645479?pt=Motherboards&hash=item589490e3a7
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d845gvsr
Doesn't have a Voltage Regulator Module.
It has a motherboard voltage regulator circuit. It is integrated into the motherboard, not a separate module.
You will have to find the components, in the motherboard voltage regulator circuit, yourself.
How?
http://www.hardwaresecrets.com/article/616
http://www.hardwaresecrets.com/article/How-to-Identify-Japanese-Electrolytic-Capacitors/595
http://www.mouser.com/Passive-Components/Capacitors/Aluminum-Electrolytic-Capacitors/Aluminum-Electrolytic-Capacitors-Leaded/_/N-75hqw/
Radial Aluminum Electrolytic Capacitor
http://www.youtube.com/watch?v=KN6_-8fYHo0
Starts at 0:04
Electrolytic Capacitors are the weakest link in the motherboard voltage regulator circuit.
Part of what the motherboard voltage regulator circuit does, is to regulate voltage for the Processor.
Just like a VRM does.
A Processor has to have a steady, 'clean', supply of voltage, and it MUST be within a VERY small tolerance range.
Cannot be too much, or too little.
Regards,
joecoolvette
Jun 28, 2012 | Intel D845GVSR Motherboard
Processor not heating
Check 12 Volt Motherboard VRM Section, Next Checek VRM Upper Mosfet or lower Mosfet one of them may b short.
Mar 08, 2012 | ASUS P4P800-MX Motherboard
Its not booting and the Leds VRM and NMI are with amber color
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
Apr 25, 2009 | IBM eServer xSeries 346 8840 (884022U)
4 pin plug 12volt on the motherboard.
pls you have to identify which area is short circuit, there for remove the 4 pin plug and power on. of power on ,it is telling your cpu section (VRM Circuit is short) it may faulty cap or transistor , bit I found more than 80% is shorted north bridge.
it was not fixed. but you have to test all coils to identify which section mos fets are short, remove the cpu to isolate north bridge , check vrm circuit,
images?q=tbn:and9gctvnhhmvqm60iuldruuri-bndxickpzhgxm7juwfsizc3gdj9_-4a
Aug 26, 2017 | Intel D945GTP Motherboard
Adding second CPU
Hi
Did you receive a VRM with the the PRC upgrade kit? And have you installed it?
The following items are/should be included in a microprocessor upgrade kit:
• A microprocessor (PRC)
• A heat sink
• Heat-sink retention clip(s)
• A voltage regulator module (VRM),
Your upgrade kit may also include a cooling fan.
If you are adding a secondary microprocessor, examine the VRM to ensure that it is the correct VRM for your system. Install the VRM in the appropriate secondary VRM connector, ensuring that the latches at each end of the connector engage. If you received two VRMs with the upgrade kit, replace the primary VRM already installed in the system with one of the VRMs from the upgrade kit.
Note: The system does not support mismatched VRMs.
Check PE1600sc Microprocessor Upgrade Installation Guide - http://support.dell.com/support/edocs/systems/pe1600sc/multlang/proc/9D904A05.pdf
Let me know how you get on
Mike
May 13, 2008 | Dell PowerEdge 1600SC Server
No Display
you should check vrm section &cmos jumper & ram & cmos battery&bios
Apr 15, 2008 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
The vrm for my 3500m20
i am using a compaq vrm for my 3500 m20:
the number is:
320266-01
spare:329267-001
this one works!!
Sep 14, 2007 | IBM Netfinity 3500 M20 8657 Server
Intel D945GCZ Motherboard Logo
550 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
