Question about Xante CL30 HSE Laser Printer
Paper keeps jamming in the fuser. I have tried setting the levers in both directions - not sure which is the correct positioning for them, as it doesn't seem to make much difference.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
If you have many jams in the fuser probably the roller have dry toner attached to them. print a heavy paper - 300gsm - without any color, just a small dot. see if the paper comes out of the fuser and if it;s dirty or not. repeat that until the pages com out clen - both sides. then print what you have again,
Posted on Nov 02, 2013
Xerox 7760 paper jam
at which position it will jam it matters tell in detail or send a sanp of it
Apr 10, 2013 | Xerox Phaser 7760/YDX Laser Printer
I have paper jammed in Xerox 7700 rollers and cannot remove even though I release the green lever on right side. Do I need to release something else?
The green lever you are referring to are I'm assuming is on the fuser. If the paper is jammed in the fuser and you are unable to remove it try removing the fuser and trying to remove the paper again, there are two thumb screws that hold it in. Make sure the printer has been off for awhile because the fuser gets VERY hot. If paper is constantly jamming in the fuser or you are unable to remove the paper you should replace the fuser, part number 016-1887-00 iteminc.com offers them for $$235 new and $139 for a refurb. Hope this helps, good luck
May 16, 2011 | Xerox Phaser 7700DN Laser Printer
A fault or error has occurred. Code 010-327
Solution : Power the Machine OFF and ON CAUTION: Wait at least 30 seconds between powering the machine OFF and powering the machine ON. Damage to the optional hard disk could occur.
  1. Press the power switch to the OFF (O) position.
  2. NOTE: If the machine is equipped with the optional hard disk, the machine remains on for approximately 10 seconds, while storing files and preparing for shutdown. The machine then shuts down completely.
  3. Press the power switch to the ON position.
IF THAT FAILS TRY THIS NEXT:
Solution : Clear the Paper Jam Behind Cover A
  1. Open Paper Tray 5 (Bypass Tray).
  2. Lift up the Cover A release lever, and open Cover A.
  3. Remove any paper below the Fuser Unit by carefully pulling up and out.
  4. WARNING: Do not touch the Fuser Unit, as it may be hot.
  5. If the jammed paper is inside the Fuser Unit, lower the green A2 lever in the direction of the arrow to open the Fuser Unit Cover.
  6. Push down and rotate the green A1 lever in the direction of the arrow to feed the paper from the top of the Fuser Unit.
  7. NOTE: Do not pull paper downward during removal.
  8. Close Cover A until the cover latches.
  9. Close Paper Tray 5.
For pictures on this procedure please follow link: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=218,E=0000000002703126506,K=8100,Sxi=4,Solution=obj(1027)
Hope it helps!
Apr 22, 2011 | Xerox WorkCentre PRO 128 Copier
ERROR CODE 010-327
Hope it helps!
Apr 07, 2011 | Xerox CopyCentre C128 Black and White...
I keep getting a printer jam when trying to print, I clear the jam and then it sticks again, wither in the tray, the inner door or the fuser, any ideas appreciated..
Please check the error code when paper jams. The code will indicate where the jam is. Also let me provide some tips to prevent paper jam.
Flex, fan, and straighten paper before loading it. Make sure the paper lies flat in the paper tray. Do not load too much paper. Make sure the stack height does not exceed the indicated maximum height. Make sure the guides in the paper tray or the manual feeder are properly positioned and are not pressing too tightly against the paper or envelopes and push the paper tray in firmly after loading paper. Use only recommended paper or specialty media.
Do not load wrinkled, creased, damp, bent, or curled paper. Do not mix paper sizes, weights, or types in the same stack and make sure all sizes and types are set correctly in the printer control panel menus.
For Further Assistance, please contact Lexmark Technical Support.
Mar 14, 2011 | Lexmark C534dn Color Laser Printer
Xerox CopyCentre C128 Black and White Copier Fault 010 327
  2. NOTE: If the machine is equipped with the optional hard disk, the machine remains on for approximately 10 seconds, while storingfiles and preparing for shutdown. The machine then shuts down completely.
Hope it helps!
Feb 27, 2011 | Xerox CopyCentre C128 Black and White...
Hope it helps!
Sep 14, 2010 | Xerox WorkCentre PRO 128 Copier
Paper jam error
have you removed the fuser unit? i am sure that there is paper in there that you can not see holding down  thew fuser sensor, good luck brother sr tech
Jan 20, 2009 | Brother MFC 7420 All-In-One Laser Printer
Ricoh aficio 150 paper jam
There are pressure release levers on the fuser --- if they are not in the correct position they will not apply the proper pressure and you will get jamming in that area. The levers are either a light green, light blue or plain black. They should be on the left and right side ( looking in at the fuser. Turn/ flip them and check.
Dec 02, 2008 | Office Equipment & Supplies
Paper jam. we removed the major portion of it. bit of paper is inside. we can't find out that. display shows 13.20.00. we removed front and back except toner catridge. what we have to do.
Try this linke below.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=411171&prodTypeId=18972&prodSeriesId=411171&objectID=c00642524
Or i cut and paste text, but you should view pictures. If you cannot get to it from link. Try typing "Paper jams alternating between front and back door" It should be first link from HP about a 3550.
HP Color LaserJet 3500, 3550, and 3700 Series Printers - Paper Jams Alternating Between Front and Back Door Issue Description Customers may see paper jams error messages with no paper seen in the paper path. The message will alternate between check the front door and the back door. Workaround The release lever engagement tabs on the rear door can be bumped into the in-correct position. The purpose for this tab is to re-engage the fuser release levers as the rear door is closed. When one or both of these are left in the in-correct position the printer goes into a cycle of alternating between a "Jam in the Front Door" message and "Jam in the Rear Door" message. There is no paper present in the paper path when this happens. When a customer gets the "Jam in the Front Door" message and opens the front door, no paper is found. After the customer closes the front door, they get the "Jam in the Rear Door" message. When they open the rear door, find not paper (even pull out the fuser), and close the rear door, they get the "Jam in the Front Door" message. This cycle will continue
Placing both engagement tabs in the "Correct" position solves the problem and allows the print job to continue.for as long as the customer is willing to keep checking.
Sep 27, 2007 | HP LaserJet 3550 Printer
Xante CL30 HSE Laser Printer Logo
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
