Question about Kenmore Freezers
Kenmore deep freezer model 253.26432100. Doesn't stay down at a constant temperature. Some items ie meat stays frozen but bread doesn't.
3 Suggested Answers
  • 41 Answers
SOURCE: Deep freezer thawed out
the last one i did was a chest freezer i froze the stuff then turned it off let it start to melt and pulled it out in one peice dan
Posted on Jul 22, 2008
  • 3 Answers
SOURCE: Sears Kenmore Deep Freezer settings
i tilt my chest kenmore deep freezer to remove water when cleaning it by the time it was connected it didnt work
Posted on Jan 21, 2010
Orange light in front is flickering almost constantly. What might this mean? The food seems frozen -ice cream is fine as are breads and meats.
It is normal for those lights ot flicker.. as long as the unit is working then do not worry about that...the light really is just showing you that you have power to the unit...
heatman101
Aug 26, 2010 | Kenmore 15 cu. ft. Chest Freezer 16542
Yesterday the door on my 14 cubic ft upright freezer did not stay shut tight (it was ajar about 1 inch for about 6 hours). When I became aware I closed and locked the door to be sure it stayed shut, but...
it may take upto24 hours to settle to -18C,remember it has to cool right through the food in the freezer,as well as the walls.also if the food went soft, it is spoilt......cook meat asap then refreeze.
Aug 12, 2010 | Kenmore Freezers
My freezer does not seem to be freezing properly. Some of the meat is staying frozen while some is getting soft. All my bread products are not freezing at all they are staying cold but soft???
THE RED WARNING LIGHT KEEPS COMING ON AND I HAVE TO KEEP PRESSING THE FAST FREEZE BUTTON, THIS IS EVERY FEW DAYS. IF I DONT NOTICE ALL THE FOOD DEFROSTS!
Mar 23, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My wife and I bought a Kenmore chest freezer (14.8 cubic foot) about 6 weeks ago. It is made by Frigidaire for Sears, and the model number is #253.165.42105, serial # WB94341279. It has been working OK. ...
This is well with in factory specifications. Hot air rises and cold air drops. Because a chest freezer does not have a fan to circulate the air it is normal for the basket to be warmer than the bottom of the freezer. The bottom of the freezer is used for food you want to keep for a longer period of time.What you store in the basket is food you will freeze for a short period of time. Ice cream should not be kept in the basket. As you fill your freezer with food you will find that the temperature will equal out because the frozen food will take up the place of the frozen air which will give you a more stable freezer temperature.
Try your test when you have it full of food.
Dec 29, 2009 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
It sounds like you have a circulation problem.
Spread out the packages so the freezing air can circulate.
  • Check that the condenser fan is on
  • Check that the coils are not covered with lint and dust especially if they are under the freezer.
  • you may need a tech to put freon in the system.
Apr 06, 2009 | Kenmore Freezers
Freezer not freezing
not freezing icedraem is an issue, bread not so much, different breads contain different ingrediants that may or may not freeze, forst offthough wher is unit located??? in garage??? if so be aware that it may not operate efficiently ion ambient temps lower then 55 degrees, but if this is in your kitchen i would suspect a "refrigeration"/sealed system issue, perhaps "low on charge and not able to maintain a frozen set temp. Meat may stay frozen ( for a little while anyway, but the ice cream is the first to show indications of problem
Jan 11, 2009 | Freezers
Freezer Burn
It sounds like you may be overloading your unit. If you place a large quanity of non frozen items in the freezer at one time, it may take a few hours to bring the temperature back down. This usually happens with a chest type not an upright. Insure when adding items to the freezer there is room for air movement. With out looking at it I think the problem is the defrost timer or sensor. Maybe staying on too long increasing the overall temperature of the unit. When ever the defrost cycle is on, the cooling unit is also off. As far as the meat freezer burning, none of the freezer bags I have used prevent this. I pr-wrap my meat in freezer paper and then place it in a bag, sometimes freezer bags sometimes not. I try not to buy meat from grocery stores, I grow my own meat and have it butchered and vacuum packed, it doesn't change color. Please note that items in a freezer bag moved around after the contents have frozen will cause air leaks in the bags very easily.
Nov 26, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Nov 10, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
150 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
