Question about Hotpoint Washing Machines
Can i use a washing machine with a broken drum paddle?
  • 155 Answers
SOURCE: Drum Paddle broken Hotpoint Aquarius
The paddles in the drum are there to agitate the clothes being washed. Without them, it is possible that the drum would just spin while the clothes sat still at the bottom.
For optimum performance, it is best to have all the paddles present, but if one is broken/missing then it shouldn't have too much effect.
Hope this helps,
Matt
Posted on Mar 08, 2008
SOURCE: One of my drum paddles
i had the same problem and sourced the parts from ebay - 3 for £9.99
Posted on Jan 04, 2009
barkencoa
  • 3463 Answers
SOURCE: remove drum paddle from hotpiont wma37 washing machine
Hi.
Firmly grip the paddle, and pull it towards you, this should release same. When you put it back, locate the paddle in the slots, and push firmly away from you
towards the rear of the drum
Good luck
Posted on Nov 22, 2008
dmftrucker
  • 1922 Answers
SOURCE: replace broken drum paddle
remove front and then top cvrs and you can repl paddle from there
Posted on Oct 19, 2009
apart4u
  • 213 Answers
SOURCE: How do I replace Drum paddle on Hotpoint WF860 washing machine
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Posted on May 06, 2010
How do i fix a paddle on the drum? I have zanussi machine. Paddle broken off. If i buy a new paddle how do i fix it on? Have tried to glue old paddle with no success!!
With some of these machines now they have sealed drums.On some models you can access through the bottom sump hose and others you may be able to get access through the hose by the soap box.There are a couple of drums where you can drill a hole in the top to get at the tags on the paddles and some drums where you cannot do without changing the complete tub.
Hope this helped.
May 17, 2010 | Zanussi FJD1466W Front Load Washer
Where can i buy a washing machine drum paddle (for inside the machine) one has snapped off today.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Mar 23, 2010 | Indesit W 123 Front Load Washer
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
Oct 19, 2009 | Indesit W 123 Front Load Washer
Drum paddles keep falling out (Hotpoint BWD129 washer/dryer)
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing.
As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
Jul 17, 2009 | Washing Machines
Plastic padle on inside of drum broken
Yes the paddles can be replaced. www.bellparts.com type in your model # and locate the paddles.
I hope this helps you.
Vic
Jul 12, 2009 | Washing Machines
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
Mar 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint WMA64 Front Load Washer
Hotpoint WD860
Aug 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
How do I replace a drum paddle in my Hoover washing machine HSWF167
there should be a plug on the top of the agitator. pry off this cap with a screwdriver. you will see the hex nut that fastens the agitator. remove the hex nut and lift the agitator from the transmission shaft. Installation is the reverse of removal.
Mar 17, 2008 | Washing Machines
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
1,813 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
