Question about Vtech 5.8 Ghz Handset Cordless Phone System with Digital Answering & Caller ID
How do I reset ringer to "on" if it is set on "off"
    Genius:
  • 1,456 Answers
Hello
Press "Prog" on the handset.
Press the arrow button beneath the phone's display until you reach "Ringer," then press "Select."
Press the arrow button until you reach "Ringer On," then press "OK." The phone should beep to confirm your selection.
Method Two
Press the down arrow key until you reach "Ringer Vol," then press "Select."
Press the up arrow key until to increase the ringer volume you want then press "Select."
Posted on Apr 11, 2011
My phone has "Ringer Off" how do I fix this??/
My cordless is a VTech ... so not quite the same, but you need to go to menu or settings or select .. then scroll till you find RINGER TONE (not to be confused with key tone). Select RINGER TONE and should be able to scroll down to select different ring sounds. One of the options will be OFF. On mine, it is 0. Select any one of the others to make it ring. There is no ON ... if you follow my drift.
Hope this helps Tricia in Bermuda
Aug 08, 2011 | Panasonic KX-TG2313W 2.4GHz Digital...
Phone does not ring on incoming calls. The manual suggests "make sure ringer is on." Where is the ringer?
Ringer On/Off and Ringer Volume 1. Make sure your phone is in idle mode. (not in Talk mode) 2. Press the VOL (- or +) button to activate the ringer volume setting. 3. Press either the LINE 1 or LINE 2 Soft key to select the desired line. 4. The LCD will display the volume range and currently-selected volume in an ascending series of bars. 5. Press the VOL (- or +) button up or down to increase or decrease the volume in steps. 6.The system will retain the last entry, it is not necessary to save or acknowledge your selection from this mode.
It is also possible you have set the DND (Do Not Disturb) feature which will also caution your phone not to ring when a call comes in.
Have a great day. Hope this helps.
Jul 05, 2011 | RCA ViSYS 2-Line Speakerphone
Message box says, "ringer off".
Ringer Settings
Handset ringer volume
4 levels (high/medium/low/off) are available. The default setting is HIGH.
1. Press "Menu."
2. Scroll to "Ringer setting" by pressing up or down arrows.
then press the arrow that looks like a play button arrow pointing to the right.
"Ringer Setting"
3. Scroll to "Ringer volume" by pressing arrow down or arrow up, then press the play button type arrow.
4. Press arrow down or arrow up repeatedly to select the desired volume.
5. Press "Save."
(To turn the ringer off, press down arrow repeatedly until "off?" is displayed, THEN PRESS "SAVE.")
Here's the manual:
http://service.us.panasonic.com/OPERMANPDF/KXTG2431.PDF
Please give me positive feedback if this helps you.
Thanks.
Feb 23, 2011 | Panasonic KX-TG2431 Cordless Phone
I have 4 KX-TG2740 units, each with 2 lines. One unit does not ring for line 1. It says "Ringer Off line 1". I can't figure out how to correct. Thank you.
Press CONF/FUNCTION key, scroll to Ringer Setting by using the up or down arrow of the center navigator key, then press the right arrow. Press the right arrow again at Ringer Volume. Press the down arrow to select Line 1. Press the up or down arrow to choose the ringer volume you want. Press the right soft key SAVE, a confirmation beep will sound.
The ringer volume can also be set while a call is ringing in on the line. Make a call to Line 1 number, use up or down arrow key while phone is ringing to adjust volume of Line 1 ringer.
The following link is for the manual in pdf format.
http://service.us.panasonic.com/OPERMANPDF/KXTG2740S.PDF
Jan 31, 2011 | Panasonic KX-TG2740 Cordless Phone
How do I go from "ringer off" to "ringer on"??
Assuming that this is a digital phone with a Navigator button (like 76xx or DTxxx), then press either the RING OFF soft key and the up button on the navigator button, or just keep pressing the up button on the navigator and the RING OFF will change to a level and the phone will ring.
Carl
Jan 15, 2011 | Panasonic Lands Phones
Ringer does't sound, manual says "switch it on". Doesn't tell me where the switch is. GE. Model 28811 series DECT 6.0 cordless.
With the phone off, press the #/pause button. The display will show "set ringer level 5", using the caller ID/volume button scroll to the level you want. Press the #/pause button to save your setting.
Dec 11, 2010 | GE Lands Phones
We've misplaced our owners manual. Keypad on phone #1 is worn - cannot select #1 when dialing. Display shows "ringer off" and we do not know how to reset the ringer. Help!!
Here is the link to the owners manual that you can down load. Hope it helps.
http://www.retrevo.com/support/Panasonic-KX-TG2383S-Telephones-manual/id/2914ci759/t/2/
Nov 23, 2010 | Panasonic KX-TG2383 Corded Phone
Sir my mobile model nokia 1100 i have a ringer problem . i changed ringer also but not working .so what i do
ya.. try to reset.. here is the reset code..
To restore Factory Settings for Nokia 1100
*#7780# reset to factory settings.
I HOPE,THIS SOLVES YOUR PROBLEM..
Apr 01, 2010 | Nokia 1100
Will not ring only vibrate
when you set the ringer to ring only will it ring?
on the side of your iphone there is a switch above the volume switch that is a ringer/vibrate switch
switch it and test
Jun 05, 2009 | Apple iPhone Smartphone
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
Vtech 5.8 Ghz Handset Cordless Phone System with Digital Answering & Caller ID Logo
99 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
